The fourth camera in Leica's SL series of full-frame mirrorless cameras sees the 60MP BSI sensor from the Q3 and M11 models arrive with a significant interface redesign.
G9II vs OM-1 compared for bird shooting - Part II
lokatz wrote:
tomhongkong wrote:
Thanks for Part ii. It's very informative, although I suspect that the 'real life 'shooting in Part iii and the subject detection performance will reveal more.
I hope and expect the same.
The G9ii looks like a good alternative to the OM-1 so far with several advantages which you have picked up. Whether I will be tempted to change, I don't yet know. I certainly won't be doing anything before you have finished your series, that might give OMSystems time to show if they have a response coming.
Here's a question. One way or another I have ended up with my 'better' lenses being Panasonic (35-100, 50-200, 200, 100-400 plus the TCs) It's probably too early for you to say, but do you sense that the AF performance of these lenses would be better on the G9ii than on the OM?. Is there some optimisation of the lenses when they are on their 'native' bodies?
I don't have enough Panasonic lenses to be able to give a full answer here. My gut feel is that the answer is 'yes', based on two aspects:
1. The fact that the G9II had a consistent focus speed advantage over the OM-1 when shooting with the PL100-400 at least hints at it.
2. To me, it would make logical sense. A general trend in camera design is that bodies include more and more features that either optimize lens characteristics or compensate for lens deficiencies. Correcting for lens distortion in-camera is one more and more makes seem to adopt. While there isn't a whole lot that gets published about this, I bet AF optimization is another. The manufacturer knows best how to get optimal results. AF design from an engineering standpoint must be a speed-vs-accuracy tradeoff, for example, which gives plenty of room for optimization on when to drive the lens fast and when to drive it more slowly.
Should my evaluation end with the conclusion that the OM-1 and G9II are about the same, I might well hang on to the Panasonic only for those trips where I prefer taking the PL100-400 along instead of the Oly 150-400, for weight and size reasons.
... Incidentally I don't agree with your comment about S-AF. Rather than cause a digression in your post, I will start another on when and why S-AF is advantageous.
Interested in your thoughts here.
Just to clarify: my tongue-in-cheek comment that I don't even know how to put a camera in S-AF mode was meant nothing but humorously. I like taking landscape shots and have yet to meet a landscape that moves. Yet, with moving subjects such as birds and other wildlife, it is a rare thing for me to even consider S-AF. There are a few exceptions, but they are that: exceptions.
I mostly shoot CAF as well. Unless the lens has terrible MF accuracy (that’s you Sony) I prefer MF on a tripod for landscape. For handheld, it depends on how precise the SAF and CAF targets are. The tiny OM1 SAF point is handy but relies on a small area of contrast. Bit of care required.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
This is a situation where I love the option to manually override the focus: I use S-AF mode and let the camera do the initial focusing job, but then check/adjust focus manually.
Obviously, this only works when using BB-AF.
A matter of taste, though. The end result will be the same either way.
By the time I’ve placed the Magnify focus point where I want it, turning the focus ring is only a bit of extra work.
Andrew
Those are my thoughts as well. In addition to the 100-400 I have the 50-200 which I prefer (my copy) to the 40-150 as well as having the 200 which is wonderful. I really like the results from 200 without TC or with 1.4x. Neither of these do so well for me in IQ terms with 2x (could be my 2x converter?) I can't really justify the expense of the 150-400 to myself although my wife would say buy it if you think it is worth it, we can afford it! (That's one effect of a the realisation that in our 80's we have few years left to go and should enjoy them)
I have started another thread with an explanation
Thanks again for your efforts in putting up your views and fielding the comments
tom
lokatz wrote:
jrsforums wrote:
Panasonic publish AF guidebooks to help understand how to customize AF under different shooting conditions…both S & G series. They are a little bit out of date and do not include latest subject selection capabilities, however the basic concepts and algorithm design should be the same and can help understand how you can best match to your shooting needs.
https://www.panasonic.com/global/consumer/lumix/technologies/af.html
Thanks for sharing the link. I'm not sure how useful this is for the G9II or, for that matter, S5II/S5IIx. The addition of PDAF requires new algorithms and must have a considerable impact. This means that some of the recommendations probably need to look different for these bodies.
LUMIX USA podcast G9ii
https://www.youtube.com/live/SPBA1hiJ5-o?si=2GmeJgu379LaUDL-
@ 59:48 AF customization
Page 160 in the manual tells you the same thing. In some of the R bodies, Canon uses a similar approach of bundling certain parameters in order to make the choice easier for users.
I'm going to start with Set 3 in my tests of the G9II, given that I often shoot small birds whose movements are fairly random. I might modify these settings down the road, but that'll take quite a bit of shooting before I'll know what I like best.
Nothing wrong with that. Again, we are deep in personal preference land here, so I'd be hard pressed to argue why one method is better than the other.
I have to admit that nowadays I rarely check my focus when shooting statics (landscapes, architecture), and pretty much never use magnification when doing it. On my Nikon Z7ii, Canon R5, OM-1, AF-C always worked so well that the shots were sharp anyway. The greater DoF of MFT helps, too. This was different with earlier bodies I have owned.
lokatz wrote:
The OM-1 allows focus peaking when using manual override. In other words, you can keep the body in AF-C mode and still use the lens’ focusing ring to adjust the focus while getting focus peaking in the viewfinder. This is very helpful when a bird’s perch is partly hidden behind branches, for example, and the camera insists on focusing on the latter. The G9II only allows the use of Focus Peaking with MF and AF-S, but not with AF-C. Bummer.
Huh. Is the menu option AF+MF greyed out when you are in AF-C? It does work on my S1 but that one does not have PDAF, so I wonder if that is a limitation of the AF-C implementation with PDAF?
Focus / Image stabilization
IS helps when trying to find a bird in the viewfinder. You don’t need IS to perform particularly well, however, to get a good shot of that bird. Here is why:
That is totally true but I would point out that I find it very useful to have a steadier view when you're at 800mm equivalent. It's also a very different story with video, obviously.
I have both the PL100-400 and the Oly100-400. The Olympus' IS is considerably worse than the PL and it has no Sync IS on the OM-1. I was hoping that the G9ii with the PL would be a lot more stable.
I am sure the 300f4 and great white are better but I prefer a zoom and the great white is just too expensive for me to justify.
It is not greyed out, it just doesn't seem to affect anything in AF-C. The Set menu for focus peaking has options to show it in M and an option to show it in AF-S. No mention of AF-C. Same in the manual (page 202).
Agree. That's why I said 'it helps'.
I should have mentioned that I do not shoot video at all, so I am not qualified to comment on that side. Sorry. However, I'm not sure why video at 1,000mm would benefit any more than stills shooting at 1,000mm.
Well, per my findings as reported in part II, it is more stable.
Understand completely. There are also trips where I don't want to take the 150-400 along and the PL100-400 is the right choice.
I, also, do not have practical experience with video, but the G9ii has additional video IS modes, p. 269 in manual.
lokatz wrote:
The main point I am making with this is that unless someone invents a subject stabilization system that will keep the animal frozen in place until I got the shot (I like that idea... ), bird photography has few scenarios where high IS performance would make any difference. Be careful not to bark up this tree too much.
Testing IS performance is difficult. Most people I know judge IS performance by how stable the image is in the viewfinder. That might give a hint but is not overly relevant: what you really want to know is how much more accurate your focus is with IS than without it.
No other animal of decent size that I am aware of will stare one down as much. I always hear folks talk about humidity temperature conditions plus anything related as opposed to the actual gear itself, how it will function regardless.
I say even under perfect condition, the gear itself will fail regardless of how skilled one might be. Problem is we never actually see enough testing to see where that point is.
Just checked the S5ii manual, it says it’s available for SAF but does not mention CAF. Funky. Maybe they haven’t gotten to it yet with PDAF
Yes, was just for emphasis
I do shoot videos occasionally. It does help to have smoother, more predictable behavior. Panasonic tends to be quite good at that. I’m looking forward to trying 4K/120p!
Yes all very promising so far! Fingers crossed it stays that way
Thanks for taking the time to write down your impressions with so much detail, much appreciated!
Grüße aus Spanien!
On G9, AF+MF was also only available with AFS, not AFC. However, if you use ‘AF Point Scope’ you can zoom in (full or PIP) in AFC (or AFS). While AF is active (half press shutter or pressing AF-ON) you can MF. (I use Point Scope Fn as on/off button, rather than ‘while pressing’ to avoid having to hold to many buttons down)
EDIT: I don’t use peaking, but just tested. Works in Point Scope PIP window in AFC.
As I said somewhere in part II, that's a feature I love and think is a great idea. Some folks will probably still prefer focus peaking, though not necessarily for bird shooting.
I did some further testing. Point Scope seems to temporarily switch to AFS mode, while activated. This seems to also allow peaking to work with it.
lokatz wrote:
Here, things got more interesting. Let’s keep in mind that the focusing distances weren’t anything like what I'd have in normal shooting. How much better the Panasonic performed in low light, in both speed and accuracy, was nevertheless a surprise to me. I am curious to see whether that pattern repeats itself when shooting birds in low light. My real-world experience with the OM- 1 is that it sometimes needs too much time to get a bird in focus in low light, so I am encouraged by what I the G9II’s showing in this test. The fact that the G9II seems to focus a bit more slowly in good light doesn’t bother me much, as I don’t consider the observed differences to be significant enough.
The differences in focus accuracy were striking across the board. I want to be careful not to make the OM-1 sound like a slouch here, because it isn’t. In my experience, it does misfocus every so often, though, which so far seems less of an issue with the G9II. The true test here is obviously how both of them perform in the field.
See these:
Robin Wong has replaced OM-1 with E-M1 II
https://www.dpreview.com/forums/post/67172708
3 more videos about the AF problems
https://www.dpreview.com/forums/post/67172978
Rob Trek: OM-1 vs E-M5 III S-AF in Low Light
lokatz wrote:
Initial focus testing
If you are anything like me, how well the G9II focuses will be what interests you most in this new body. (“Don’t give me all that crap about noise and colors, just tell me how well it focuses”. )
Hahaha, although I don't shoot birds (not yet, anyway), I am also most interested in the AF performance of G9II, so I hope you don't mind that I read your Part II first (then went to your ThisBeautifulPlanet comparison report, and again reading the "AF Impressions" section first).
https://thisbeautifulplanet.de/five-body-lens-combinations-for-mobile-bird-shooters-part-ii
This is why I bought the G9II: I’m hoping it’ll get me closer to the R5’s performance, ideally both in focusing speed and accuracy, without requiring excessive sacrifices in other areas. Well, that, plus resolution: while the 25 vs 20 MP difference is pretty small, it matters to me. This is because the subjects I love shooting most are small birds. Some of them are minute and quite shy, so they rarely let me get close. As a result, even with lens plus TC at 500mm they won’t fill the frame. When you crop a lot, even a few more pixels matter, which adds to my interest in the Panasonic.
Believe or not, your report addressed (or at least started to -- I am sure there will be even more insight shared in Part III) what I have been looking all over the internet for:
How does the PDAF in the G9II compare to the best cameras on the market (at least those at similar price points)?
Since I already have quite a few MFT lenses, comparison between the G9II and the OM-1 is naturally of interest to me.
However, after the heartbreak I suffered with the G9's firmware 2.4 update, you can understand why a small voice inside me keeps asking if I should take another look at Canon again (I used to shoot with a Canon 7D, and still have several L EF lenses, including the 70-200/4 L IS and the 100-400 L IS).
While there have already been a million reports by photography pundits/influencers/YouTubers on the G9II's AF, very few of them compared the G9II to other brands, and even fewer to non-MFT brands like Canon and Sony.
You obviously have lots of experience with the R5, and also experience with the OM-1 and now G9II, so I consider you a context expert when it comes to the relative performance of different AF systems, at least in the setting of photographing birds (in flight or not). If I read your Part II correctly, OM-1 and G9II are very close to each other in terms of AF performance, but still NEITHER AS GOOD as the Canon R5.
I'm sure you are aware of the BIF comparison article by Mirrorless Comparison, also ranking the R5 above the OM-1 (albeit only very slightly):
https://mirrorlesscomparison.com/best/mirrorless-cameras-for-birds-in-flight/#cameras
So my question for you: Have you ever considered the Canon R7 for bird photography (especially when the pixel density should make it even more suitable for small birds than the R5)?
If not, was it because of its AF being inferior to the R5? Or because of Canon lenses not matching your Olympus 150-400/4.5 TC?
Earlier in this thread someone asked if you would consider switching back to Nikon, and you said no, because of how perfect the Olympus 150-400 is for your needs. But I wonder if the new Canon 100-300/2.8 (plus TC) would finally give your Olympus 150-400 some competition?
With a 1.4 TC, the Canon 100-300 would become a 140-420/4.0, so covering the entire zoom range of the Olympus 150-400, but with a slightly faster aperture.
A R7 will get even more pixel density out of that lens due to its crop sensor.
While not quite as exotic as the Olympus 150-400 or the Canon 100-300/2.8, the Canon 200-800 would give more reach (but with slower apertures).
But I suspect the answer is that the R7's AF performance is simply not as good as the R5's. (Certainly, the Mirrorless Comparison ranks the R7 significantly lower than the OM-1....)
Maybe Canon will add pre-burst to the R5 with a future firmware update (but I hope they improve upon the not-so-perfect implementation in the R7).
Anyway, sorry about the rambling -- it's past midnight here.
I just want to thank you again for putting together such a detailed and insightful comparison. I can't wait to read Part III when it comes out!
Let's all ask ourselves every now and then: Have I taken
more photos than posted messages on DPR this week?
Glad someone is reading it.
Working on it. Still need a week or so. (Spoiler alert! I can already safely say that with perched birds (ok, let's say "relatively static subjects"), the G9II clearly beats the OM-1 and does not feel much different from my R5 if the light is good. In low light, it is noticeably slower. All further inquiries will be referred to Part III.)
Because somebody else wielded it as if it were solid proof, I have recently been tempted to write a critique of this particular comparison (but don't know if and when I'll get around to it). Mathieu Gasquet is a good guy and I like some of his work, but what he does here IMO is highly misleading. I suggest taking this comparison with a BIG grain of salt. As good as the OM-1 is, there is still a substantial difference in AF performance between it and the R5, for example, which is not at all reflected in his 'data'. I can see why, but it's complex to explain.
I have, carefully checked specs and reviews, checked it out myself in a store, and decided against it. This had nothing to do with AF, where the R7 is at least R5 grade, maybe even a little higher.
To me, the R7 is a perfect example of an excellent concept spoiled by some rotten ideas. Its AF is VERY good, clearly the best for the price. Its higher resolution allows for more cropping, again just what birders need every so often. Yet, its control elements, especially but not only that quirky rotating dial placed near the EVF (another one of Canons "in the field" experiments it never repeated, and never should), take a level of getting used to that anyone coming from a well designed body doesn't want to get near to. I know several R5 users who won't even buy it as a backup body because of this. There's quite a list of other irritations, starting with but not limited to the needlessly small buffer and the ProCap implementation you mention further below. With a few modifications, this body could build a rep similar to the Nikon D500, but Canon must have feared that this would cannibalize their higher-end models too much. Which, at the prices they are asking for those, is probably true.
No. That's a 2,650 gram lens. I don't care how good it is, that's too heavy for extended hand-holding. Been there, done that, won't do it again. My limit for body plus lens, obtained from plenty of experience with different rigs, is about 2.5kg, less than what that lens weighs alone. On top of that, 600mm (with a 2x TC) is still short.
You ARE familiar with the MFT system's crop factor of 2.0, aren't you? That 420mm compares to an FF equivalent Field of View of 1,000mm with my Oly 150-400, with its internal TC engaged but without adding an external one.
Even when putting the lens on an R7 with its 1.6 crop factor, that Canon lens would only give you an FoV equivalent of 672mm. Yes, the R7's 33MP resolution vs. the OM-1's 20MP would narrow that gap some, but the G9II widens it again.
If you're willing to live with the quirks, the R7 with the RF 200-800 is a "low budget birder's dream team". I am not, plus my Big White Oly is the much better lens anyway (at a steep price of admission).
Agree on both parts. The R5 II will have it for sure.
See these:
All three videos are from the same person. The person Olympus parted ways with last year.
Great video and shows the issue only occurs on white walls below 1EV and only in S-AF. Using C-AF or magnified view avoids the issue all together.
Every camera can misfocus, that I agree with. Even the G9II bird in branches photo someone else shared demonstrates the camera is focused on the berries and branch, not the bird. In Duade Paton's example, the G9II would not focus at all on birds with a bright background. He had to point the camera somewhere else, push focus a few times then recompose on the subject.
See these:
Or shooting events (and other low contrast situations) like Robin Wong does. Fortunately his E-M1 II can still focus in those low contrast situations that his OM-1 cannot.
Latest sample galleries
Latest in-depth reviews
The Fujifilm X100VI is the sixth iteration of Fujifilm's classically-styled large sensor compact. A 40MP X-Trans sensor, in-body stabilization and 6.2K video are among the updates.
The Nikon Zf is a 24MP full-frame mirrorless camera with classic looks that brings significant improvements to Nikon's mid-price cameras. We just shot a sample reel to get a better feel for its video features and have added our impressions to the review.
This $250 electronic lens adapter is perfect for Nikon Z-mount curious Sony shooters — shhh, we won’t tell anyone.
Latest buying guides
