Can I use CF I and CF II both at once?
pekr
Leading Member
CZ
Hi,
it's just some two weeks before I finally get my G2. I am deciding upon additional CF card. I can't go with Microdrive or so, as it is too expensive here.
But - what happens if I use CF I and CF II at once? Can I do so? How does camera decide, which one to use? Or is there any menu item to select? Or? :-)
Thanks,
-pekr-
It won't work! They both go into the same slot. --- Ron
Hi,
too expensive here.
to select? Or? :-)
Thanks,
-pekr-
Aren't Microdrive and CFII the same animal?
Hi,
too expensive here.
to select? Or? :-)
Thanks,
-pekr-
Zippity
Wellington, New Zealand
There is only ONE slot. It will take CF I or CF II but only one or the other - you can't put in two cards.
Hi,
too expensive here.
to select? Or? :-)
Thanks,
-pekr-
CF I andd CF II are the format used, the size. The pins inside the door are used for all three types of media. You can only use one media at a time.
Go to http://www.dpreview.com/learn/Glossary/Camera_System/Storage_Card_01.htm and learn the difference in all three.
JB
Hi,
too expensive here.
to select? Or? :-)
Thanks,
-pekr-
Microdrive is not a CF (different hardware inside), but it interfaces with the camera's software in the same way as a CF II. - Therefore, any camera that takes a CF II will take a microdrive.
Whether a camera that takes a CF I also takes a CF II depends on how smart the camera's operating system is. The G2's has this capability.
The physical connections are the same in every case, and the camera does the recognition automatically. And it only fits one at a time..
Hi,
too expensive here.
to select? Or? :-)
Thanks,
-pekr-
Zippity
