Re: Deciding between the R6 Mark II or the R5?
Interesting analysis that might help others. A couple of comments, though...
Basil Fawlty wrote:
ISO Range:
- R6ii - max native ISO 102400
- R5 - max native ISO 51200
- I don't think I've ever shot at 51200, so this wasn't even a consideration
Controls:
- R6 II has a dedicated mode dial, but doesn't have a top LCD. Also the R6II has dedicated video/ stills switch
- R5 has a top LCD screen, but changing modes is a little clunky compared to the R6. Also switching between video and stills required two button presses - the mode button on top, then press the "info" button on the back.
Memory Cards:
- R6 II: 2x SD UHS-II slots
- R5: 1x CFexpress Type B slot and 1x SD UHS II slot
- Which is better is a matter of personal preference and what you shoot. Personally, as a mostly stills shooter, I'd have preferred dual SD slots since SD cards are cheaper and are more than up to the task for stills. The CFExpress card is really only necessary in hard-core video scenarios like high speed high resolution video. Given the R5's capabilities with video, it's understandable why they have the CFe slot.
While I agree with your thoughts on ISO as far as they go, I'm more interested in image characteristics in the ISO 3200-12,800 range. Specifically, noise and color saturation. How do R6 II and R5 images compare at, say, ISO 6400? As mostly a wildlife/bird photographer, I want to be able to shoot at higher ISOs and have lower noise.
Controls: The R5 does have a dedicated Record button. It's pretty prominent on the top of the camera. What you may not have noticed in the manual is that regardless of what Still mode you're in, pressing that button tells the camera to record video at whatever you've set the C3video settings to be. What I miss, though, is the ability to click a couple of stills while shooting video. Of course one can set the video mode to record Raw images and do a frame grab from that, but I find it more cumbersome than just having a couple of still saved separately.
BTW: If you're setting C modes, be sure to set both the still and video custom modes, and remember that you can have different button and wheel settings saved for each mode. Lots of initial work, but well worth it in the field.
As far as changing modes, on the R5 I just have to press the Mode button and rotate the dial it's embedded in. I don't find it any work at all. Of course you could also switch using the M.Fn. button, but I find that more cumbersome than "the easy way", and I also have other uses for the M.Fn. button.
For cards, while I appreciate the convenience of 2 SD cards (including that my laptop has a built-in SD reader), I've come to really like the fast R/W speeds of CFexpress B cards. When shooting rapid-fire bursts, My R5s rarely fill the buffer, so I can continue shooting fast. And when I'm back at the computer, being able to transfer files quickly really matters when I've got tens of GB on the card (be careful not to burn yourself though!).
My Canon cameras have all had dissimilar slots. With DSLRs, I usually used the SD slot because it was more convenient. But with the R5, I'm using the CFexpress card almost exclusively, and the SD is for overflow. If I was shooting more video, I might use the CFe card for video and SD for Raw. Lots of uses for dissimilar cards if you're really pushing the camera.
Enjoy your new purchase; either camera would have probably delighted you, and I think you'll love the R5.
