Yes, I'm pretty sure that I could do it, though it does take me a bit of time and effort. Remember, I don't live and breathe this stuff like you and others here do and only started thinking about this stuff around a week agoYou ignored my posts. Do you need help with the physics, Physics1? You should read Joseph James' and Richard Butler's articles. Then work out the exposures for yourself in the DPR tests, look at Bill Claff's input-referred noise data, and make the appropriate deductions. Start with Butler's articles.
http://www.josephjamesphotography.com/equivalence/
https://www.dpreview.com/articles/2666934640/what-is-equivalence-and-why-should-i-care
https://www.dpreview.com/learn/2799100497/equivalence-in-a-nutshell
Remember that the fraction of light collected from each subject point is proportional to the lens entrance pupil area and inversely proportional to the square of the distance to the subject. Remember also that the magnification is proportional to the focal length, and the entrance pupil diameter D = f/N, where N is the f-number. You can figure out how to normalize the DPR tests and figure out the appropriate exposures. You should find that the situation is what I already told you. Good luck. I'm traveling, and can't give any handholding.
But ultimately you are likely to be in the situation where the DP Test Image taken under the conditions that you would like does not exist, and you need to choose the closest, which is a bit rough and approximate.
Also, how often, actually, are we in the situation where shot noise is not dominant? I don't usually care about DOF, but I take the point that if you do, then you may be forced to stop down the lens and compensate with high ISO. And if the ISO is high enough then you have very few measured photons, and the readout noise could be significant. In fact eventually it must become dominant, but before that happens the shot and readout noise could be so high relative to signal that the image is probably unusable anyway? Hey, I'm not a photographer or even a photographic enthusiast and have only my broad scientific background to guide me
