Digital 2x and 4x extender
Started 1 week ago | Discussions
RLight Senior Member • Posts: 4,426
Re: Samples
drsnoopy wrote:
RLight wrote:
No Digital TC, SOOC JPEG, Large
2X
4X
Notice the exposure shift on the minimum shutter, smart. Camera shake does become more pronounced at longer focals, even digitally cropped. Canon has a point...
It also makes it easier to see your camera shake, even with IS enabled, so to help you think to stabilize it...
Shot in P, btw.
Thank you, RLight, for these samples. You have effectively answered my earlier question about image size, these are all 6000x4000 so interpolation/upscaling has taken place in camera. There is no visible gain in apparent resolution, to my eyes these look rather like upsampling in Photoshop before “preserve details” or “super resolution” became available. No doubt some users will find these acceptable, particularly the 2x image, depending on their output requirements.
The exposure shift (faster shutter speed, higher ISO) is exactly what P mode would be expected to do, given the effective focal length, no more smart than normal operation.
Yes, except if you crop a RAW/JPEG, the shutter isn’t raised for the desired pixel level sharpness. Also the framing function isn’t used either if cropping. I actually think this feature will benefit the target audience. That said an advanced shooter? Not so much. I may use it ironically. I may be an old fart shooter but it’s effective for being lazy. Lazy can be good.
 RLight's gear list:RLight's gear list
Canon EOS M6 II Canon EOS R3 Canon EOS R50 Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Re: Sorta
John Sheehy wrote:
RLight wrote:
The center of the lens is always sharper, so long as your lens isn’t defective or damaged, yes.
The center of the image circle is usually the sharpest, but the corners of a crop can be softer than the corners of the entire sensor, when both are normalized to the same displayed size. It is a lens-by-lens thing. The center of the image will never be sharper in a normalized crop, though; it will always be softer. That is how I think of it in terms of normalizing for the same image.
Of course, if you are using a mode that uses a fraction of the sensor just to avoid wasted MBs, and would crop from the full sensor, otherwise, then this whole normalization perspective has no practical value.
People need to be aware that crop modes, especially when used with zooms, and especially with fixed-open-f-ratio zooms, can be extremely counterproductive. Let's say you have a 24-105 fixed-f/4 zoom. If you use 25mm in 4x TC mode vs 100mm in full-sensor mode, both at f/4 on a 24MP sensor, the 100mm gives you 100/4 with 24MP, but the 25mm and 4x "TC" gives you 1.5MP at a FF equivalent of 100/16.
It is good to be aware and not use a crop mode or fake firmware TC
Fake? I think it's real John or are you suggesting the Digital TC doesn't exist? How bizarre.
when you don't really need them. Even a real 4x TC would yield 100/16; the only benefit would be 24MP used.
I think this is covered in the thread but these can be helpful to the user and AF purely to magnify the data.
I agree that there are occasions where cropping an image may perform better than an optical TC but maybe the system with the optical TC has other advantages in terms of metering and AF.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
Ephemeris
Re: Samples
2X
4X
Thanks for the images. I hadn't thought of the camera shake. Reminds me of digital cam corders when they came out with a digital X10 button.
Shot in P, btw.
Ephemeris
Re: Samples
I was looking at some of the shadows in the rope between the 3 images and some of the noise patterns around and couldn't see a great deal of change.
drsnoopy Senior Member • Posts: 1,216
Re: Samples
Ephemeris wrote:
2X
4X
Shot in P, btw.
The R50 has 10x digital zoom in HD video!
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
0lf
0lf Senior Member • Posts: 1,283
Re: Samples
2X
4X
Shot in P, btw.
Thank you for the test. Looks OK on a 11’’ ipad screen even for the 4x DTC.
 0lf's gear list:0lf's gear list
Sony RX1 Fujifilm X70 Canon G7 X II Apple iPhone 13 mini
Ephemeris
Re: Samples
drsnoopy wrote:
Ephemeris wrote:
2X
4X
Shot in P, btw.
1920x1080?
I remember or handicams seemed to have. X10 button. A popular favourite on a Saturday nights ITV showing of Jeremy Beadle
davesurrey Senior Member • Posts: 1,846
Re: Digital 2x and 4x extender
John Sheehy wrote:
davesurrey wrote:
A general comment:
I’ve just seen this post and I have to say I disagree with those who are quite adamant that a 4x crop must give 1.5MP resolution. This doesn’t seem to be thinking out the box or considering what DSP technology can do these days.
Here’s a simple example. When CDs first came out I happened to work for Sony and so could get one of their CD players very cheap with staff-sales but I bought one from Philips instead.
Friends were baffled as the Sony used a 16 bit DAC whereas the Philips “only” used a 14 bit DAC. They just couldn’t believe it would sound as good, let alone better, until they heard it for themselves.
The reason was that the Philips used 4x over-sampling so could use a more linear 14 bit DAC (16 bits DACs were not so linear in those days) and the anti-aliasing or reconstruction filters could have a much more gradual pass band leading to far less phase distortion/ripples in the pass band. As a result they just sounded better.
It's rarely wise to underestimate what engineers can do, which may appear to “cheat” the laws of physics.
That doesn't seem like an applicable analogy. The sensor would have to be read multiple times in a row, either slowing the rolling shutter time or doing low-bitdepth readout, to curb noise a bit (eliminate far outliers), but that will not increase resolution. You'd have to shift the sensor to multiple positions, too, to increase capture resolution beyond 1.5 million samples to 24 million, and shifting to 16 positions would be very time consuming.
It wasn't meant to be any sort of analogy, John. And definitely not a suggestion of how this works in the R6ii.
It was just an example of how some folk seem to jump to conclusions without giving much thought as to what might be possible with some clever processing.
Which if you re-read what I wrote you'll see is what I said it was (see quote in bold above.)
Dave
 davesurrey's gear list:davesurrey's gear list
Nikon Coolpix A Panasonic Lumix DMC-ZS60 Panasonic Lumix DC-FZ1000 II Canon EOS D30 Canon EOS M5 +24 more
