Heat destroyed my 135mm f2L
Started 1 week ago | Discussions
LennyLevino Forum Member • Posts: 59
I left my EF 135mm f2L out in the sun for 3-4 days. It's old and gave off a bit of a musty/basement odor, so I thought I'd let UV light clean it up. I took the lens in at night to shield it from the cold.
Unfortunately, the lens is now completely destroyed. My R6 often cannot recognize that it is an autofocus lens, and automatically goes into Manual when attaching it. But even when the autofocus is recognized, the motor keeps running and humming continuously. Also it doesn't matter whether I shoot it in auto or in manual focus mode, all images turn out soft and with artifacts in the pictures.
I'm really bummed as this was my favorite lens. I thought a lens could handle UV rays and heat, as I imagined guys at safaris or hiking the outdoors with their camera on a strap would be proof that heat won't be an issue for a camera lens.
So just a heads up. Take care of your gear and don't let it get too hot or stay in the sun for too long.
 LennyLevino's gear list:LennyLevino's gear list
Canon EOS R6 Canon EF 135mm F2L USM Canon RF 24-105mm F4L IS USM Sigma 40mm F1.4 DG HSM Canon RF 85mm F2 Macro IS STM +3 more
Canon EOS R6
rmexpress22 Senior Member • Posts: 2,304
Re: Heat destroyed my 135mm f2L
If there's moisture outside, condensation will build up inside. Depending on where you're at, if the water droplets freeze at night, that will make things inside the lens expand if there's water inside. Couple that with the sun, it's just not going to turn out well.
I think I'd expect things to go wrong if the lens was intentionally left out in the sun or in the elements over the course of a few days.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
ZX11
ZX11 Veteran Member • Posts: 6,156
Worth looking at a flex cable break from age and heat cold cycles.  Or, a poor/aged solder joint.  Electronics hate heat cold cycles.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
