I did a quick/dirty micro focus adjustment for my 70-200 lens on my new 5D4. Got a -10, which was the same as on my old 5D3, so I felt confident. Went on a walk about and made about 50 shots at various settings. Most of the shots looked a little soft to me.
So I spent the last 3 hrs doing a serious MFA. Custom target, all distances measured twice. Camera as level and parallel as I can make it. Fired about 6 shots at each MFA setting of 0, -5, -10, +5, +10, plus live view. I set the lens to minimum focus distance or infinity before each auto focus. Used only the center focus point, which should be the most accurate. Even made a couple manual focus shots in Liveview at 10x with a loupe on the LCD. Used a heavy tripod, so no camera shake. All shots at 1/400 shutter speed, so no mirror slap vibration.
Found a problem, a big one I think. While accuracy could be achieved, repeatability was poor. I determined that -10 was my best MFA setting (for the max zoom of 200mm). So I made 20 identical shots at that setting, throwing the lens out of focus before each shot. Ten of those were thru the viewfinder, 10 with Liveview. In each batch, only 4 or 5 shots were OK. Close enough to the best reference shot to say they matched. But 5 or 6 of the bacth were not OK. Far enough off the reference to call it a bad focus.
I've had the 70-200 for over 10 years, used on 4 cameras. Used on a 5D3 for the past 4 years with no problems other than operator error.
So, has anybody else done any extensive focus testing? Any similar problems with repeatability? Are you getting better than a 50% success rate?
