Charging in camera vs using charger
Started 6 days ago | Questions
Matt_Kolf
Matt_Kolf Junior Member • Posts: 25
Quick question:
Does anyone know if charging the battery in camera could be worse than using the original charger?
Could battery charge last less or the camera be damaged if I always charge via the USB cable, for example?
(I have an R6 and LP-E6nh batteries).
Thanks!
 Matt_Kolf's gear list:Matt_Kolf's gear list
Sony RX100 III Canon EOS R Canon EOS RP Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM +7 more
Canon EOS R6
Steve Balcombe Forum Pro • Posts: 15,571
Re: Charging in camera vs using charger
Matt_Kolf wrote:
Quick question:
There shouldn't be any significant difference, especially if you only use the genuine Canon charger. It has been suggested that some aftermarket chargers can charge too fast, which is bad for battery life. I don't know if there is any truth to this.
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
I‘ve been using in-camera charging almost exclusively since I got my M6II in 2019, and continue to do it with that camera and my R, R7, and R6II (R now sold). I haven’t noticed any problems.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
drsnoopy Senior Member • Posts: 1,216
It has often been stated that the USB-C port is somewhat fragile, being directly soldered to the main board in at least some of the R series bodies. But a lot of people do regularly use it for charging and downloading. Personally I find no need to charge in-camera, as I always carry spare batteries which can be swapped in a moment, and then charge the used ones with the OEM charger when I’m home. Also I prefer a card reader for downloading. But I can see that if you want to keep weight to a minimum for travelling etc, in-camera charging may be attractive especially if you already carry a USB-C PD charger.  I would still want at least one spare charged battery though!
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Matt_Kolf
OP Matt_Kolf Junior Member • Posts: 25
Great. Thanks for your reply, Steve!
koenkooi Contributing Member • Posts: 919
The camera will use a relatively slow charging speed to keep the heat down. I’ve been charging batteries solely in the camera for my R5 and M6II since their release and everything is still working well.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
CameraCarl Veteran Member • Posts: 9,193
The one real risk that I see is that the PC board to which the USB port is attached is very expensive to replace. So if something should jerk on your cable when it is connected to the camera, it could damage the camera leading to many big repair dollars. I know carrying a charger can be an inconvenience but I find it easy to do.  I can charge batteries while using my camera. And that is one more cable I don't need to remember to carry along.
amas2
amas2 Forum Member • Posts: 96
It´s not another cable, because it´s the same cable I need to charge my mobile phone.
 amas2's gear list:amas2's gear list
Canon EOS R6 Canon EOS-1D Mark IV Canon EOS 5D Mark III Canon EF 100mm f/2.0 USM Canon EF 300mm f/4.0L IS USM +4 more
Matt_Kolf
Thanks everyone! Great replies! I think I'll use the charger for the most part, but I won't be afraid to charge in camera either.
