G1 Flash Photograph 101
Started May 21, 2001 | Discussions
Michael w Regular Member • Posts: 487
Evidently many people still don't understand the issues about manual flash that Peter T., myself and a few others tried to explain in the "Canon's attitude" thread. This post is dedicated to EXPLAIN the situation. If you know for fact anything I say is technically wrong then correct me. I'm not solicity opinion on this thread. If after reading this you want to further express you opinion on the issue then please go to the "Canon's Attitude" thread. I'm going to get pretty basic, so don't feel insulted if some of the things I say are too fundamental. Thank you very much.
1. Universal Manual Flash Basic:
To set exposure for a manual direct flash, one typically use the basic rule:
a. Set shutter at or slower than maximum synch speed supported by the camera. G1 manual specifies 1/125 second.
b. Set apperture to: Ap = GN / distance. For example to shoot an object at 30 ft away at ISO 50 using a flash with Guide Number of 80 ft @ ISO 50, set apperture to 4.0. Note that guide number is dependent on ISO setting, so you must ensure to use the correct GN. In manual flash the camera does not attempt to adjust intensity of the flash, it simply tells the flash to fire at full strength. A manual flash rated at 120 ft GN if set at 1/4 power ratio will act like a a 60 ft GN flash.
c. Both ambience light and the flash light will affect the exposure. It is the photographer's responsibility to account for ambience light and make adjustment to get perfect exposure.
d. Adjustment rule: higher apperture number will reduce the exposure of both flash light and ambience light, thus at f5.6 you would expect the picture to be 1 stop DARKER than at f4.0 and so on so forth. Adjustment of speed (within specified maximum synch) only affect the ambience light and not the flash light because the entire flash duration always occurs while the camera aperture is open at the specified setting. Flash duration is typically between 1ms to 2 ms (1/1000 to 1/500 seconds).
c. Bounce flash is less straight forward, but the same rule of adjustment is the same: f5.6 is to be darker than f4.0, f4.0 is to be dark0er than f2.8, so on so forth.
2. What Happens to Manual Flash with G1?
If you shoot with a Canon 420EX or 550EX, everything happens as described above. When you put ANY standard non-Canon strobe on it this happens: the flash will fire shortly BEFORE the aperture stabilizes at the intended aperture. For example, if you set the camera to f5.6 at 1/125 the actual aperture goes through a very brief transition phase before the aperture actually stabilizes at f5.6. During this transition phase the aperture can be any value, be it f2.0 or whatever. What happens is that the G1 will fire your non-Canon flash during this transition phase in stead of waiting until the aperture reaches the intended value. Yet, somehow it manages to do the right thing whenever an EX flash is mounted on. Selective wrong doing!
3. E-TTL and Standard 3rd-party Flashes
E-TTL does not support 3rd-party flashes. The G1 and other Canon cameras are designed to NEVER activate E-TTL unless an EX flash is detected. So no relationship exists between E-TTL and standard manual flashes. No photographer in the right mind would expect the camera to adjust exposure for him/her while taking a manual flash shot with a manual flash unit.
4. G1 Supports E-TTL, why bother with manual flashes?
E-TTL is simply a form of automatic exposure in flash mode. As with any automatic exposure system, it cannot produce good results in all lighting conditions such as shooting against back-lit scenes and difficult flash fill situations. For some one who don't want to deal with the complexity of manual flash photography it E-TTL makes perfect sense. But if one know enough about flash photography that he/she can consistently achieve better results using manual flash techniques, why bother?
5. The 380EX and 420EX will fire in manual mode, why not use it?
Neither of these allows ratio down, making manual flash impractical. A good manual flash would allow ratio down to 1/2, 1/4, 1/8, 1/16, etc.
6. 550EX fully supports manual flash, why not use it?
If the price is the same as my Sunpak 383 ($69), this would have been a valid question.
Michael
--Michael
OP Michael w Regular Member • Posts: 487
Re: G1 Flash Photograph 101
Oops, excuse my typing, I meant to type 20 ft and not 30 ft.
Michael
basic rule:
Michael
euthon New Member • Posts: 21
My experience is different from yours. So, either not all G1's exhibit this behavior or not all manual flashes are equal.
I just run a quick and dirty test and here are the results:
Equipment:
  • Flash: Spectrum 370T Auto flash in manual mode, bounced off the ceilling to prevent gross overexposure, plugged into the hot shoe.
  • Camera: Canon Powershot G1, updated firmware, zoom set at its longest, 1/125 shutter speed, manual focus, on a tripod, ISO 50, RAW mode.
  • Target: 8x10" gray card, about 4 feet from the camera.
I shot the card at f/2.8, 4.0, 5.6, 8.0 and exported images into Photoshop. Below are averaged RGB values for each shot:
f/2.8 -- R: 199, G: 190, B: 172
f/4.0 -- R: 125, G: 117, B: 103
f/5.6 -- R: 111, G: 106, B: 92
f/8.0 -- R: 23, G: 22, B: 20
White balance was set to "flash".
I repeated the test several times and the results were pretty consistent.
I can definitely see the problem you describe around f/4 - f/5.6, but it's not nearly as bad as in your case. The problem can be solved easily and cheaply: slave your manual flashes optically.
euthon
Peter T Senior Member • Posts: 1,272
I can't translate your numbers into anything I understand. You say you see the problem but it's not that bad. How bad is it?
What method do you suggest for optical slaving?
Explanation
The numbers suggest that stopping the aperture down from f/4.0 to f/5.6 has no effect on the exposure. Other aperture settings work as expected.
It depends. It is bad enough to make flashmeters unusable. On the other hand, if you are using a G1 in a studio and judge the results by histograms -- you may not notice it.
Cheap optical slaves are available for under $25, trigger them with the built-in flash.
euthon
Re: Explanation
the built-in flash.
My flash has a built-in optical slave. But triggering it with the built-in flash at full-strength is not feasible. If you could reduce the output of the flash it might be ok, but you can't do that in manual mode.
Wein makes a product that fits over the camera's flash. It blocks the flash light from influencing your exposure and uses the flash as a trigger. If this was connected to a sync cord it would be a great solution. But it's meant to work with their wireless slave system, so the total solution ends up costing at least $300.
Re: Explanation
For $300 i can think of a better solution: get a 550EX and use it just to trigger your slaves.
On a more serious note, just cover that built-in flash with an IR filter. Only invisible IR light will get through and trip the slaves. A piece of unexposed, but developed slide film will do just fine.
euthon
Re: Explanation
Interesting. So I would buy a roll of slide film and just have it processed without shooting it? I guess I would have to tell the processor not to mount the slides?
For anyone reading this thread that doesn't have a flash with a built-in optical salve, Wein makes a Peanut slave that sells for about $15.
Shaam Shilome Regular Member • Posts: 150
I have a quick but may sound like a dumb question.....Is there any other way to tell if a G1 is overexposed or underexposed other than just looking at the picture?....How does one really know for sure what the real sweet spot of a perfectly exposed picture?...whether it be a portrait, a landscape...ect.?
Other than just visualizing it ...what other ways can I determine whether or not an image is correctly exposed....I'm not just reffering to Flash shots but mainly outdoor shots.....I'm sorry if this sounds like a dumb question but i am finally venturing out of full auto mode on my G1 and want to try manual mode.
thanks!
Equipment:
RAW mode.
consistent.
euthon
...what other ways can I determine whether or not an image is correctly > exposed....
You'll need to export the picture into Photoshop (or other editor) and look at the histogram. It will tell you the whole story. Search for a tutorial on histograms.
Unfortunately, the G1 (unlike the CP990) cannot dispaly histograms on its own.
euthon
kevin Regular Member • Posts: 166
so, i can't afford the 550ex, but, i can get roughly the equivalent (from a G1 perspective) functionality from a 420ex + a Sunpak 383?
.kevin
http://www01.bhphotovideo.com/default.sph/FrameWork.class?FNC=ProductActivator__Aproductlist_html___52799___SU383S___REG___SID=E6D308FA630
Michael
BryanS Veteran Member • Posts: 4,104
This rant isn't logical
I'm seriously trying to be patient with this rant, but it always falls apart on me when I try to think it out logically.
You buy a new digicam for nearly $900 (or $800 if you manage a good deal). Add another $100 at least for a decent compact flash or maybe $400-500 for a microdrive. Spend some other bucks for maybe the LensMate and some filters.
And we're quibbling because we can't add a $50 flash?
Funny... just for kicks, I bought the little Sunpak digicam flash with the built in slave for maybe $35 (even came with a little tripod), though I have the 420EX. It has a built in slave, and I set the G1 for flash compensation to the absolute lowest setting (just enough to fire the slave). This combination works perfectly for me, but maybe I'm doing something wrong.
I guess I should be stomping my feet and shaking my finger at Canon. Silly me for being busy taking pictures instead.
Bryan
basic rule:
Michael
Richard Contributing Member • Posts: 924
Re: Explanation
Peter,
Does the Wein Peanut fire on the first or second flash? If it fires on the first flash it would not be suitable for use with digital cameras, or any other camera that adjusts it's final flash output on the measurement of a pre-exposure flash. This would solve a number of problems for me if it works...
rhb
about $15.
Re: Explanation
There is no preflash in manual mode.
euthon
Re: This rant isn't logical
Bryan,
Where did you buy the Sunpak? And what model is it? I have a "scrim" panel from my old theater days that I would like to use as a diffusion panel for a slave flash, and this sounds like something I could really use.
rhb
Re: Explanation
Thanks for replying, Euthon--
I know this-- I'm working in other modes as well, so the Wein Peanut would be useful for me if it works with a pre-flash...
rhb
euthon
There was some special when I bought mine, so it's a tad more expensive now. But here's where I got mine:
http://www.wolfcamera.com/1-800-643-9653/home_product.asp?menu=search&ProductID=61235
Enjoy!
Bryan
Richard wrote:
Bryan,
I could really use.
Phil H Junior Member • Posts: 46
I prefer to call it a logical complaint
Bryan,
This is an acceptable work-around for use with off-camera flash - I've used it many times myself. It doesn't solve the problem for portable on-camera flash use. The point is that the problem needs a cure, not a band aid.
Phil H
Bryan
basic rule:
Michael
Thanks, Bryan-- I'll order pretty soon. My goal is to use the ST-E2 trigger to set off the 420 EX and have it set off a slave on the other side or behind the subject, cranked down to 1/2 or 1/4 strength. I'll tell you how it goes...
rhb
Enjoy!
Bryan
Richard wrote:
Bryan,
I could really use.
