Whoops! Where's Adobe Gamma gone??
Started Jul 2, 2004 | Discussions
Barrie Davis
Barrie Davis Forum Pro • Posts: 21,460
I hope someone can help me??
My image editor of principle use is now Adobe's Photoshop CS, but until recently I still had Elements 1 on my system, a hangover from an earlier time.
To make room on the HD I removed Elements about two weeks ago... and now I cannot find Adobe Gamma in my Control Panels. Presumably de-installing Elements has removed it from the system.
Is there any way I can get it back, WITHOUT re-installing the whole of Elements?
I am also particularly unkeen to re-install PS CS, and get Adobe Gamma back that way, because of the irksome (infernal?) activation issue.
Any help would be appreciated.
Baz
 Barrie Davis's gear list:Barrie Davis's gear list
Konica Minolta DiMAGE A2
JJMacks
JJMacks Forum Pro • Posts: 10,570
Re: Whoops! Where's Adobe Gamma gone??
Barrie
It is most likely still on your system but when you un-installed elements a registry entry was removed. Look for "C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma.cpl"you can start it from there you should also see the loader in that directory. Had a Problem like this when I un-installed PS 7. The un-install also broke PS CS droplet function. I had to re-install PS 7 and PS CS and wipe out PS 7 without un-installing it to get everything working again.
JJMack
 JJMacks's gear list:JJMacks's gear list
Canon EOS-1D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/2.8L IS USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/2.8L IS USM +3 more
Barrie Davis
OP Barrie Davis Forum Pro • Posts: 21,460
Such prompt and accurate help...
JJMacks wrote:
Barrie
working again.
JJMack
Thanks JJ,
You are quite right, and I went straight to it. Ta muchly!
Hmmm... It aint exactly 'slick' but it is workable......
Thanks again for your kind attention.
Baz
