What is your favourite trick?
Started Aug 19, 2004 | Discussions
david casius
david casius Contributing Member • Posts: 597
good to know (nt)
Julio wrote:
Easy, realistic skin smoothing:
1. Channel mixer adjustment layer - just click ok without any
changes - set mode to luminosity and reopen the adjustment layer.
2. Clheck monochrome; red 70%, Green 25% Blue 0% (total=95%)
3. On the channel mixer mask use a black brush to remove the effect
from the eyes, lips and any other areas you want .
Conversely... If you want to deliberately coarsen... make the
adjustment in step 2 be Red 0%, Green 35%, Blue 70% (total=105%)
Here's an example - nothing done to raw conversion other than the
steps above and cropping:
Dave
N.i.k.o.n D.1.0.0
N.i.k.o.n C.o.o.l.P.i.x 4.3.0.0
O.l.y.m.p.u.s C.5.0.z
C.a.n.o.n A.E.1 P.r.o.g.r.a.m
Mac G4 Dual 1Ghz Digital Dark Room!
 david casius's gear list:david casius's gear list
Nikon D100 Nikon D90 Nikon D7000 Nikon D7100 Nikon D600 +17 more
Stinson
Stinson Veteran Member • Posts: 3,843
Animal Shots - Eyes with Emotions
Select Eyes and place on new layer or duplicate layer and set a mask to reveal eyes only. On new layer, set to screen and adjust opacity to taste.
See my site on this here.
http://stinson.smugmug.com/gallery/211419
View it in journal mode (upper right side dropdown under style).
French connection wrote:
Hello all!
What is your favourite ttrick to enhance pics in one or two (max
3steps) in PS?
 Stinson's gear list:Stinson's gear list
Nikon Z5 Nikon Z 24-200mm F4-6.3 VR Nikon Z 35mm F1.8 Olympus TG-5 Nikon D7000 +1 more
Stinson
Thanks that's an enhancement
Thi Tran wrote:
In PS7, I use the following steps sometines in order to fix color
cast:
. Select "Curves"
. Select "Options"
. Select "Find Dark & Light Colors", and "Snap Neutral Midtones"
The following helps this trick when I am not happy with the results from my standard settings.
If you not happy yet with the Shadows & Highlights, select the
appropriate box then use the color picker or just move the little
circle to where the ideal color for Shadows & Highlights
Thi
Hello all!
3steps) in PS?
Glenn Barber Veteran Member • Posts: 3,464
Re: bookmark (nt)
Hello all!
3steps) in PS?
 Glenn Barber's gear list:Glenn Barber's gear list
Sony a6500 Sony a7R IV Sony a6600 Sony FE 35mm F2.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +12 more
Stinson
Yo Danny isn't
that just because adjustment layers are created with masks that start out white and can then be painted like a regular layer mask?
dannyraphael wrote:
Hi Isabel:
Thanks for asking. If it wasn't quite clear to you, it probably
wasn't for other folks.
Painting B or W on adjustment layers works the same way as it does
on layer masks added to regular layers. In this case no layer masks
are involved...just the adjustment layers themselves, which are
added above the target layer(s).
Try this extreme example:
  • Add a Hue/Sat adjustment layer above any color Background
  • Set Saturation to -100 and close the dialog
  • Set foreground color to black and choose a hard edged brush
  • Flow = 100%, Opacity = 100%
  • Where you paint black on the adjustment layer the effect is
suppressed
revealing the color from the BG below
  • Ctrl + I to invert the mask
  • Ctrl + I again to put it back the way it was
  • Switch to white and paint to "undo"
Black and white are the extremes (100% conceal or 100% reveal). By
airbrushing black on a white mask or white on black mask results in
various degrees of gray (somewhere in between B/W) for controlled
applicaiton.
Does this help?
Danny
Isabel Cutler wrote:
Good observation Danny...are you talking below of a layer mask or a
selection? I assume layer mask.
Isabel
dannyraphael wrote:
Great thread. Great idea. I don't believe I read this one among
this collection.
It's not unusual for an image to need color or toning adjustments
in specific areas, not overall. This is my I approach to these
situations:
  • Add the appropriate adjustment layer (Levels, Curves, Hue/Sat, etc.)
  • Apply the adjustment to correct/enhance the areas that need it.
(This
usually results in messing up areas that don't need fixing.)
  • Ctrl + I (to invert the mask and "undo" the effect)
  • Airbrush with white in desired areas to (again) reveal the
adjustment
layer's effect. Airbrushing allows you to control the degree of
application depending on need. (Paint black to "undo" if you overdo
it.) You can fine tune by tweaking the adjustment layer's opacity
or trying different layer blend modes.
Danny
Kent C Forum Pro • Posts: 25,803
Re: Yo Danny isn't
They have an added mask by default, however with a regular layer mask you can click on the layer (not the mask) and use the brush tool in a 'regular' way. Not so with an adjustment layer - all brush strokes are confined to the mask.
Kent
http://www.pbase.com/kentc
jfriend00 Forum Pro • Posts: 13,094
Wow, works like a charm to warm up the color on a flat photo
This one works like a charm. I just tried it on a dreary low saturation photo taken on a foggy day and it worked great. Really warmed up the color. Thanks for the tip.
parikh wrote:
This is to enhance the colors of the image especially taken with
low to mid end digital cameras, generally suffering from poor color
saturation.
Typical adj. layer with hue/saturation would result in ugly
artifacts. This method might be a better alternative.
duplicate background> select the copy> image> adjustment> hue and
saturation> increase the saturation to around 60-70 (image will
look to be absolutely thrashy)> go to filter> noise> median(select
around 6 )> filter> blur> gausssian blur(select around 4)> set the
blend mode to color> dial the opacity as per the liking.
Enriches the colors in otherwise bland images without the
accompanying artifacts.
cheers,
parikh
 jfriend00's gear list:jfriend00's gear list
Nikon D750 Nikon Z7 II Tamron 15-30mm F2.8 Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR +2 more
Marly Contributing Member • Posts: 877
book mark n/m
Francis Tapia wrote:
Marly
Isabel Cutler Forum Pro • Posts: 11,174
I tried it Parikh! What do you think?.....
Thank you for sharing this trick. Tell me, did I overdo?
Before your technique:
After:
Isabel
http://www.pbase.com/isabel95
http://groups.yahoo.com/group/Digipets
dannyraphael Veteran Member • Posts: 3,494
question - Re: one more if permitted
saturation.
select the copy
image> adjustment> hue and saturation
increase the saturation to around 60-70 (image will look to be absolutely thrashy)
filter > noise > median (select around 6)
filter > blur > gausssian blur (select around 4)
set the blend mode to color
This enriches the colors in otherwise bland images without the
Interesting technique...
So you need both Noise > Median & Blur > Gaussian blur?
Re: Yo Danny isn't
Yep. Sure is.
You're on top of your game as usual.
snapper25 Forum Member • Posts: 90
Re: Feivel,
Not to question the master, but just going to the "hill" would lose all of the highlight and shadow detail, as in the clouds and the trees? Would it be better to move the center slider so that the detail is kept?
Of course, it depends whether you keep the foothills or not.
DianeR wrote:
Your little trick uncovered a rainbow that I didn't know was there
at the time of the shot! Thanks!
Hello all!
3steps) in PS?
go to levels
bring left and right triangles in until they meet the "hill" of the
histogram
then
go to unsharp mask
amount 15
radius 30
threshold zero
D Juan Hundred Senior Member • Posts: 1,364
2 more
Toggle through the blending modes
Hold the shift key down and hit the "+" key
Color correction for PS CS
Duplicate background
Filter> blur> average
Image> Adjustments> Invert
Change blending mode to "color"
Change opacity to about 50%
Add saturation with Hue/Sat adjustment layer
Henry W Regular Member • Posts: 440
Re: Feivel,
feivel is correct unless you move the outer sliders up the hill. By definition there are no values at the base line and therefore nothing to lose.
Henry
detail is kept?
Hello all!
3steps) in PS?
go to levels
histogram
then
go to unsharp mask
amount 15
radius 30
threshold zero
 Henry W's gear list:Henry W's gear list
Canon PowerShot SX60 HS Olympus Tough TG-4 Olympus Stylus Tough TG-850 iHS Canon EOS 5D Mark II +1 more
feivel Forum Pro • Posts: 10,168
Re: Feivel,
henry's right
im talking about the type of situation found here
http://forums.dpreview.com/forums/read.asp?forum=1006&message=10121996
in a case like this you would lose zero shadow and highlight detail.
of course every situation is different
and there could be some small footlills that are important
you can hold the alt key while you move the triangles and the lost detail areas will be highlighted
feivel
Bernd Taeger Senior Member • Posts: 2,389
Re: 2 more
Nice one, but caution:
Toggling will fill in history pallette and push other corrections outside the history stack.
Bernd Taeger
Bob Quinn Senior Member • Posts: 2,206
Re: 2 more
Bernd,
I have PS7, I don't see it affecting history. But maybe it does in CS.
Bob
Yes it does
Bob,
Bernd is right (with CS, at least). Since I don't use the history much, I never noticed. And, if you don't know what blend mode to use, as I normally don't, it helps me to decide.
Gary
Bob Quinn wrote:
Bernd,
CS.
Bob
mandrake Regular Member • Posts: 285
Re: Feivel,
feivel wrote:
henry's right
You could just do 'Auto-Contrast' in PhotoShop and this would be exactly the same thing (provided you had clipping set to zero for both the white- and black-points).
http://www.pbase.com/dkusner
Re: Feivel,
you could
you could also do auto levels
you could also move the ends of the line in curves to the right and left
theres lots of ways to do any one thing in ps
the problem with autocontrast is that you cant watch the picture or the clipping display (when holding the alt key) if there are important pixels before the "hill"
