Sony NP-FM50 battery
I charged my original cam battery one time in the camera. After that I used an aftermarket quick charger. Ambico.. I think. It comes with adapters for many types of batteries. You can charge one while shooting with another. Maybe try that type charger and see if the battery takes a charge. also charge the battery full. disconect the charger then charge again, immediately. (not something I would do in the camera, Overcharging the old batt.s had the possibility of making them explode or vent gas, I am not sure what happens with the newer NmH and lithium batteries) Sometimes a double charge wakes them up some.
Mikeeeeeeeeee
Donuts... is there anything they can't do? H.J. Simpson
So, how do you charge the battery if it is not in the camera? Is
there some other thing I should purchase to charge batteries?
And, one of you said to take the Mem stick out and stick it into a
Mem card reader (which I do not have) instead of downloading
directly from the camera. Is this the best way to keep from
draining these batteries out?
So, I guess I need an "external battery charge"r (what is the name
so I can purchase one) and a "Mem card reader" (also need name of
it)???
And, of course 2 more batteries before I go on my trip. Per
another poster I need to fully charge each new battery before using
it. Right?
On trips can I just charge the battery in the camera when it gets
low so I don't have to drag all the other stuff around? I am
taking my laptop and can download the photos to a CD if necessary.
But our kids always want to see the all the photos on the computer
at the end of the day in a slide show. Thanks for everyone's help!
Elena
As soon as I saw the size of the "transformer" that came with my 707, I knew I was not going to lug it around. I bought the Sony charger (from Sony). Much smaller, lighter and charges the battery pretty quickly.
Has the added advantage of running on either 110 or 220 volt current. All I needed in Italy for two weeks in March was a plug adapter.
I carry 3 batteries-one in the camera and two in the case. When travelling, I never want to run out and I can recharge at night.
Glenn
I'll have to time my next transfer.
R2
USB 2.0 makes it go Very fast.
R2
Yeah, but we don't all have USB 2 . On laptops particularly it's
only the fairly (very) recent ones that are now putting it on
here...USB 1.1 is still pretty good though
EJN
I was just reading in the manual, and came across where it says to remove the battery when using the A/C adapter (if you're going to keep the camera on). Charge only with camera turned off. Hmmm
--I am now on my second NPFM50 batteries for this camera (DSC-S70).
It works fine for 6- 10 months and then the camera says "FULL"
after I charge, it but indicates no battery left when I disconnect
and turn the camera on. Does this mean I have to buy a THIRD
battery?? What is the deal with these batteries?? Are all Sony
batteries this crappy?
HELP!
Interesting... I always use the external charger... but thought most devices only charge when turned off. Otherwise it just works as an AC adapter.
Macro-
(aka David Hasenick)
http://www.pbase.com/dbh/galleries
