Weird issue with RF 100-500 and 1.4x teleconverter
Started 1 week ago | Discussions
drunkenjitsu
drunkenjitsu New Member • Posts: 15
So I just received these and noticed after taking the teleconverter off that the lens will not close back down when turning the focal ring. It will extend to 500, but stops at around 300 as if something is blocking it, and I didn't want to force it. Has anyone experienced this?  What should I do?
SydLow Regular Member • Posts: 175
Re: Weird issue with RF 100-500 and 1.4x teleconverter
drunkenjitsu wrote:
... the lens will not close back down when turning the focal ring.
What do you mean "close back down" and "focal ring"?
You know the Teleconverter only works between 300-500mm
drunkenjitsu
OP drunkenjitsu New Member • Posts: 15
The focal distance/zoom ring, and it wont go down to fully collapsed at 100mm
With the Teleconverter attached?
drunkenjitsu
No I took it off. I know it has a limiter when it's attached. It's behaving as if it is though
Sounds like something is broken now.
drunkenjitsu
Basically it's acting like the limiter is still engaged with the teleconverter removed. Ill call Canon.
CameraCarl Veteran Member • Posts: 9,193
I didn’t think that there was a limiter built into the 100-500 lens. I thought that the zoom was simply limited by the presence of the teleconverter being there.
drunkenjitsu
So I called Canon and they said that it does have an internal limiter when the teleconverter is attached, and when you remove the teleconverter you have to click past the limiter and you'll hear a clicking sound which is normal.
Phylloxera Regular Member • Posts: 256
Interesting. I just tried several times and couldn't reproduce the effect. Just once I heard a faint click shortly after removing the converter.
 Phylloxera's gear list:Phylloxera's gear list
PTGui Pro
PMUK
PMUK Senior Member • Posts: 2,999
Hi drunkenjitsu,
It is 'normal' - excerpt from RF 100-500 User Manual...
Phil
Dear Everyone at Canon: Zebras for Stills - How Hard Can It Be?
Abbott Schindler Veteran Member • Posts: 3,099
I've had this happen a couple of times with the 2X. The first time really worried me, but in a second I discovered that just zooming the lens out a bit released the limiter. Not a biggie once you understand what's happening, but really worrisome the first time.
Now I rarely remove the Extender unless the lens is zoomed a bit, and the "problem" hasn't occurred lately.
