A1 RAW failure, or what?
Started Apr 18, 2004 | Discussions
Don Dement Contributing Member • Posts: 590
My A1 won't produce RAW image files, suddenly. I'm using RawDeal and ThumbsPlus 6 Pro, both of which recently opened .MRW Raw files. Now I get almost totally white screen with random color dots in RawDeal and a regular color pattern like tweed cloth in T+. The .THM files are opened in RawDeal and show that the camera functioned well in other respects, and all other recording functions such as JPG and TIF work perfectlyl. Changing cards made no difference.
Anyone ever have failures of only RAW file creation? Have I set something inadvertently to kill this? I don't shoot in RAW often so wasn't aware this whatever it is had happened. What's going on ???
 Don Dement's gear list:Don Dement's gear list
Canon EOS 20D Canon EOS 40D Canon EOS 7D Canon EOS 7D Mark II Canon EOS M5 +5 more
Klaudio Senior Member • Posts: 2,525
Re: A1 RAW failure, or what?
Since the thumbnail is created by the camera from the raw data, I suspect the probelm is not in the "creation" of the raw file but on the converter side. Try installing the original Dimage viewer and see what you get.
Claudio
no difference.
OP Don Dement Contributing Member • Posts: 590
Thanks - you're right. DIVU hadn't occurred to me, and it works fine.
Now I wonder why T+ Pro opened D7i MRWs but won't handle A1 MRWs, and the same with RawDeal. I had better get onto their sites and look for upgrages. Things change so fast I think I'm up to date, and I'm not. Thanks again.
Don
see what you get.
Claudio
no difference.
Aaron Bredon Regular Member • Posts: 436
Minolta changed the format of the A1's MRW file. The A1 stores RAW files in packed format (12 bits/pixel rather than 16 on the 7/7i/7Hi)
José Martins Forum Member • Posts: 80
Minolta A1 Raw files are different from the previous Minolta Cameras.
You need to update your software.
Thanks all for this info. I will look into updating.
Photog74 Regular Member • Posts: 447
I used RAW Deal quite a bit when I was shooting with the MinoltaDiMAGE A1, but I can’t seem to find the software now - do you know if it’s still available to download (and if so, point me in the right direction)?
 Photog74's gear list:Photog74's gear list
Nikon D7000
