Card Reader - HELP!
Started Jan 5, 2004 | Discussions
ranix Forum Member • Posts: 79
Card Reader - HELP!
Hi,
I just got a new USB2.0 6-in-1 card reader (Y-720).
I tried to connect it to my home PC (XP) but no go - just keeps blinking my
At work (W2000, USB1.1), it seems to read Memory Stick (I also have a sony camcorder+F717) just fine. When I insert the CF from the EOS-300D it recongnizes it but wants to format it ?!?!?!
Anyone tried to read the EOS-300D cards on in any other reader besides the EOS-300D's internal reader?
Thanks,
Ranix
OP ranix Forum Member • Posts: 79
Re: Card Reader - HELP!
(one line was cut on the previous post)
Hi,
blinking the green led, and the PC won't read anything. Not a MS, nor a CF.
Thanks,
Ranix
Dennis Regular Member • Posts: 128
Hi,
nor a CF.
I have used the CF card from the 300D on my external card reader with no problems. It could well be you have a faulty card reader or CF card. Try using another CF card to see if you have the same problem. Alternatively, format the existing CF card in the 300D, snap a few pics and see if the problems reoccur.
A buddy of mine has a card reader that can read CF cards with no problems, but hung his PC when he tries to read a CF II card (microdrive) or an SD card. Turns out his USB connection was flaky
Thanks,
Ranix
Michael Crowder Senior Member • Posts: 1,800
Lexar 6 in 1
I have the Lexar 2.0 and I use SanDisk cards. They read fine.
Kelvinz Contributing Member • Posts: 883
Sandisk Imagemate 6in1 USB2.0
Using a Sandisk Imagemate 6in1 USB2.0 works fine for me.
-Kelvin
Equipment-
Canon 300D/18-55mm f/3.5-5.6
Sony F717
Nikon F2
Tiny Gallery of mine http://kelvinz.deviantart.com/
Lynyrd New Member • Posts: 13
Have the PQI 6n1 USB 2.0 Card reader .. and it works perfectly reading and writing to the CF card.
Robert-Mike Regular Member • Posts: 214
What size card.....
I went through several brands before I found one that worked with 512 and larger cards. The ones that didn't work always wanted to format and/or would not recognize the large cards. I finally went with the Lexar 6 in 1 USB 2.0 reader.
ranix wrote:
Hi,
blinking my
Thanks,
Ranix
