UWA zoom for R7 (EF-S adapted)
Started 1 week ago | Questions
dwkdnvr Regular Member • Posts: 263
I recently picked up my R7 with the 18-150 kit lens and the 100-400. My primary application will be to try to come up to speed on birding/wildlife, but I want to fill out the lens lineup a bit for more general purpose and/or video use.
I'll definitely be getting the EF-S 24mm, and probably the RF 50mm/1.8. I'm considering the RF 16mm but not immediately as I'm not really sure I need that FL in a prime.
I'm also eyeing the Sigma 18-35 as a potential future purchase.
So, that leaves an ultra-wide zoom. My original thought was the EF-S 10-18 since it's cheap and seems to be widely recommended. Browsing MPB though there are a whole bunch of wide EF-S zooms so I thought it would be worth gathering some opinions.
Canon 10-18
Canon 10-22
Tamron 10-24 (2 different versions)
Tokina 11-16, 11-20/2.8, 11-16II
Sigma 10-20/3.5, 10-20/3.5-4.6
My thoughts: The Tokina 2.8 is the most expensive, but offers constant 2.8 which is valuable particularly for video but less so if I get the Sigma 18-35.  The Tamron 10-24 has the longest reach which gets solidly up into 'normal' range. The Canon 10-18 is tiny and seems to be well regarded and seems to generally be recommended above the 10-22.
So, my question is: do any of these offer performance compelling enough to choose over the 10-18?
Thanks for any feedback (and apologies for re-treading what is probably well covered ground, but surprisingly my search didn't really turn up much relating to R series)
Canon EOS R7
DivaDreamer New Member • Posts: 20
Re: UWA zoom for R7 (EF-S adapted)
Doing the exact same pondering myself. I have the rf 501.8 and ef-s 24 and like both. Though I am sad every time I put the adapter on the lovely 24 pancake and double its size and weight.
Anyway, for what it is worth, I am a bit leery about the sigma 18-35. The Northrop’s say they have stopped recommending it for canon due to af issues. Perhaps someone with direct experience can comment.
Llop Forum Member • Posts: 50
I have the 10-18 adapted on the R7 and works very well, I have not tried other alternatives mentioned.
I also used the sigma 18-35 1.8 as my main lens on the R7 for almost a month and it worked great. Extremely sharp, great IQ, accurate and fast autofocus. I did not keep it due to its size/weight (front-heavy), and because I did not want to invest that much in an apsc lens, but I would recommend the combination if the focal lens range works for you.
KENTGA Veteran Member • Posts: 8,727
I'd choose the EF-s 10-22. Seems like it's a notch above the 10-18.
Kent
Here is a link to some of my travels since 2006. Feel free to comment.
https://www.flickr.com/photos/108062364@N04/albums
KENTGA = Kent from Georgia (metro Atlanta)
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +14 more
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
I have the R7 and EF-S 24mm 2.8 and it is a very good lens indeed. I used to have the EF-S 10-18 with a T7, and was great. I will probably pick up another one, since the IQ is outstanding.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
KevinRA Senior Member • Posts: 1,457
Suggest used copy of the 10-18 - and then buy the RF-S 11-22 when canon ports it over from the excellent EFM lens.
I have owned it before on the 7DII - and was just as good as the 10-22 in real life use.  The IS is nice too.
I like my 11-22 on my M6II - and one reason I have kept the M6II
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
WShotton Forum Member • Posts: 93
I have the Canon 10-22 and it is a nice range and works very well with my R7. However, especially combined with the required adapter, it is a relatively large and heavy package. Given that eventually Canon will likely make an RF version of the 11-22 EF-M lens, that will probably be a better choice. But when or if that will happen is a big question.
 WShotton's gear list:WShotton's gear list
Canon EOS R7
dankenny Forum Member • Posts: 78
I use the 10-18 on my R7, alongside the 15-85 for general landscape/family and the 18-35 Sigma for low light. All great performers in terms of AF and image quality.
MikeJ9116 Veteran Member • Posts: 6,955
If you are going to use this lens for video then go with the EF-S 10-18mm STM. Its AF was designed to work very well for video use. The others you are considering will have issues due to their age and AF systems. Plus, this lens has very good IS which is likely better than the R7's IBIS when used on a non stabilized lens. The IS allows the IBIS in the R7 to be turned off and thus avoiding some of its issues with warping/warbling the video near the edges of the frame that has been an issue, in general, with Canon cameras. The EF-S 10-18mm also performs very well as a stills lens.
Sittatunga Veteran Member • Posts: 5,406
That's cheap second-hand as it's a huge lens, equivalent to a full-frame 28-57mm f/2.9, but with the adapter it's bigger and heavier than the EF 24-70mm f/2.8.
Canon 10-18
very plasticky, has IS but definitely a wideangle zoom range.  Possibly better edge resolution and coma with similar distortion and slightly worse vignetting compared to the earlier
Canon 10-22.
Just about a walkaround lens for wideangle enthusiasts, bigger, better finished, f/3.5-4.5 rather than f/4.5-5.6, focussing scale (but it's very very approximate as the lens isn't parfocal), metal bayonet.
The 10-22mm looks and feels nicer than the 10-18mm and has a more useful range.  The 10-18mm might actually bounce better, being plastic and less than â…” the mass.  There are rumours of a forthcoming RF 11-22mm, slightly slower than the EF-M 11-22mm that I found a real upgrade to the EF-S 10-22mm, but you wouldn't lose much on buying the 10-18mm second-hand now,  while we wait to see if the rumours are true.
JoWinter Regular Member • Posts: 315
Yeah, that might all be true, but the 10-22 is an ugly lens, especially with an adaptor on a modern mirrorless Canon camera. It really looks, like, 20 years old. Oh, wait, it is a 20 year-old design!
But of course, that's my personal taste issue and does not affect other positives of the 10-22.
Neither lens is particularly good looking compared to what I use; https://camerasize.com/compact/#890.22.5,890.424.5,719.386,ha,t
The other possible positive with the 10-18mm on the R7 is its lack of IS, particularly as its focal lengths are short enough not to to tax the IBIS' range of movement. . You can't use the R7 with IBIS switched on and the lens IS switched off. IBIS wasn't a thing for Canon when the 10-18mm came out in 2014, so generally the EF-S and EF lens' IS wasn't designed to work in conjunction with IBIS. People have complained about this here, but I don't have first hand experience of those lenses on that body.
True - but the M100 is a pain with lack of controls...  M5 or M6II a fairer comparison - but yes we need that RFS 11-22
If I did not have my M6II - a 2nd hand 10-18 with warranty from dealer seems best option and sell on at not too big loss when the RFS 11-22 comes out.
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
I loved the EF-s 10-22. Nevertheless I am pretty sure that sooner than later a comparable RF-s will come and that will be much more compact than adapted ones. So I would wait.
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
Steve Balcombe Forum Pro • Posts: 15,571
Sittatunga wrote:
Canon 10-18
Canon 10-22.
[snip]
I agree with all of that; just one thing to add which is that the 10-22 has better flare resistance than the 10-18, and that's very important for ultrawides because it's so hard to avoid bright lights in/close to the frame. It's worth picking up a lens hood for it; I have the JJC LH-83L which works well.
But yes, the R7/R10/R50 desperately need a native ultrawide, and a ported EF-M 11-22 would be perfect. Let's hope it comes soon.
It's very different, but it's not my only camera.  I enjoy its minimalist touchscreen philosophy and find it less of a pain than the 5Ds which has buttons and controls all over the place. I use the R and the 5Ds for higher quality and the stuff the M series can't do and APS-C for size, fun and pocketability. The M50 II is just too big for what I want from APS-C and the M6 II too expensive. I don't think the R7, desirable as it is, is any replacement for the M series.
Same advice here.
drsnoopy Senior Member • Posts: 1,216
You can’t turn off the IBIS independently.  If lens IS is turned on, IBIS is turned on.  This is true for all R series bodies that have IBIS.
And yes, the 10-18 is an excellent lens, indeed the only EF-S lens I kept.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
But the EF-S 10-18mm *does* have IS…
That's exactly what I was saying.  Its IS wasn't designed to work in conjunction with IBIS though, and you can't set the R7 to have either system working without the other, so the lens's IS is potentially a disadvantage on the R7, though definitely an advantage with the R10 and the R50.
R2D2 Forum Pro • Posts: 26,537
Yes, waiting PATIENTLY for the RF-S 11-22!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
R2
