Digital 2x and 4x extender
Started 1 week ago | Discussions
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Re: Digital 2x and 4x extender
0lf wrote:
Ephemeris wrote:
0lf wrote:
Ephemeris wrote:
0lf wrote:
Ephemeris wrote:
drsnoopy wrote:
Ephemeris wrote:
drsnoopy wrote:
Ephemeris wrote:
drsnoopy wrote:
If something sounds too good to be true, it almost certainly is. A 4x “digital TC” is only using one sixteenth of the sensor area, so that’s a 1.5MP image. When that is upscaled to 24MP, you’re not going to have “image quality retained”. It’s a trick, pure and simple, more suitable for smartphones than cameras. But then I guess that’s the target demographic.
Maybe it's trying to say this is an improvement over a 4x crop. I think it's that which is the comparison rather than with 4x FL.
Same thing, same issue. 4x crop is the same as 4x “digital teleconverter”. A 24MP R50 sensor with a 4x crop = 1.5 MP image.
The question: is it the same thing. They suggest it isn't the same.
So in camera zoom isn't the same as the equivalent crop after the fact.
So no, not the same.
OK then please explain how it is “not the same”. The R50 has 24MP, no more. If you apply a 4x (which must be squared) you have just 1.5MP to use. If that is then upscaled, it is not using genuine data and there will be artefacts and loss of detail. You can’t change the laws of physics of maths.
I couldn't possibly comment on changing the laws of physics of maths but changing the laws (rules, guide?) Of maths and science is a daily affair.
So what I said is that they (Canon) suggest that taking a 4x crop after the fact isn't the same as what they (Canon) are doing with this digital zoom.
Noone has so far explained how this system operates.
If you take a 4x crop after the fact. The result is A
If I use Canons in camera zoom at a x4 level. The result is B
We display the two images at equal size
The suggestion (Canons) is that A does not equal B
I say again I do not know how this Canon system works, however I would be interested in knowing.
This was not meant to be a test of the feature, so there is variation between the shots, but may be you will find it informative
https://www.dpreview.com/forums/thread/4409591
Given the results with the G7x, I would presume the R50 to give excellent results at 2x.
Thanks Olf. I think your post is a little more helpful that the response you got in the past..
It does appear to be a helpful feature.
Thanks for your post I appreciate it
I just find an old test I made after buying the G7x2
max optical zoom + 2x crop in post
2x digital zoom
Thanks Olf.
Looks like the digital zoom has some noise, almost the type you get from creating a JPEG. What do you think?
yes, there is some artifact from the upscalling. But also it seems the sharpening is a bit more agressive with digital zoom (but imho, it is the cropped image that is lacking in this department). In definitive I think both are good enough to be usable.
I agree. I was looking at the cab of the crane.
Keep in mind this is from a 1inch 20Mp sensor, so not as clean as the R50 sensor
Thanks.
To add a bit mode data, below is the previously posted cropped photo upscalled by pixelmator photo
I think it's (the camera) doing a useful function.
2x cropped and pixelmator photo upscalling
BirdShooter7 Veteran Member • Posts: 9,127
Ephemeris wrote:
BirdShooter7 wrote:
chipman wrote:
Here's a sample of 2x digital zoom from 6 years ago -
800mm eq. from a FZ1000 - 1 inch 20 meg sensor.
Like I said above, about the same IQ as your basic cell phone.
Thanks for this but I thought we were discussing whatever version of the feature is in these latest R cameras and if it’s something more than a simple upscale.
We are. That is more or less the question.
I had thought whilst on my daily rounds if an OEM could use something at the level of Gigapixel AI becuase they now have a multi core AI engine within the ASIC it could be quite a selling point.
If course plenty will disagree with me (which is just fine) but more musing the possibility.
We are leveraging a new system from nVidia Drive Hyperon using a SoC called Atlan. Maybe Canon have something as advanced (this does use quite a bit of juice).
I’ve had similar thoughts and it seemed like it would be an interesting feature to me.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
PicPocket Veteran Member • Posts: 5,897
John Sheehy wrote:
PicPocket wrote:
BrianOdell wrote:
Canon states that this is not simply a crop, and retains quality (jpeg only).
I wonder what that means. Free pixels? Retains 50% quality? JPEG only, so some processing trick. I wonder if that can mean crop and upscale as best as we can
That statement is as subjective as it gets it, unless there is some more detail there
Some people have suggested some kind of AI upsizing, but at the speed that these images can be burst at, it doesn't seem likely that there can be any kind of real "intelligence".
When people start saying AI, it almost always starts to mean different things from context to context. The AI from 10 years ago is perhaps just automation/algorithm today. It's a fancy way to say we have a better algorithm. When it comes to learning models, with today's technology, it almost always means offloading to an online high capacity service, or spending ages running it local. There is no AI in a box as tiny as these cameras - that is, if we can even agree on what AI actually means
PicPocket
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
RLight Senior Member • Posts: 4,426
Sorta
I've used DC on the former PowerShots, its usefulness is limited. Pretty much if you're a JPEG shooter and don't want to /can't touch RAWs or crop in post, sure. And, I'll say the JPEGs on the R50 are pretty good. It's a smartphone-like option that is a gimmick to the point of others. But, I might argue it's actually useful in theory here. I'm pretty happy with the SOOC JPEGs from the R50, enough it could be "worth it". I may give DPP4 a shot now (on those R50 RAWs I have) that I figured out my lens profile issues... Not today though.
It's not "magic" though, it modifies things like your aperture a touch, really it's a no-post crop that does slightly alter your exposure/metering for the center of the image in my experience, but just crops it for you to the point of others, so it's more than what folks around here argue, less than what Canon insinuates, falls in the middle. That's not a bad thing if you intended to throw away the rest of the uncropped image anyways... Now sure, shoot RAW, do it yourself in post. But about that buffer... And folks coming from smartphones are used to this sort of thing too. Not inappropriate for the target audience of this thing. And again, those SOOC JPEGs are pretty good, it's not like you're gonna kick yourself for not being able to raise a shadow and then crop, or change WB and then crop on the R50. That's just not my experience in the past 48 hours with this thing. It's bang on with things like WB and exposure, right out of camera. So yeah, crop away in camera...
BTW, the real help the Digital TC does? Framing and metering. So as I said, it is somewhat useful.
 RLight's gear list:RLight's gear list
Canon EOS M6 II Canon EOS R3 Canon EOS R50 Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
Ephemeris
Indeed. If done well it's a powerful feature set. I'd also thought if it knows which lens and camera (so easy to have that data) it could upscale the sharper (above some limit that a user sets) portion from a lens give the particular F stop, and provide some Tele function.
Ephemeris
Re: Sorta
That's interesting. So it's got a set of functions that it's leveraging.
So it is doing more than you could with just a raw as it's adjusting F stop and metering if I understand correctly.
I should add framing to the above features but sounds a positive option to have.
After all I use 1.6x crop on my R5 sometimes to help with AF, framing and just to help me see a little better.
drsnoopy Senior Member • Posts: 1,216
Re: Sorta
It sounds like you have first hand experience of the digital TC mode on the R50. Can you please give a figure for the size of the output image in pixels? For example, is it 6000x4000 (which implies upsampling) or is it 3000x2000 (for 2x) or 1500x1000 (for 4x)? These figures are not given anywhere in the specs or manual, and are key to understanding how this works.
You mention framing, metering and aperture. The first two make perfect sense, but I don’t see why the aperture should change if for example you’re in manual or Av mode and have set a specific aperture. In other modes, where aperture is the variable set by the camera, the metering may well change it based on the target area.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
John Sheehy Forum Pro • Posts: 26,688
Re: Sorta
Yes, having the extra magnification in the viewfinder can be useful, but the Digital TC concept is not necessary for that at all; the already-existing "crop mode" in Canon FF cameras does that, too.
The only thing that the upsampling really does, perhaps, is create a JPEG that handles subsequent resampling better than a simply-cropped JPEG or crop mode JPEG would.  You could do that yourself before distributing the files or uploaded them somewhere with unknown resampling quality, the camera just does it automatically with the DTC.  There may be a slight benefit to upsampling pixels before committing to JPEG, but the fact of the Bayer CFA does make that benefit quite small, compared to doing that with an image that was previously downsampled or came from a sensor without a CFA, like a 3-CCD video frame grab or a Foveon image.
I called it a gimmick because the name of the mode implies some kind of optical gain, but there is no optical gain.  Canon seems to want to sell these cameras to people based on the false premise that they have something optically better than crops going on, and as a Canon user I am very embarrassed by this deception.  "My 400mm f/8 lens becomes a real 1600mm and is still f/8!".  Many of us have been wishing for more options of crop mode size, or even a continuous crop mode with the zoom ring or control ring, but then they start giving this "raw-less, upsized-JPEG crop mode masquerading as a TC" nonsense instead.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
Re: Sorta
Does anybody actually have the pixel dimensions of the images produced by the “digital TC” on the R50?  Are they upsampled?  Several people above seem to want to think there is “more going on” than a simple crop, upsampled or not.
This is wishful thinking.  It’s impossible to get away from the fact that the 4x “TC” is only using 1.5MP of the sensor area. I’d be surprised if the limited processing ability and battery power available in a small chip in a small camera, could rival what is otherwise done using paid-for software on a high spec computer with graphics processor, cache memory and far more electrical power, yet takes far longer per image.
JohnMoyer Regular Member • Posts: 354
Re: Sorta
It has been a few decades since I paid much attention to image scaling algorithms and I may not remember correctly or newer algorithms may be available. It makes sense to not do upscaling in camera when raw quality is selected since raw implies later processing on a bigger faster computer. If the goal is to get a JPEG from the camera quickly and avoid spending time post processing, then it seems to me that the upscaling in the camera is useful. But, if one is to do post processing anyway then one may choose algorithms that are slower or use more memory on a larger computer than the one in the camera.
As has been mentioned, it is always necessary to do some sharpening after scaling.
Comparison gallery of image scaling algorithms: https://en.wikipedia.org/wiki/Comparison_gallery_of_image_scaling_algorithms
The scaling algorithm that I usually use when down-scaling an image (default for GraphicsMagick) is: https://en.wikipedia.org/wiki/Lanczos_resampling
For upscaling the default algorithm for GraphicsMagick is: https://en.wikipedia.org/wiki/Mitchell%E2%80%93Netravali_filters
Gimp also allows one to choose the scaling algorithm which assumes one knows the tradeoffs among the various algorithms and can choose an algorithm based upon the desired result.
https://en.wikipedia.org/wiki/Image_scaling
http://www.graphicsmagick.org/GraphicsMagick.html
-filter <type>
use this type of filter when resizing an image
Use this option to affect the resizing operation of an image (see -geometry). Choose from these filters (ordered by approximate increasing CPU time):
Point Box Triangle Hermite Hanning Hamming Blackman Gaussian Quadratic Cubic Catrom Mitchell Lanczos Bessel Sinc
The default filter is automatically selected to provide the best quality while consuming a reasonable amount of time. The Mitchell filter is used if the image supports a palette, supports a matte channel, or is being enlarged, otherwise the Lanczos filter is used.
https://gmic.eu/reference/list_of_commands.html#geometry_manipulation
Ephemeris
We use MAX78000 in very small packages (much smaller than an R) and they are optimized for deep convolutional neural networks and can do one and two dimensional convolution processing.
This is a true CNN so it would be said to be AI and AD advertise as such.
Ephemeris
Re: Sorta
No John. It's specifically called DIGITAL and not Optical.
I think the problem isn't with Canon here at all and it's not deception but possibly biased confusion.
Let's not tar a manufacturer incorrectly that's not positive.
It's not nonsense though, far from it. If it's not for you that's just one of those things. I however am interested in finding out more about how this feature works.
John
Re: Sorta
The center of the lens is always sharper, so long as your lens isn’t defective or damaged, yes.
Re: Sorta
The center of the image circle is usually the sharpest, but the corners of a crop can be softer than the corners of the entire sensor, when both are normalized to the same displayed size.  It is a lens-by-lens thing.  The center of the image will never be sharper in a normalized crop, though; it will always be softer.  That is how I think of it in terms of normalizing for the same image.
Of course, if you are using a mode that uses a fraction of the sensor just to avoid wasted MBs, and would crop from the full sensor, otherwise, then this whole normalization perspective has no practical value.
People need to be aware that crop modes, especially when used with zooms, and especially with fixed-open-f-ratio zooms, can be extremely counterproductive.  Let's say you have a 24-105 fixed-f/4 zoom.  If you use 25mm in 4x TC mode vs 100mm in full-sensor mode, both at f/4 on a 24MP sensor, the 100mm gives you 100/4 with 24MP, but the 25mm and 4x "TC" gives you 1.5MP at a FF equivalent of 100/16.
It is good to be aware and not use a crop mode or fake firmware TC when you don't really need them.  Even a real 4x TC would yield 100/16; the only benefit would be 24MP used.
John
davesurrey Senior Member • Posts: 1,846
A general comment:
I’ve just seen this post and I have to say I disagree with those who are quite adamant that a 4x crop must give 1.5MP resolution. This doesn’t seem to be thinking out the box or considering what DSP technology can do these days.
Here’s a simple example. When CDs first came out I happened to work for Sony and so could get one of their CD players very cheap with staff-sales but I bought one from Philips instead.
Friends were baffled as the Sony used a 16 bit DAC whereas the Philips “only” used a 14 bit DAC. They just couldn’t believe it would sound as good, let alone better, until they heard it for themselves.
The reason was that the Philips used 4x over-sampling so could use a more linear 14 bit DAC (16 bits DACs were not so linear in those days) and the anti-aliasing or reconstruction filters could have a much more gradual pass band leading to far less phase distortion/ripples in the pass band. As a result they just sounded better.
It's rarely wise to underestimate what engineers can do, which may appear to “cheat” the laws of physics.
 davesurrey's gear list:davesurrey's gear list
Nikon Coolpix A Panasonic Lumix DMC-ZS60 Panasonic Lumix DC-FZ1000 II Canon EOS D30 Canon EOS M5 +24 more
davesurrey wrote:
A general comment:
That doesn't seem like an applicable analogy.  The sensor would have to be read multiple times in a row, either slowing the rolling shutter time or doing low-bitdepth readout, to curb noise a bit (eliminate far outliers), but that will not increase resolution.  You'd have to shift the sensor to multiple positions, too, to increase capture resolution beyond 1.5 million samples to 24 million, and shifting to 16 positions would be very time consuming.
John
Re: Sorta
Canons trying to sell stuff, although I’m a Canon-fan, not everything they say should be taken at face value. Digital TC is one of them. I have to concur partially with the naysayers, and also inform others that Canon is partially true in their claims. It’s just misleading as the OP is thinking it’s a magic bullet, it’s not. If there was a magic bullet? We wouldn’t need telephoto lenses. As it stands this is the last holdout that smartphones can’t out-compute their way out of. Canon is just making a more efficient out of camera cropping method, but it doesn’t solve lack of reach is lack of reach.
Us forum dwellers are mostly RAW shooting post-processing fiends, but the greater populace still uses a smartphone not even a dedicated camera, can’t do anything windows can’t (in fact I bet this is most people here), and doesn’t even know what RAW is. Digital TC is a good answer for the masses that will either use SOOC JPEG on their computer, or sync to their phone and upload and just wants a magic button like an app in their smartphone.
Samples
No Digital TC, SOOC JPEG, Large
2X
4X
Notice the exposure shift on the minimum shutter, smart. Camera shake does become more pronounced at longer focals, even digitally cropped. Canon has a point...
It also makes it easier to see your camera shake, even with IS enabled, so to help you think to stabilize it...
Shot in P, btw.
davesurrey wrote:
A general comment:
I like your audio comparison, but not sure it’s entirely valid. (BTW I had the early Philips CD104 too). Like comparing a low bitrate mp3 with a FLAC. On some audio systems - and to older ears - they may sound almost the same, on others there is a clearly audible difference.  No matter how you look at it, a 4x crop of the centre of the sensor results in 1.5MP of image data. What you do with that afterwards can improve it subjectively, that is certain. I have been unable to find online the size of the output images - nobody has answered my question here - indeed the only reference I can find is Ken Rockwell on the R6ii stating it’s “interpolated”, no further details given.  The 2x image will be, or be derived from, 6MP.  I know I can make a very good A4 print with 6MP, no interpolation needed.  The 4X TC image will have a quarter as much data and will probably look acceptable on an HD display.  So if that’s satisfactory for a certain demographic of users, then that’s absolutely fine but there is no escaping the underlying principle, even with clever manipulation, interpolation, smoothing, AI or whatever else is involved.
Re: Samples
2X
4X
Shot in P, btw.
Thank you, RLight, for these samples. You have effectively answered my earlier question about image size, these are all 6000x4000 so interpolation/upscaling has taken place in camera. There is no visible gain in apparent resolution, to my eyes these look rather like upsampling in Photoshop before “preserve details” or “super resolution” became available. No doubt some users will find these acceptable, particularly the 2x image, depending on their output requirements.
The exposure shift (faster shutter speed, higher ISO) is exactly what P mode would be expected to do, given the effective focal length, no more smart than normal operation.
