E-TTL for event photography is a nightmare!!!
Started Feb 28, 2004 | Discussions
Adrian Tung
Adrian Tung Veteran Member • Posts: 3,754
rant on
Just came back from an event... body all sore and muscles aching now, lol...
After today's event, I really, really, really HATE people who wear all white or all black especially if they are VIPs, or worse - some wear black and some wear white. Hmm... that will include weddings now, doesn't it? ooooo.....
Things happen at events quite fast, so sometimes there's no time to watch where the AF point lands, set FEC and then shoot. So sometimes I get some underexposed shots (fine - PS can handle that) and sometimes I get overexposed ones (gaaaahhh!!!!!! blown highlights all over!!!!!). Even though I've practiced setting FEC while peering through the viewfinder, sometimes I forget I turned off the thumb dial because I kept accidentally turning it while my 10D hung around my neck.
rant off
So... anyone want to share their experiences, or chip in some useful advice? :)))
:)atwl
http://www.imageevent.com/atwl77
Canon: E0S-1OD, Can. Z8-13S F3,5-5,6IS U5M, Can. 5Omm F1,8II, Tam. 28-3OOXR, Tam. 9O F2,8 macro, Can. 55OEX
Olympus: C-75OUZ, TC0N-17, WC0N-O7, MC0N-4O, FL-4O
 Adrian Tung's gear list:Adrian Tung's gear list
Sony RX100 III Olympus Stylus Tough TG-870 Sony RX100 VI Olympus PEN-F Panasonic Lumix DC-G9 +18 more
Nugi Contributing Member • Posts: 591
Re: E-TTL for event photography is a nightmare!!!
That is why I sold my 550EX and bought Sunpak PZ5000AF. There is a time when the FEL is impractical and need the auto thrystor instead.
Nugi
10D + 4 L glasses
Need lens comparisons ? See :
http://www.pbase.com/image/22050307/original
Ken Phares Forum Member • Posts: 62
I know exactly what you are talking about. I was use to shooting with a Nikon f5 and SB28 flash. With the nikon you never even had to think about what you were shooting, it just worked very well. I dont think I got 5 bad flash exposures in 5 years. The 10D is very hard to use for event phtotography. My most dificult shots seem to be dance floor photos where there are 2 people and you have to focous on the face and recompose. When you hit the fel button they think that you took the shot and they look away. It gets pretty old explaining to people that dont understand I was just meetering my flash.
I love my 10D, I came from the fuji s1 and s2 where I had many more and other problems.
Adrian Tung wrote:
rant on
now, lol...
rant off
useful advice? :)))
CoalXMan Forum Member • Posts: 98
I was under the impression the sunpak was a much cheaper flashunit
what is the auto thystor your talking about.
Dose the flash connect to the hotshoe,or does it run on batteries, or dose it just drain the camera battery really fast.
Those rare few who have mastered the pixel, can one day wield the
almighty weapons that capture time and space.
Adrian Tung
OP Adrian Tung Veteran Member • Posts: 3,754
my flash.
Exactly why I stopped using FEL for event shoots - it's so annoying!!!
So I employ a bunch of other tricks to work around the E-TTL system such as:
  • switching AF points to get the best one to land on the subject
  • quickly dialing in FEC based on where the AF point lands after recomposing
  • shooting a wider shot to make sure that the AF point lands on a good spot, then crop for composition later
But sometimes, things can happen very quickly (with no time to play around with exposure) and I can only hope for the best... or at least hope that it can be saved in post-processing.
:)atwl
Jeff Peterman
MOD Jeff Peterman Forum Pro • Posts: 12,889
Auto thyristor mode
This type of flash has been around for over 20 years. It has a sensor on the front and it measures the average light reflected back to the flash. You select the distance range you want on the back of the flash, and set the camera to the indicated aperture, and the flash takes care of the exposure.
This works great when your subject fills most of the view seen in the lens, but its problematic when the view is much different, e.g. with a long lens.
Jeff Peterman
Any insults, implied anger, bad grammar and bad spelling, are entirely unintentional. Sorry.
 Jeff Peterman's gear list:Jeff Peterman's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot S110 Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +18 more
Bernie R Swanson Regular Member • Posts: 459
Here is a great link on EOS flash usage
Timley thread Adrian. I have an reception on May first that I am a little concerned about because of flash exposure issues. I have the 10d and a 420EX and a Lumiquest pocket bouncer. I have been struggling with using E-TTL with this set up and my 17-40L or using my old Sunpack auto544 handle mounted flash gun. With that set up, the camera is in manual mode and the flash in Auto mode. I could vary the f stop to adjust for ambient light and the shutter for movement if needed. Do you have a second flash unit like this to try?
Someone gave me a great link to EOS flash photography recently and it is a great read for anyone with a Canon body.
http://photonotes.org/articles/eos-flash/
Adrian Tung wrote:
rant on
now, lol...
rant off
useful advice? :)))
Todd Walker Veteran Member • Posts: 6,091
useful advice? :)))
Sunpak 383 Super. Perfect results almost every time (a much higher percentage than the EX flashes,) for $60.
 Todd Walker's gear list:Todd Walker's gear list
Panasonic FZ1000 Olympus OM-D E-M5 Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +4 more
Robert D. McGee1 Senior Member • Posts: 1,157
A different point of view
Before I comment, I would like to state that I am not making fun of anyone nor am I stating that everything is "easy as pie" with E-TTL Flash.
However, reading these comments, I had a little chuckle. You see, I just received a new book on "Weegee" the great photojournalist of New York in the decade of 1935-1945. "Weegee" used the hot set up of the times, a 4x5 Speed Graphic, set his aperture on f 16 and shot all of his shots using the old, familiar, side mounted flash gun with flash bulbs (looked like 40 watt bulbs). For those unfamiliar with the old flash guns, you had to replace the bulb after each shot. Each bulb was good for one exposure! Weegee had to mostly shoot from a fixed position from his subjects - 10 feet. The disadvantages were obvious but the advantage is he could shoot instantly when he was at the right distance (ten feet) and could "capture the moment".
With all of these equipment limitations, he practically invented tabloid photojournalism.
Get one of his books off Amazon, they are amazingly inexpensive, look at the gritty, underbelly of New York of the time, and realize what great equipment we have with the 10D and 550EX.
Dale53
http://www.pbase.com/dale53
Adrian Tung
Re: Here is a great link on EOS flash usage
I think most experienced E-TTL users already know that link by heart.
Understanding E-TTL is the easy part... the hard part is to try and apply all that information to a real, fast-moving situation where speed and timing are the key.
:)atwl
Rob van Hoorn Senior Member • Posts: 1,629
two words: manual focus!
manual focus yourself and the problem is gone.
or use the 550 in manual mode.
Rob.
Adrian Tung wrote:
rant on
now, lol...
rant off
useful advice? :)))
shoot!
Loggedonnow Senior Member • Posts: 1,698
The Metz 54-3 in auto mode is great as it bypasses the e-ttl and manages the camera itself.
Adrian Tung wrote:
rant on
now, lol...
rant off
useful advice? :)))
 Loggedonnow's gear list:Loggedonnow's gear list
Nikon D850
StaceyRGT Junior Member • Posts: 28
Re: two words: manual focus!
Rob,
I too have been stuggling with e-ttl....can you explain how manual focus, or manual mode on the 550 solves the problem????
Thanks,
Stacey
jbjones Regular Member • Posts: 411
Re: How about...
I know that using MF defaults to evaul metering, but what if I set all focus points active? Does E-TTL stlll exopose only the points used or does it move to eval metering as well?
Rob.
Adrian Tung wrote:
rant on
now, lol...
rant off
useful advice? :)))
 jbjones's gear list:jbjones's gear list
Canon EOS 60D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III Sigma 35mm F1.4 DG HSM Art
When you switch to manual focus, the metering uses evaluative metering and exposes the entire frame, where if you choose a focus point it actually only exposes the active focus point.
Manual mode uses the av and tv that you choose and leaves the flash to properly expose the picture. I use Man mode for all my flash shots.
Rob,
Thanks,
Stacey
Guillaume paris2 Veteran Member • Posts: 4,014
Photography without brain is a nightmare
This ETTL event stuff has been discussed over and over... read before you rant.
http://forums.dpreview.com/forums/read.asp?forum=1019&message=7715940
The Big Bad Veteran Member • Posts: 4,108
Flash bracketing solves my problems every time
Tell the 550EX to bracket each shot + -2 and your all set. 1 out of the 3 has always been acceptable to me.
Not the best way to work for every shot, but during those tricky situations I think it takes alot of guesswork out
Re: Flash bracketing solves my problems every time
Alright, so far we have the following "fixes" for ETTL shortcomings:
  • Cripple your $1500 camera by using manual focus
  • Take three shots of everything so that one will come out right
  • Push the FEL button then explain to your subjects that you didn't really just take the picture and ask them to please return to their previous positions for the actual shot.
Please remind me again why this is all worth it? I think that a $300 flash should work BETTER than a $60 one but with Canon this isn't the case.
BTW, I have a 420EX as well but I never use it because I can't count on it to give me the proper exposure. My Sunpak works every time.
Imagemaker18 Regular Member • Posts: 183
To all of you, who are frustrated by the 550EX ETTL idiosyncracies, I humbly suggest that you read the 550EX manual, pp. 112 & 113 "CUSTOM FUNCTIONS", and see that you can eliminate all your ETTL woes by simply switching CF-3 from 0 to 1, which turns the unit into a straight TTL flash for those special occasions when you can't use FEL or can't focus on an area that represents average exposure. For my money, TTL flash beats the run-of-the mill Auto-Flash, although the Vivitar 283, 285, and the Sunpack 383 Super are excellent Auto-Flash units. I have them, and use them on cameras that can not use TTL Flash. IMHO, ETTL, however, when applied correctly, produces superb images!
All the great hi-tech features that Canon offers in the $300 550EX are useless, unless applied judiciously. The Canon 550EX Flash is an excellent, flexible unit, if used properly.
Cheers!
Imagemaker
isn't the case.
time.
Amen!!! (nt)
isn't the case.
time.
