Hi All,
I have been away from this forum for very long time but was reading some posts sometimes. My D7000 died few months back so recently I purchased used D7500 in excellent condition with very low shutter count (only 2300).. Camera is fine, still getting used to it though. I have external flash Yongnuo YN568ex which worked perfectly fine with my D7000 but not working as expected with D7500.
So I can use this flash fine when its mounted 'on-camera' but its not working as expected when off-camera. When off-camera I can see flash does in fact trigger but photos are coming way too dark as if taken in dark room with very limited light (even when subjet is within 2-3 feets from flash). So I'm not sure if this flash is compatible with D7500 or not for off-camera mode.
Has anyone used this same flash in off-camera mode with D7500? Not sure if there is any setting that I'm missing. In flash I have set it to i-TTL, off-camera, Sn A Group, channel 1. In camera I have enabled 'wireless flash option' under 'Flash control' setting and set 'built-in-flash' to --, Group A to TTL, Channel 1. (It's weird that Nikon changed this setting location for external flash compared to previous models.)
In case this flash is not compatible with D7500 then can purchasing YN-622N Wireless Flash Controller fix this issue in off-camera mode (I'm not even sure if this is controller is compatible with D7500)?
Thanks in advance
Thanks in advance
