What is your favourite trick?
Started Aug 19, 2004 | Discussions
French connection Senior Member • Posts: 1,053
Hello all!
What is your favourite ttrick to enhance pics in one or two (max 3steps) in PS?
feivel Forum Pro • Posts: 10,168
Re: What is your favourite trick?
French connection wrote:
Hello all!
3steps) in PS?
go to levels
bring left and right triangles in until they meet the "hill" of the histogram
then
go to unsharp mask
amount 15
radius 30
threshold zero
D Juan Hundred Senior Member • Posts: 1,364
Go to DPreview
Click on "New Thread"
Key in: "feivel, how do I do this?"
Hello all!
3steps) in PS?
cspringer Forum Pro • Posts: 19,632
My favorite trick is to look for feivel's posts and do what he says.
Hello all!
3steps) in PS?
mandrake Regular Member • Posts: 285
Hello all!
3steps) in PS?
My favorite trick is to saturate colors in a way I particularly like. I use it mostly with outdoor photos, though that's mainly because I primarily take outdoor photos. It generally brings out deeper blues in the sky and warmer tones in things that need them.
Take your image and make a duplicate layer of it. Use the 'Apply Image' tool in PhotoShop CS (Image-> Apply Image... -- you can also probably use Calculations or just do it manually with layers if you know what you're doing, but it's easy with Apply Image). What you want to do is blend in an inverted blue channel in hard mix mode.
In the Apply Image Dialog, choose Channel: Blue, click Invert, Blending: Hard Mix. At 100% opacity this will show you the colors you will be superimposing on your photo. Now bring the opacity down to 15-25% to see the effect. Sometimes the green channel is a better choice than blue.
fantastipotamus Regular Member • Posts: 107
thanks
Just tried out that trick on some of my landscapes, I really like the effect. Thanks for the tip!
Hello all!
3steps) in PS?
Brian Randall Senior Member • Posts: 2,925
Hello all!
3steps) in PS?
French Connection,
Heck, I could not answer this in 2 or 3 steps. It takes me at least 6 big steps just to get TOO the computer. Then I have to open the lid, turn it on, sign on, open my email's first, then check CNN.com, then check GirlsGoneWild.....oops, wasn't suppose to say that one. Then I go into DPReview to find something to work on or help with. Argue with D123, or Fibel, or anybody else that wants to argue, THEN I open Photoshop. So, I am way beyond 2-3 steps already.
Byron
Brian Randall Photography
http://www.pbase.com/brw_2909
Kent C Forum Pro • Posts: 25,803
Hello all!
3steps) in PS?
small 's' curve in Curves; Hue/sat - saturation +10 to 20.
Kent
http://www.pbase.com/kentc
James Kay Senior Member • Posts: 1,405
Very Cool! Thanks NT
Hello all!
3steps) in PS?
Dan T Regular Member • Posts: 391
Good trick Feivel....
I just tried it on a couple of my photos. Quick, easy and effective!
Another good one...
I just tried it on a landscape. I like it. Thanks! Keep them coming!
Cricketb Senior Member • Posts: 1,483
My favorite trick right now is running impressionist twice and setting the top layer to overlay.
Also any of Mike Finn's actions
( http://homepages.slingshot.co.nz/~mikefinn/action.html )
are great for a quick and dramatic change.
Cricket
http://www.casmaran.com/
Photoshop tutorials and links.
Digital/photo art forums at: http://casmaran.com/forum/index.php
Mr. Jalapeno Contributing Member • Posts: 970
A good, healthy...crop!
Tonality ('S') Curve
http://www.luminous-landscape.com/tutorials/command_primer.shtml
Fred Miranda's Digital Velvia.
http://www.fredmiranda.com/shopping/DV
gill Senior Member • Posts: 1,049
great thread, keep posting nt
Gill
WSSA#28
CP 4500, TCE2, WC-E63
http://www.bytephoto.com
webdivauk Regular Member • Posts: 318
Re: psp7?
I'm using PSP7 is there anything I can use instead of hard mix?
Canon 300d D-Rebel / Canon A80 / Kodak DX4900
http://www.webdiva.co.uk/blog/
http://www.webdiva.co.uk/photoblog/
http://www.pbase.com/webdivauk/
Doug Morgan Veteran Member • Posts: 4,435
I have 2 that I use all the time, both of which I picked up from someone else:
USM for contrast 25-30, 50-60, 0 Can be used in combo with "S" curves.
To tone down or eliminate USM side effects:
Double click seperate USM layer to bring up layer properties
Set mode to luminosity
Hold down alt(Windows) and drag/split white highlight triangle under "this layer" for the blend if sliders.
Set the left side to between 120-180 and the right side to 200-240 to eliminate or reduce highlight side effects from heavy sharpening of high contrast edges.
The other hints are great!
Doug
DianeR Veteran Member • Posts: 5,323
Feivel,
Your little trick uncovered a rainbow that I didn't know was there at the time of the shot! Thanks!
Hello all!
3steps) in PS?
go to levels
histogram
then
go to unsharp mask
amount 15
radius 30
threshold zero
Thi Tran Forum Member • Posts: 78
In PS7, I use the following steps sometines in order to fix color cast:
. Select "Curves"
. Select "Options"
. Select "Find Dark & Light Colors", and "Snap Neutral Midtones"
. If you not happy yet with the Shadows & Highlights, select the appropriate box then use the color picker or just move the little circle to where the ideal color for Shadows & Highlights
Thi
Hello all!
3steps) in PS?
cast:
. Select "Curves"
. Select "Options"
Actually, this is a way to tweak the algorithms of 'Auto Color'. To complete the tweak, I set the shadow/highlight clips both to '0.10%'. A great way to get better results with this underappreciated tool!
Max Savoie Forum Member • Posts: 90
Please more, more I want more tricks !!! (nt)
Mr. Jalapeno wrote:
cast:
. Select "Curves"
. Select "Options"
Yes I'm still a newbie but I love this camera
One day I will shoot in manual mode
Sorry english is not my native language
