elliottnewcomb
It uses Oly Stylus 1 Lens, same size sensor, not sure if same sensor, as it is so fast in burst shooting. uses CDAF, not Hybrid PDCD like rx100m5 and new Nikon DL's
Casio EX-100F notes from Casio manual, 1-14-17.
http://support.casio.com/en/manual/manualfile.php?cid=001018003
Info for Stills, I don’t shoot videos. (my understandings, errors might be included below)
1. Language: verify your language is an option.
2. 49 MB internal memory
3. Self Open/Close Lens cap auto like Oly
4. Remove cap: threads, Oly conversion tubes/lenses & filters fit
5. Jpeg Compression: Default Image Quality is Normal. Fine is an option. No SF superfine. Extra Zooms, Burst shooting, other modes change to Normal compression even if using Fine for stills.
Always the same # of pixels, but different amounts of data retained for later PP. Casio 12mp image size chart: RAW is 127% larger file/more data than Jpeg Fine; Jpeg Fine is 78% larger file/more data than Jpeg Normal.
6. Front Button: Shutter or Re-assign (where Oly lever is, lose front lever MF/AF toggle)
7. Flip out stand behind tilt lcd for table top use
8. LCD up 180 degrees, down 55 degrees (oly up abut 80, down about 55
9. LCD, 3-1/2” not touch screen, oly is. Brightness range: auto, +2,+1,0,-1. (dark enough to shoot inconspiculously?)
10. LCD display: grid, level, histogram, movie image area
11. ND filter: on, off, no Auto
12. AF assist lamp: on, off, no auto
13. Motion Shutter, wave hand, for starting self timer selfies from afar
14. Self Timer is a recording mode, thus cannot be combined with other modes like bracketing
15. Language: confirm version has yours
16. No EVF
17. No Hot shoe, thus no external EVF or Flash or Mic
18. No AEL
19. P mode = normal single shot program auto
20. Premium Auto Pro = auto, possibly using multi-shot blended into 1 shot, not for motion
21. Slow Shutter Speed, camera will use both NR and high ISO
22. BS Best Shot, is like Scenes in other cameras, uses icons and presets
23. Custom: up to 12 sets of custom settings
24. Can use Step Zoom, and, can use Last Zoom, and Last Focal Length when turned on, if set up
25. WB, auto, many pre-sets, set by white paper, however, no specific Kelvin scale to choose from.
26. Macro, Auto Macro, Super Macro (?), Magnifying Glass (?).
27. Flash, and flash compensation. Flash is auto pop-up, (cannot leave flash on in settings and leave flash down; use it by releasing flash like Oly, without going into the menu).
28. Metering, always centered: large, medium, spot (spot cannot follow focus spot like Oly does).
29. Focus: CDAF contrast detect. AF-S (single pre-focus at what it camera is aimed at, wait for half press?); AF-C, continuous AF until half press (continuous pre-focus?); MF; Face; Tracking; All-In-Focus (multi-shots, like focus stacking). AF-less (no focus, it just shoots instantly at half press, no lag, ?)
30. Focus Area: large, multi, medium, spot. Multi is 9 block grid, can toggle to use any 3 block area, or toggle 1 block (any of the nine), like spot, back to 9 blocks
31. Zoom Options (see separate zoom chart):
a. Optical
b. HD, sensor crop, no upscaling, available at 8mp and 3mp image sizes
c. Single SR (super resolution), single shot, (sensor crop and in-camera upscaling)
d. Multi SR, like SR but a blend of several shots, not for motion. Automatically uses Anti-Shake (IS) ‘Standard’. Must be in Best Shot to use these.
e. Digital, nasty like any digital zoom. Why do they include it?
32. Anti-Shake (IS). 5 axis. Standard, Strong (uses faster shutter, may use high ISO), OFF (off for tripod use). Note: says if IS set to standard, then exposure settings are not shown on lcd???
33. Intelligent Bracketing, a few types, needs clarification.
34. Burst, High Speed CS (continuous shutter). Must be in P mode, then pick CS, then pick speed:
Individual Focus each shot: 3,5,10,15,30 fps, (using 12mp image size, Jpeg Normal Compression)
Focus first shot then repeat: 60fps (using 8mp image size, Jpeg Normal Compression, 16:9 AR)
Set # of shots: 5,10,20,30. Uses AF Spot Focus Area.
35. Pre-Record CS shots. Half Press, starts pre-recording shots into the buffer. Full Press the CS process starts, pre-shots are recorded from the buffer to card, and subsequent CS shots are into buffer, onto card normally. IF release half press, the pre-shots are discarded from the buffer.
36. Stills while shooting movie: single, or CS up to 7 shots at 10fps speed
37. Best Shot, ‘scenes’ to get pre-sets automatically, and special modes
a. Triple Shot, pre-records, takes 3 shots, IQ Normal
b. Blurred Background. In-camera analysis, in-camera processing, blurs background
c. All-In-Focus, multi shots, like focus stacking, blended in-camera
d. HDR Art, High Dynamic Range. Automatic bracketed exposure burst, processed into single HDR, or, Double, both HDR and Single shot as per the settings.
e. HS AS, High Speed, Anti Shake, combines a burst, uses Auto ISO
f. HS Night Shot, burst, combined
g. HS Best Selection (portraits). Takes a burst, picks and keeps one shot (no blending), based on blur, smile, blink analysis.
h. Slide Pano. Focus and metering set at beginning of the sweep. Horizontal up to 360 degrees (11,520 x 1080 pixels); Vertical up to 180 degrees (1920 x 7296 pixels). Select 60,120,180,240,300,360 degrees. Note: can set for vertical sweep, turn camera vertically, and sweep sideways, get 1920 h x 7296 wide.
i. Wide Shot (3 shot sweep combined to wide shot. Options: 17mm or 21mm (not exact). Camera in Vertical Position, sweep sideways. Note, not only wider, much more height, 1,920 pixels high: 78% more than normal 1,080 h. It might be possible to do this sweeping vertically, getting a much wider 1,920 p and taller vertical shot.
38. Assignments of Rings, buttons, etc. are shown at the edge of the lcd, reminding you.
39. ISO, auto, 80,100,200,400,800,1600,3200,6400,12800. No Auto ISO in M. Can set ISO high limit, cannot set ISO low limit. Native ISO?????
40. Image Sizes: 12mp, 8mp, 3mp. Full sensor 4:3, or aspect ratios 3:2; 16:9
41. Lighting (OIB Optimizes Image Brightness) in-camera, like DRO (dynamic range optimization)
42. Exposure Compensation, no separate dial or rocker, use front ring, or use menu.
43. Adjustments: sharpness, saturation, contrast, flash strength. Either +/-3 or +/-2.
44. Settings (many) can be retained as your defaults at power on, including last zoom position.
45. HDMI out may include PAL 576p option (verify your model)
46. Alternate Image Creation(s) in camera: later, in Play Mode: in addition to the normal image captured, being viewed, make an alternate OIB; Brightness; WB; Crop; Re-size;
End of notes
Zoom Chart
Found this cool Camera Evaluation Graph
I will post a link to this in the Casio Forum, perhaps they can add to our understanding.
Oly Stylus 1, some comparative notes here
https://www.dpreview.com/forums/thread/4075193
Elliott
16. No EVF
18. No AEL
a. Optical
End of notes
Zoom Chart
Elliott
