Which WB setting for halogen lights!
Started Jul 9, 2004 | Discussions
digital addict Regular Member • Posts: 107
Hi. What is the best white balance setting for shooting under halogen lights without a flash? Is this lighting similar to tungsten or a little different? The area I'm shooting is a rink so it's pretty large and fairly dark.
Ray Chen Veteran Member • Posts: 9,652
custom WB?
Read up on the manual if you don't already know how to do custom WB. You may also try to shoot RAW and adjust the WB later.
Ray Chen
You Gotta Be In It To Shoot It!
 Ray Chen's gear list:Ray Chen's gear list
Canon EF 40mm f/2.8 STM
blueuser Contributing Member • Posts: 518
Re: Which WB setting for halogen lights!
Halogen is a little bit colder than ordinary tungsten like normal used in homes. Thats due to the colortemperature which is 3600K from halogen compared to 3000K to 3200K from a 60W - 100W bulb.
If you are in hurry, use the tungsten setting. If you have time or are in doubts make a custom WB with a piece of white paper
Jordan Robbins Senior Member • Posts: 1,702
Always custom wb if possible... even with raw...
Always custom wb if possible... it will give you the most accurate results. Even if you use raw using a custom wb will give you a much more accurate starting point when adjusting it to fit your taste. Once you get used to using it its pretty simple and becomes 2nd nature... the only time it may get annoying is if the lighting changes frequently.
-Jordan
-Jordan
OP digital addict Regular Member • Posts: 107
Re: Always custom wb if possible... even with raw...
I'm actually shooting at a roller skating rink. The lights are placed 3 across the rink side ways and about 7 down it's length. There are dark spots and there are light spots on the floor. So I guess the light conditions would change in that situation depending on where I was aiming whilst shooting?
changes frequently.
-Jordan
dougsmit
dougsmit Senior Member • Posts: 1,366
You should be OK with a single custom WB setting as long as all the spaced lights are the same type. The exposure will vary between the light and dark areas but the balance should hold pretty well (certainly correctable in postprocessing). The problem would be if the likes were covered with color filters so there were blue and red patches on the rink. That would make it a situation where you can't keep up and RAW would be the only answer.
 dougsmit's gear list:dougsmit's gear list
Canon EOS RP Canon EOS R7 Canon EF 50mm F1.8 II Canon EF 70-200mm F4L USM Canon EF 100mm f/2.8 Macro USM +6 more
there are no covers over the lights. The floor has a real yellow tinge to it and the back wall to the rink is yellow and orange so I was expecting the photos to look a little yellow. The brownish stockings don't help either. Here is a sample. See what you suggest.
David Barker Senior Member • Posts: 2,966
Is the "Peters" sign white? (nt)
[snip]...Here is a sample. See what you suggest.
DB
Re: Is the "Peters" sign white? (nt)
Yes, the Peters sign is supposed to be white lettering. green surround!
How id you custom white balance? If the lettering is supposed to be white it seemks like it is still off. I usually use my expodisc which I find to be the easiest method but by no means the only one. If you used a grey card was the grey card picture taken under the same lighting as the subject? Was the white balance then manually set through the menu (in the past a number of posters didnt know that this needs to be done). Otherwise its possible that the rink may have used different bulbs without you realizing it making it a mixed lighting situation.
-Jordan
surround!
-Jordan
well, to be honest i just used a white sheet of paper! yes, i was under the same lighting and I'm pretty sure there was no other type of lighting. custom white balance is something i haven't mastered yet i don't think?
-Jordan
surround!
jimcreative Senior Member • Posts: 2,584
Many typical household lightbulbs come in more around 2400-2800K. Photographic halogen lights are supposed to be 3200K but there will be some variation. I have been using color temperature meters for about 18 years and I have yet to meter an incandescent bulb of any variety that is more than 3350.
If the original poster is referring to houseshold halogen bulbs such as those found in low voltage fixtures then there is an additional factor to consider. The reflectors for the MR-16 bulbs are somewhat dichroic, meaning that the reflected light will have the color shifted in some manner. Some shift to green/yellow while others might go a little red/magenta.
All that said, use a custom WB and shoot in RAW so that it can be easily fine tuned without creating any ugly mismatches between shadow/highlight.
C5Driver Regular Member • Posts: 302
Just a thought...
Are you sure they are halogens?
Is it possible that they are using Mercury vapor or metal halide lighting. Any thoughts?
-Ron
Suggestion sample
I have tried to play a little bit with you picture with levels in PSCS
It was a little bit difficult because I haven't seen it by myself
The Big Bad Veteran Member • Posts: 4,108
just shot a raw shot and adjust it til it looks right, and thats your answer
Just shoot a raw image and then adjust the WB slider til you think it looks good to your eyes. Whatever the temp is, thats what you want to set at
Better yet, id say shoot them all raw and adjust the keepers as needed. Some shots with the players up close, I like a little warmer look for skin tones and uniforms, other shots I like a cooler look to give a bit of a colder feel to the ice. I find it to be real subjective personally
http://www.pbase.com/bigbad
LeeBase Veteran Member • Posts: 5,413
Here here -- even when shooting RAW, it helps to get a good custom wb.
Use a grey card or an expodisc if you care about colors.
If "close enough" is close enough -- then use a pringles lid or white coffee filters when setting the wb.
White piece of paper -- ok...if "close enough" is too accurate (kidding, I just don't think white papers are very good)
Lee
changes frequently.
-Jordan
Bill McKelvie Contributing Member • Posts: 893
Halogen lamps are acyualy in the 3000-3200K range. Domestic tungsten is about 2700-2900, with 60W bulbs being toward the lower end of this.
Your Tungsten position on tour camera is actually for halogen lamps - domestic tungsten will give an orangeish cast at this setting.
A custom ehite balance is always best.
Bill.
In that case I think your lights are high pressure sdium, not tungsten - custom white balance is definitely your best option.
Bill.
Asim1
Asim1 Junior Member • Posts: 42
Hello everyone. I have question which makes me curious.
If I shoot a picture with halogen bulb which has yellowish tone then correct its white balance in Raw settings.
Then If I take another picture with the same setup but this time with very natural white light that doesn't need any correction.
my question is do the both images will look like same or similar in color reproduction? or the manually corrected version would have a lesser color quality?
 Asim1's gear list:Asim1's gear list
Canon PowerShot A630 Canon PowerShot A710 IS Sony a6100 Sony E 16-50mm F3.5-5.6 PZ OSS
guinness2
guinness2 Veteran Member • Posts: 4,617
Hi guys ,  does the following answer make sense to you ?
The best white balance setting for shooting under halogen lights without a flash is "tungsten" or "incandescent" setting. Halogen lights are similar to tungsten lights, as they both emit a warm, yellow-orange light. Using the "tungsten" setting will help to neutralize the yellow-orange cast and give your photos a more natural color balance. If you have the option, it would be best to use a manual white balance, to fine-tune the settings according to your preference. For large and fairly dark areas like rink, it would be best to use a tripod, or a high shutter speed to avoid camera shake.
I appreciate your feedback.
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
