Re: Sharpness with long focal length
Hi all,
thank you very much for your input, it's greatly appreciated!
I removed the filter and took some more trial shots. Personally I do not feel like it changed a lot.
Weather is a little bit worse today and the bird somehow didn't wait for me to return. But here are three more:
All images on tripod with 10s exposure delay.
1) Indoor, short distance (3-4m?). This one wasnt taken with 600mm but slightly zoomed out to ~560mm because I otherwise couldnt focus in the small room.... So maybe forget about this picture...
2) Outdoor, 10m. No significant wind
3) Same as for second picture
I think I did them all with 1/500s (which I think should be fine on tripod with calm air and still target?), ISO1000 (with the EOS R I usually do not see noise issues at this ISO for e.g. macros and so on) and fully open (f/6.3) at 600mm.
I still have this feeling of everything being a little too fuzzy. It looks a little bit better for the close distance shot on the book (as it did for the black bird yesterday. This one was also in the 3m range). But the flower and the 10m book shot still look rather soft to me. And this is closer to the intended distance of use for this lens...
But again, maybe I am seeing issues that are not there. I am well aware I bought a 1000€ and not a 3000€ piece. But I would have still expected a little more crispiness under such controlled conditions.
I would again appreciate your input on wether I should exchange the lens, do more (which?) tests or if I am being unreasonably picky;)
Thanks and best
Stefan
