Adding a date stamp on a picture after the fact
Started 1 week ago | Questions
Lord Al New Member • Posts: 3
Hi,
Thanks for the forum!
I have taken some photos on my Nikon D3100(B) and then realized that the date stamp was not switched on. I need the stamp because it's for a record.
I have a late 2015 iMac running Monterey.
How can I add the date after the fact before printing it?
Thanks in advance.
Andersonm Contributing Member • Posts: 951
On the picture or in metadata?
Do you mean on the picture itself - a date written on the image?
Or to add a date to the metadata, the information stored with the file saying when the picture was taken?
or is both necessary?
Assuming you mean writing it on the picture itself, I don’t use Nikon so I don’t know if there is a setting for it - if the date is for artistic effect, you could set your camera to the right date, take another picture, then pay some photoshopper on Fiverr to use the new picture as a template and copy over the date stamp. Should be extremely fast, and a few dollars.
Edit: would be particularly easy if you took it against a fully white background. Or leave the lens cap on and make it fully black. Not sure if black or white makes a difference. You could also do it yourself.
 Andersonm's gear list:Andersonm's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 20mm F1.7 II Panasonic Leica DG Summilux 15mm F1.7 ASPH
bobn2
bobn2 Forum Pro • Posts: 71,925
Re: Adding a date stamp on a picture after the fact
Lord Al wrote:
Hi,
Thanks in advance.
You can use any image editing software and superimpose the date on it yourself. The built-in Photos app on your Mac will do it. Instructions here.
"There are plenty of cameras at work, but most of them without any brains or knowledge to work them."
Ferdinand Hurter.
OP Lord Al New Member • Posts: 3
Re: On the picture or in metadata?
Thanks Andersonm,
I need it on the photo when printed as it is for a legal requirement. The metadata shows it, but it won't show on the photo.
The camera was set up with the date stamp, but a relative was playing with it (thinking they were helping) and deleted that option.
Took me a while but I finally figured out how to get it back, but in the meantime I have to keep a notice up on my property for another month unless I can transfer it from the metadata somehow.
All the best
Thanks bobn2,
I will try that. i appreciate your suggestion.
All the best
