Fred Miranda Plugins....with PS CS & C1 SE
Started Mar 3, 2004 | Discussions
Mikey's_World Contributing Member • Posts: 817
Hi All,
I currently have PS CS and Capture 1 SE for Windows (RAW).... Knowing that I have the latter 2 packages, do I need to download FM plugins?? He makes it look easier with the plugins. If I do download them, am I wasting my money and causing duplication already available in the software that I have??
Like to hear from those that have same 2 software packages that I have. Thanks in advance...
Mike
'Get rid of those damn angles! The shortest distance is a straight line.'
Juli Valley Forum Pro • Posts: 54,435
Re: Fred Miranda Plugins....with PS CS & C1 SE
Well, I enjoy Miranda's Intellisharpen and Frames software packages a lot. You probably can achieve the same effects with PS CS but with less ease. Fred's software is certainly not expensive. I bought his programs after having both of the other programs you mentioned.
Kenneth R. Allison Regular Member • Posts: 172
it depends on usage and skill . i have downloaed the digital velvia and found it to worth what i spent . bumping up the saturation never seemed to give the results i wanted . I started my hobby about five years ago i used cheaper neg. film and moved to velvia and astia 100 . i wanted to keep that higher level of saturation so i tried the d-velvia and am quite happy with the results. pick and choose, is what i can tell you.
OP Mikey's_World Contributing Member • Posts: 817
Anyone else??
Also, which FM plugins do you use?? Trying to get an idea of the most used here on this forum. Intellisharpen for sure... How about others?? Keeping in mind that I have PS CS and C1 SE.
Mike
Mikey's_World wrote:
Hi All,
Mike
line.'
Melanie Kipp Forum Pro • Posts: 11,079
I use Intellisharpen Pro most often. Next would be his B&W actions. I have the Digital Velvia one, too, but seldom use it.
Anyone else??
Mike
Hi All,
Mike
line.'
wcbert Contributing Member • Posts: 621
I Use Freds Plugins ...
... DV, WP, SI and Frames. Also I own C1LE and PhotoShop CS. You can do everything that Fred's plugins do in PhotoShop is if you have the time to design your own actions.
Well for sharpening I use Focal Blade, because I think it is better that Fred's, C1LE and PhotoShop. There are people feel that when it comes to sharpening PhotoShop is good enough for them. I disagree. I am causing duplication you bet, but I look for steps to improve my workflow and save me time when it comes to photo editing and that why I use them.
My Two Cents
Bill
davecarrick Regular Member • Posts: 167
Re: I Use Freds Plugins ...
Any action for Photoshop, whether from Fred Miranda, Mike Finn...whomever...simply utilitzes the features and tools already available in the original software. I've been using Photoshop for 14 years, and I find that the use of other people's actions streamlines my workflow and greatly speeds up the post-processing effort. I just don't have the time to experiment on my own. I'm currently using Miranda's Stair Interpolation, Intelligent Sharpening, Shadow Reduction and ISOX Pro (noise reduction plug-in) and find them all to be invaluable. In fact, from the samples I've seen, Miranda's Shadow Reduction action is far superior than the shadow rection filter built in to Photoshop CS. (I'm using Photoshop 7.)
Carrick
10D & Photoshop
Todd Walker Veteran Member • Posts: 6,091
Hi All,
I use Intellisharpen and Digital Velvia and I love both of them. At $12-20 for each action, you really can't go wrong.
 Todd Walker's gear list:Todd Walker's gear list
Panasonic FZ1000 Olympus OM-D E-M5 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +1 more
Ian Byerrum Forum Member • Posts: 69
Has anyone tried the custom 10D sharpener action by FM? (nt)
Hi All,
Mike
line.'
DaveCS Regular Member • Posts: 256
I've been using the soft focus action but now that I finally have a 10D, I'm sure I'll be using the others as well, such as the IntelliSharpen.
DaveCS
 DaveCS's gear list:DaveCS's gear list
Nikon Coolpix A Sony RX100 IV Sony a7R II Sony FE 35mm F1.4 Sony FE 28mm F2
