Ron A81271
Member
Does the 995 internal flash emit a single flash when a pic is taken, or is there a quick pre-flash prior to the exposure flash?
Thanks!
Thanks!
I think that the 995 has a pre-flash because the 775 has.Does the 995 internal flash emit a single flash when a pic is
Thanks!
One of the advantage of the 9 CP's is that they don't fire a preflash. Most other DC's do fire a preflash, which, by the way, cannot be switched off. Nikons that fire a preflash are all non-9xx CPs. The exception is the red-eye reduction preflash on the 9's.I think that the 995 has a pre-flash because the 775 has.Does the 995 internal flash emit a single flash when a pic is
Thanks!
One of the advantage of the 9 CP's is that they don't fire aDoes the 995 internal flash emit a single flash when a pic is
Thanks!
Wow, thanks for that valuable (at least to me) info!! My current camera, an Olympus C-3030Z, fires a pre-flash which, just as you said, cannot be turned off. Since most of my pics are of animals, primarily cats, what I end up with is a huge percentage of pictures of animals with their eyes partially or fully closed. I've had my eye on the 995 for a while now, and as long as it doesn't produce a pre-flash then that clinches it, I'm going to buy one pronto!! My C-3030Z is going up for sale!!--
FJBrad
Ron,One of the advantage of the 9 CP's is that they don't fire aDoes the 995 internal flash emit a single flash when a pic is
Thanks!
CPs. The exception is the red-eye reduction preflash on the 9's.Wow, thanks for that valuable (at least to me) info!! My current--
FJBrad
Thanks for the additional info. I do plan to buy a bracket and speedlight. I understand the SB50DX is an excellent choice for use with the 995.Red eye reduction on the 995 is in the form of a light beam rather
than a flash. As stated earlier, the redeye reduction is
switchable.
Keep in mind that the 995 is still a red-eye champ when using the
on-board speedlite. You will get much more enjoyment out of it if
you add an external flash with enough power to bounce off the
ceiling.
RalphM
Virginia/USA
Bob
ps. I have the Rollbar, SB-28 and cp995 like you, too. Still
trying to get consistant flash outputs with external flash.
If I'm not using Auto mode, I use 'M' and set the shutter speed and
f: to whatever the situation requires. For me, this was a matter
of practicing for days and days. I think a +1 EV is the most I
have added for the light box. I walked around the shop or house or
office, wherever I was and filled up 128mb card after 128mb card.
Many times I would not upload or save the shots, because they
weren't 'keepers'. I would just review them in the LCD and
reformat the card when it was full. The history mode in the 995 is
excellent for this learning experience because you can see
immediately what you need to do to improve the shot. The other
feature I love is the zoom in the LCD review mode. I often zoom
each and every shot to check the highlights and shadows to see if I
am getting detail or not.
In the studio this all goes out the window because you have fixed
distances, meters, reflectors; etc.
HTH. PatiO.
Bob
--Nikon e990; Olympus OM2nLondon U.K.hi guys!!
sorry to butt in...i'm just a new nikon coolpix user!!i do have a
cp990...i know it's kinda old...but i got it really cheap and bnew
condition so i gave it a try...I'm now getting all the accessories
i can get w it...i already gottn all the add on lenses exept the
fish eye...all the brackets and filters...
The only acc i still don't have...is an external flash...I only use
my sunpak slave units...i really don't understand the "TTL" w
digicams? i'm planning to buy the sb-50dx this week...the sb28 is
too expensive for me!
well...the guy from the shop is telling me that i don't have to buy
a flash that is TTL coz my cp990 doesn't support TTL flash...(not
like cp995)
Is it true that cp990 is not TTL like cp995?
What flash can u recommend?
i do have 3 as-10 w cords that are ready to fire...but no flash
yet...hehe!!
is it better to buy a non-nikon flash?they say there are lower
priced flash units that are "replica" of the sb-28 that only cost
as much or lower than the sb-50dx?
what other flash can u recommend?
Tnx so much for ur reply!!Tnx a million!!
HTH. PatiO.
Bob
Right. If the image is an important one (money shot) I usually try to get a slight underexposure on the LCD, figuring I will bring it up in PS. Then I bracket the shot one up and one down. Then, when I have a few samples of what I want, I load them in the PC and check out everything. Usually framing and rotation come up 'short' at this stage. If all looks good, I go back and fire away.Thanks PatiO,
I may need to use Auto mode more often to get consistant external
flash results. I've been using Aperture Priority mode with TTL
flash setting and its 65% right on and 35% either over or under
exposed.
You may want to check those images a bit more in the computer you
are only monitoring on the LCD panel. I've found the LCD is much
more forgiving on exposure than the final result on your monitor
screen or printed format.
Yes, I think it does, although I have never tested this.When in TTL mode and Auto for the cp995 does it matter which f-stop
you have the flash set on?
I don't think so. Most of the real experts here say to set the 28 fstop the same as the camera. I always try to do this, but I'm not sure I always follow through during a complete session which can run to 300 or 400 images. I'll have to check myself next time and see how well I do.I think that is overridden by the
camera, right?
Thanks again for your response.
Bob
HTH. PatiO.
Bob
