cannot get photographs off a memory card
InvisibleCities
New member
US
Hey, just wandering if could help me get some images off a memory card - or else let me know if I should abandon all hope. I took some pictures with a Nikon Coolpix 5000 which used a 1GB Compact Flash card made by PNY Technologies. I didn't have time to take the photos off, so I left the camera in a lab I work in: there is a high chance that other people used it after me. When I came in the next day I was unable to get the computer to access the files, and I tried many things - hooking up a USB to the camera, using a flash card reader, switching computers - nothing worked.
When I open the card, there is the DCIM folder, which usually contains the photos, and a file titled BOOTEX.LOG. If I try to open DCIM an error message pops up: "G:\DCIM no accessible. The directory name is invalid". BOOTEX.LOG contains the following lovely notice:
Checking file system on I:
The type of the file system is FAT.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
Volume Serial Number is 2007-0109
Unrecoverable error in folder \DCIM.
Convert folder to file (Y/N)? Yes
Lost chain cross-linked at cluster 255. Orphan truncated.
Lost chain cross-linked at cluster 1389. Orphan truncated.
Lost chain cross-linked at cluster 1690. Orphan truncated.
Bad links in lost chain at cluster 1849 corrected.
Lost chain cross-linked at cluster 2573. Orphan truncated.
Lost chain cross-linked at cluster 2521. Orphan truncated.
Bad links in lost chain at cluster 3239 corrected.
Bad links in lost chain at cluster 3579 corrected.
Lost chain cross-linked at cluster 3916. Orphan truncated.
Lost chain cross-linked at cluster 4900. Orphan truncated.
Lost chain cross-linked at cluster 5027. Orphan truncated.
Lost chain cross-linked at cluster 5122. Orphan truncated.
Bad links in lost chain at cluster 5258 corrected.
Bad links in lost chain at cluster 5892 corrected.
Bad links in lost chain at cluster 5955 corrected.
Bad links in lost chain at cluster 8756 corrected.
Bad links in lost chain at cluster 10700 corrected.
Convert lost chains to files (Y/N)? Yes
70352896 bytes in 79 recovered files.
Windows has made corrections to the file system.
1023623168 bytes total disk space.
16384 bytes in 1 hidden files.
16384 bytes in 1 folders.
70385664 bytes in 80 files.
953204736 bytes available on disk.
16384 bytes in each allocation unit.
62477 total allocation units on disk.
58179 allocation units available on disk.
Oh, ad I can still view the photos using the Coolpix, but no other camera. Does anyone know the way out?
