M
MattPointZero
Guest
there is very limited DR in the posted images.More great user experience, thank you, nice shots. Great to hear the DR issues are as overblown (no pun intended) as I am reading in other reports!I am doing all this with my A9 III. I got it for our portrait business for shooting out in the sun as we shoot beach portraits for a living and beach weddings everything out doors.
First off the DR limitations are over rated I am not seeing any problems at all on this.
Also you can shoot at lower iso then 250 I have shot at 125 with no problem at all.
I only use one Godox AD200 flash on our jobs and now with the A9 III I have had to turn the flash power down so much it's amazing.
I am using less flash power now then I ever have in over 25 years of doing this. Most of the time i am in the 1/64 flash output range now vs 1/2 to full at times before out in the sun.
Before the A9 III I would be at F8 to F11 when we start our session one hour before sunset as it is still very bright out on the beach. Now I am at a F4 to 5.6 or even F 2.8 based on the group size cutting my flash output that is needed by a lot so instant flash recycle times. On smaller groups like two people or one I can shoot at F 1.4 or 1.8 now with flash at super low flash settings. Even at the lowest setting I may have to now move the flash more far away as its still to bright when at F 1.4
It is taking me some time to get to this as I keep needing to lower the flash output and the changes are more smaller now. It's amazing what I can do now knocking down the sun and getting a much deeper color in the sky and water on the beach. I have 5 jobs in the next 6 days I will be doing this on as we move into our session.
Even as it gets darker out being able to use the higher shutter speeds is a joy to use I just need to keep change settings and lowering the flash even more. I shoot all manual flash off camera.
I am using a 85mm 1.4 lens now as I can for the first time now with the A9 III outdoors like this with flash. I shoot fast on jobs so a Flash HSS setting I could never use in the past as the recycle times could not keep up.
I just got in some new filters to put on my flash as the flash tends to get a more blur color I see more of now shooting at the higher shutter speeds. So I will be using a mild orange Gell starting today. I have done this many times in the past to give skin tones a better look. It changes a bit at different times of the year for this here..
Then the other side of it is shooting natural light and no ND filter needed wide open.
Here is two from yesterday at 85mm at F 1.4 no ND needed, When its super bright you can only go to F1.8 and it is limited to hitting the much higher shutter speed to F1.8 but when not to bad out as for brightness you can hit the F1.4 or a F1.2. Or you can shoot at F1.4 and be over exposed some and shooting raw pull it back done that works to or change the iso from the base 250 down to 125. I have yet to see any difference in the image quality from 250 to 125 doing this.
I do have another Godox on camera manual flash I am thinking now I could start using it in place of the AD200 as I need so much less flash power now and run it off camera on a stand. But I still need to bring the off camera stand so bringing the AD200 is not that much more to bring vs the smaller flash.
I will have a video out on the Samyang 85mm 1.4 VS the Viltrox 75mm 1.2 in a day or so from this shoot as I shot them both by side to compare cropped a6700 VS full frame A9 III for background bokeh look.
Here is two natural shot light at F1.4 no ND filter and one from a small beach wedding from a few days ago with flash at F2.5.
The info may say A9II as I change the camera name to A9II from 3 so I can edit the raw files in DXO Photolab. This works so I can edit them till they get full raw support out for it.
this is when you need class leading DR no fill flash. fill just ruines the look.
this is an example of how much fill should be used shooting with miday sun behind the subject. very little , and from memory its a godox 685 shooting through a 900mm umbrella. the images have to look natural. fill flash is to fill the shadows not create new ones.
another example of fill flash. the images are to look natural and just fill/add some highlight to the subject, not over power the scene.
That's quite prescriptive - your shots are balanced very nicely, but that's not the same as 'this is how this has to be done in every situation' as there is a lot more artistic choice and variation. For natural wedding and event shots where you want the flash to be invisible, I agree - but that's not the only stylistic option of course
