P
ProDude
Guest
If Canon was inclined (which I'm quite sure they are NOT) they could offer a "at cost modification". if sent back to Canon service, much like the detent removal option for the custom control on the lenses, to add a nice professionally fabricated copper plate to be installed much like this guy did. Then nobody would be complaining about the overheating if they are inclined to use so much intense video. That would take the onus off of Canon. But don't think it will happen.........it most likely won't.Wrong.The thing about a heat sink is it is both a thermal mass and additional surface area. Those two things only make a difference if you use them to more efficiently transfer heat out of the system. That requires a coolant and movement: air over fins using a fan, liquid over a plate using tubes and a pump.+1 extra cost $100 should not issue for a camera sell in $3899. Such heat sink also not a advance tech.
Your solution is extra weight, extra cost, and might buy a few extra minutes before overheating occurs because to make use of that heat sink you need a fan, power, and an air path that would compromise weather sealing.
A little bit more weight, less than 100$, many extra minutes with very quick recovery time and ... no compromise for weather sealing.
Copper plate
LOL ... well ... yeah. Should i comment this?!This sounds like the simplistic thinking of Wikipedia engineers who have no actual training, experience, or understanding of the implications such “simple” solutions truly incur.![]()
Name the gear and I've probably owned it and used it.
