Bas Hamstra
This time I attached an extra bottom-up reflector to my AK diffuser (diffuser is a too small, I was hoping to compensate). Somehow it doesn't work well because despite the light is first diffused and then reflected, it still throws too much light straight ahead and making everything hazy and more specular. Go to redo this some time hopefully. In the meantime here are some shots.
In the first shot you actually see the shape of the bottom reflector, which I don't quite understand. Shouldn't the unreflected diffused light be way brighter? It probably has to do with the camera angle, at a certain angle the diffuser fires straight down into the reflector, that throws it straight forward.
Bas
Bas
