I
inasir1971
Guest
This is just a quick post to let people know what I have found out about the 650D.
I had been searching for a replacement for my aging 550D (over 100,000 clicks on it) to use with my EF-S 17-55 2.8 IS lens.
Anyway, I purchased a 650D (body only) and have been doing some quick comparisons.
I shot some images at ISO 6400 in RAW and processed in Lightroom 4.1, using Topaz Denoise for NR and downsampled to 8MP files (3600 x 2400) - that's enough for an 8 x 12 print at 300 DPI.
Canon have not used a new sensor. It appears to be the same as in the 550D, 600D, and 60D. I have owned and shot extensively with both the 60D and the 7D as well - though not the 600D.
The first thing to note is that if High ISO NR is enabled on the 650D - it seems to affect RAW files as well. Something is being done in camera and if you process RAW you will end up with a worse result by enabling high ISO NR (loss of detail). So if shooting RAW make sure you turn off high ISO NR.
You cannot tell the results of either camera apart.
How are the results at ISO 6400? Remarkably good but it depends on the subject. Dark areas show magenta patches after NR which cannot be dealt with. If the image only contains light areas - these are not visible. We should keep in mind that ISO 6400 really is pushing an APS-C camera so it is actually quite good. I haven't had time and was only checking the limits so to speak, but I would guess that ISO 3200 would not suffer from this issue (there are no intermediate steps).
How does the 650D differ from the 550D?
Bottom line.
For me, as I process RAW, the image quality remains the same across the 550D, 600D, 60D, 650D, (I feel that these four are better image quality wise than the 7D). The additional range of ISO's you get on the 650D really aren't intended for normal use (the auto ISO functions max ISO is 6400) and are just more image processing by the DIGIC 5. I don't think they'll give you results that are usable.
The hybrid live-view AF however is ground breaking. Liveview AF has suddenly become much more usable. (for static subjects)
Out of the 550D, 600D, 60D and 650D - the new hybrid AF makes the 650D my choice. I prefer it over the 60D which apart from a slightly higher frame rate/burst has little else going for it over this. (Canon dropped the pro features that the 50D had like AF micro-adjust, N3 terminal etc.)
Hope this is useful.
- AF with the center point is not any more or less accurate than the 550D. With the 17-55 2.8 IS USM, it is extremely fast, but not completely accurate all the time. The lack of AF micro-adjustment will be an issue for faster lenses.
- the big improvement is in the liveview AF which uses the sensor's new built in PDAF to get you into the 'zone' with CDAF fine-tuning it to give you much faster and accurate liveview focus. It is extremely fast. (The CDAF portion is also probably helped by the DIGIC 5)
- there is a new continuous focus option for liveview which is also interesting - though probably more interesting for people doing video.
- everything on the 650D (owing to the new processor) is faster than the other cameras.
- the swivel display is extremely nice and I am sure that some will appreciate the touch screen (which allows you to select the AF area in liveview)
Bottom line.
