LDJS Photography
Leading Member
- Messages
- 664
- Reaction score
- 619
Hi. In C1 express in the lens tab where you can make corrections there are 3 tabs I am unsure about
Distortion
Sharpness falloff
Light falloff
These are at default of zero. They go higher than 100 but I just figured 100 for each was the correct amount
Should I leave at default or am I correct that 100 means 100 percent correction?
Also is there a toggle button where you can see the effect turned on and off like there is in ACR and Photoshop? (For example in photoshop it looks like a little eye and you click it and it shows with and without the new adjustments for curves / levels etc)
Distortion
Sharpness falloff
Light falloff
