Peak Design Clutch Camera Hand Strap for an X-Tn ?
Started 2 weeks ago | Discussions
Veritable Forum Member • Posts: 66
Anyone using the PD Clutch Camera Hand Strap on an XT camera?
How is it? Isn't it too big for the XT? Perhaps better with an added handgrip?
Or can you suggest another hand/wrist strap that's better suited?
I'm looking for a wrist strap for an X-T2/3, with wide & normal FL lenses, for event and street photography. Should be comfortable when carrying the camera with the arm down, i.e., not causing hand fatigue by having to grip the camera constantly.
Thanks!
 Veritable's gear list:Veritable's gear list
Fujifilm XF 30mm F2.8 R LM WR
GreatOceanSoftware
GreatOceanSoftware Senior Member • Posts: 1,222
Re: Peak Design Clutch Camera Hand Strap for an X-Tn ?
Mine is terrible. Once you put it on you wrist, good luck getting the damn thing off. I would choose almost any other wrist strap.
This one is functional, strong and cheap.
https://www.amazon.com/dp/B08RSBWNF9?ref=ppx_pop_mob_ap_share
Good luck!
Randy
 GreatOceanSoftware's gear list:GreatOceanSoftware's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +11 more
RangerPhotog Regular Member • Posts: 303
Over the years, I have tried various hand straps and found I do not like hand straps for this very reason.  On the other hand I do use wrist straps and do like the Peak Design cuff.
 RangerPhotog's gear list:RangerPhotog's gear list
Nikon Coolpix A Fujifilm X100F Fujifilm X-Pro3 Fujifilm X-E4 XF 90mm +9 more
GreatOceanSoftware
Oops. It’s actually the Cuff that I have. It’s like a noose that can only tighten. The Clutch may be ok. Don’t have any experience with that one.
Randy
10sj03 Contributing Member • Posts: 542
The Peak Design clutch doesn’t work well with Fujifilm cameras. With that many dials and buttons in the top plate, your finger won’t reach them when the clutch is on. I like Peak Design products and have many of them. The clutch is the only one I return and get a refund.
Meeces
Meeces Contributing Member • Posts: 561
Check out Cosyspeed strap
I picked up the cosyspeed quick sally not too long ago. I added a peak design anchors to the end to use with the other half of the anchor links that are on the camera to make it quick release.
link to strap- www.cosyspeed.com/en-usacdn/products/quick-sally-die-einhand-schlaufe
Quick phone shot of pd anchor attached to strap.
Matt
http://www.instagram.com/photosbymattjames
http://www.flickr.com/photos/akita/
Fujifilm X-T5 (black and silver). 18mm f/1.4, Viltrox 75mm, 16-55, 50-140, 70-300, and 100-400mm, 1.4 ext. and MCEX-11. X-T2 (paper weight).
 Meeces's gear list:Meeces's gear list
Fujifilm X-T2 Fujifilm X-T5 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR +4 more
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
Thanks!
FWIW - I don’t like their hand straps. I have a T2 and hand carry it along with it having my RRS L bracket …. like you are moving away from. It’s easy for me to carry it that way. I do use the Sling strap and let it hang around my neck. Can carry it that way and then remove the strap to hand carry when wanting to. My answer might not be what you want to hear and your specific use case. Good luck and happy shooting.
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
ChrisGibbons001
ChrisGibbons001 Regular Member • Posts: 234
https://www.cordweaver.co.uk/product-page/cordy-classic-with-peak-design-anchor-link
Cordy strap is perfect imo compared to the peak design strap. Have had both and I couldn't stand how uncomfortable the peak-design wrist strap was (I have giant wrists to be fair).
@bychrisgibbons
@chrisgibbonswildlife
 ChrisGibbons001's gear list:ChrisGibbons001's gear list
Fujifilm X-T5 Fujifilm XF 23mm F2 R WR XF 150-600mm
c0nfund0
c0nfund0 Contributing Member • Posts: 795
6
GreatOceanSoftware wrote:Mine is terrible. Once you put it on you wrist, good luck getting the damn thing off. I would choose almost any other wrist strap.
Good luck!
Are you referring to the Peak Design "clutch" or "cuff" ?
If you're talking about the "cuff" stuck to your wrist I had that issue too and struggled with it cinching so easily.
Then learned you're suppose to pull the cuff all the way to semi-lock it in position. Stays loose on your wrist. Doesn't cinch unless you drop the camera.
https://youtu.be/_hYLeP_crk4?t=122
 c0nfund0's gear list:c0nfund0's gear list
Sony a7R V Sony FE 50mm F1.2 GM Sony FE 24mm F1.4 GM Tamron 28-200mm F2.8-5.6
RustyRus Senior Member • Posts: 1,696
Thanks!
The Cuff is awesome....Not sure what others had problems with but I use it on my Xh2, X100v, XT4 when I owned one, Leica M11 and a Leica MP.
Love it for all cameras. I use it when I want to just hand carry as I walk around and take photos. I would rather wear this then drop a 10K camera and lens on the ground.
Watch the videos on it...Its exactly how it looks.
 RustyRus's gear list:RustyRus's gear list
Ricoh GR III Leica Q2 Fujifilm X100V Fujifilm X-Pro3 Leica M11 +1 more
jonikon Veteran Member • Posts: 7,432
I use a Joby wrist strap that works perfectly. Unfortunately it is no longer available.
Thanks!
Yes. The PD cuff is great. That’s my mostly used strap. I have the slide, slide lite but I always go with the cuff.
Gavi New Member • Posts: 18
5
PD Cuff is great indeed. Online criticism towards it is common, and almost always the root cause is user error. Cuff does not tighten around one's wrist uncomfortably, neither is it hard to remove.
Shadwellal Regular Member • Posts: 152
Another vote for the PD cuff. I use a PD slide and it's really quick to switch between the two. The cuff is great for street photography.
Fuji Maine Senior Member • Posts: 1,702
I have the clutch. The problem with using it on an XT-X camera is that you can't reach the shutter button with your finger if it's tight enough to be able to walk around with the camera at your side in your hand. The XH bodies are a great match with it but unless you want to loosen it or slip your hand out every time you want to take a photo it's useless with the XT's.
GreatOceanSoftware
Good luck!
Talking about the Cuff. Sorry to the OP for mistakenly introducing this sub-thread.
The lock feature is super tight on mine. It takes both hands and almost a pair of pliers to engage it. Using it without it means that it always cinches. And once cinched, if it doesn't amputate my hand, I have to set the camera down and use both hands to take it off (camera is too heavy to pull one side of the strap through the lug).
I guess you could say that once engaged, leave it engaged. But then that makes it just a loop that flops around on my wrist without tightening at all.
The parachute chord models that I use seem to respond very intuitively to whatever weight is on my hand or whatever my hands are doing. I don't even realize it's there most of the time, which is perfect. And the D ring slider doesn't offer any resistance when trying to remove.
Hope that made sense.
Randy
c0nfund0
Good luck!
Guess yours is defective or something got caught/worn? Shouldn't need "pliers" to engage. Only bit extra tug like in the video.
Maybe you are pulling it wrong. Gold the strap with one hand and slide the silver buckle up with the other. It should slide effortlessly up/down, then apply bit extra tug at the end to lock. Can even do this one handed
If you yank/pull the strap with it angled/perpendicular near the buckle it won't lock. Needs to slide freely.
A properly functioning CUFF would unlock with the weight of a camera falling and cinch/tighten.
Just like this video https://youtu.be/B2UaScIb0t4?t=148
Samuraidog Senior Member • Posts: 1,672
I'm not a fan of the pd cuff because I'm obsessive about the condition of my gear. The metal attachment bothers me. I realize it won't cause too much damage, but I don't want to risk it. Instead, I prefer the Paracord with plastic cinches.
I like PD's products overall though.
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
And the loose fitting loop is precisely why I really like the Cuff. Because of way I have the Cuff mounted to the bottom of my cameras (as oppose the strap lug on the side), the loose Cuff just slides down my wrist and hangs out of the way. There is certainly no flopping around.
I wasn't too thrilled with the Cuff at first UNTIL I found that it can be locked opened as such. I do not want or need a wrist strap snuggly around my wrist at any time. I just have on for security from dropping a camera and the Cuff fits that need. It is completely out of way when shooting or walking but if I should accidently drop, it cinches up snuggly. I do not need put the camera down to uncinch. I just put it in the cradle of my other arm and quickly uncinch with the free hand.
Another complaint about the Cuff is the metal clasp.  With the way I have the Cuff mounted, the metal part does not come close to camera and hangs below the camera.  There is no potential marring.
JNR
JNR Veteran Member • Posts: 4,652
I have tried several durable wrist straps that can handle the mid- to large-mirrorless cameras. Best overall for convenience and build are these rope types (various brands available):
https://www.amazon.com/Unisex-Compatible-Mirrorless-Cameras-Photographers/dp/B08RS5HMP4
The rope loop-type strap is just easier to use than straps requiring two hands to cinch up a band around the straps - the band tends to fail under stress. So, I'm agree with GreatOceanSoftware above.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
