alfred_schiele
Hi
Maybe you understood wrong and I have could worded better.
I expect when metering a reference gray to produce something like a bell curve with the center ideally in the middle of the histogram.
There are two parts, the metering itself (no matrix metering here please) that refers to the ideal gray and the subject that is metered. If the metered subject is dark - as a result to the metering standard - it should still come out gray... refering to uncorrected metering. If you want something different for darker or brighter subjects you have to compensate EV then. If you do so, right, the historgram changes then. And: the historgramm tells of course more than the graypoint does...
If the gray metered subject does not produce a gray image there are two ways to go:
1. EV compensation. This is somehow inconvenient just to shift the gray point to where it should be, at ZERO EV...
2. A custom curve. More convenient as the graypoint standard can be kept close to EV comp. ZERO. But on the other hand it introduces some nonlinear behaviour that can be positive or negative depending on the curve shape used and your need, preference or taste.
In the meantime a downloaded the curves and analyzed them. The one that is called ev0_... has a confusing name as it does shift the graypint up a good deal as well. Nevertheless the curves are interesting as they reduce contrast in the highlights and give a bit better detail visibility there.
All these curves seem better to me than the predefined N* standards.
Regards, A. Schiele
There is nothing wrong with my view on metering.WHAT , your smoking crack, just because you meter grey doesnt meanThe "problem" I evaluated is more subtile. If I meter a graySo, if you have no problem with your exposures, don't use my curve.
subject I expect it to be in the center of the histogram
the histrogram is in the centre,what if 2/3 of the subject is black
think your theory again
Regards, A. Schiele
