Sergey_Green
Sure. But getting closer to the subject does also mean you are restrained by framing, which you can only control by giving up on other parameters for it. Full circle and you are back to where you started.If the format size changes then you have to manipulate one of the variables. I can get shallow DOF on my Panasonic LX5 compact because I understand that DOF decreases as the aperture gets bigger, and it also decreases as I get closer to the subject.But every single one of these variables is sensor size depended, would not you say? And would not it be then perfectly correct to say that achieving the effect will get harder and harder as the sensor size gets smaller and smaller. Or is it not so?Having used many different systems in both cinematography and photography, you can achieve just about anything you want with just about any system/format you want if you know how to use the tool.
Many time, I find, people use ultra shallow depth of field to ignore their background (note the word many). Not to say that I want to see every fine detail in my backgrounds, having some semblance of what is in the background is really valuable to me. I find it allows the whole scene to be noticed but still have the subject be the focus.
In the end, there are so many things that affect depth of field. People like to boil it down to the size of the sensor but that is one minor variable. It is more akin to saying eating a lot of bread make you fat. That could be a contributor but there is much more to that equation than the bread.
Angle of view, focal length, distance from the subject, reproduction size, etc. all affect depth of field.
--My advice, learn how to use your tools, don't think in "equivalence", and use the gear that gives you what you want. Let the other photographers talk about it, you go out and do it.
-A
- sergey
I can also get shallow DoF with my camera phone, sometimes. Can I safely rely on the techniques you describe above for whenever I need it?
Can be done with full frame setup no less than it can be done with mFT setup for the same focal length and framing. Therefore what?I can also get get front to back sharpness on my 5x4 camera because I understand how to manipulate DOF using the Scheimpflug principle and aperture size.
Spare me the history lesson. Just like the idea of home matches (for creating controlled flame) was discovered from a dried lump on the end of a stick that was used for stirring a mix of chemicals; microwave oven was a result from a radar defence tech military experiment; and potato chips was a result of a pure prank, and not a $7 billion a year enterprise planning. Does the this information make those appliances for our use less important or more important?..
These days most discussion about DOF is about how to achieve shallow DOF and the discussion centres around aperture size. When fast lenses first started to appear they were considered essential not because of the shallow DOF potential but because film speeds were slow.
- sergey
