I got my DPR data download, but there are no photos in it
GaryW wrote:
I thought someone said that they give you small versions, but no, looks like I got full size. I just didn't have a lot there, for being on here 21 years! So my download was not large.
By small versions perhaps they meant text only with no images.
We’ve now figured out to get at most of the images. Give the viewer another try:
https://avidgamefan.github.io/dp-display/
Thankyou very much for this, works great!
Glad to hear. Do you see most of your images? Could you also test with my version
https://hk1020.github.io/dp-display
We are still figuring out what is going on with images. Gary’s and my version are a little different at the moment. Gary’s doesn’t work well for me and mine doesn’t work for Gary.
I really didn't post any images over the years:
In that case there is no difference. It is loading of posted images which is making trouble. dpreview gave wrong links and we mostly succeeded in finding the valid ones.
https://avidgamefan.github.io/dp-display/ has a black background & the https://hk1020.github.io/dp-display/ has a white background. So far I can't see any other differences. I'm definitely bookmarking both & really appreciate what you both have done!
Thanks for checking. Eventually, the black version will be used.
If it is still important to anyone, https://hk1020.github.io/dp-display now also shows your private messages and the comments. Just load the complete zip file as a whole.
