How heavy of lens can R5 Lens mount support?
Started 1 week ago | Discussions
tclardy Forum Member • Posts: 84
I am looking for a solution for carrying my R5 and RF 100-500 lens.  I have tried a cotton carrier belt and it is too heavy.
I have found it is a pain and awkward to carry the combo by attached to the sling or belt using the lens foot.    Puts the camera and lens further away from the strop/belt and gets awkward.  Not too mention I have to remove the attachment device to using my monopod/gimbal.
Does anyone know what Canon recommends as the heaviest lens I can mount on this camera using the tripod mount on the body to attach to the sling/belt without risk of damage?
The 100-500 is about 3 lbs for reference.
Thanks,
Tim
 tclardy's gear list:tclardy's gear list
Nikon Z6 Canon EOS R6 Nikon AF Micro-Nikkor 60mm f/2.8D Nikon 85mm F1.8G Canon 85mm F1.4L IS USM +5 more
Canon EOS R5
Sharpshooter007 Forum Member • Posts: 86
Re: How heavy of lens can R5 Lens mount support?
I don't have any specifications from Canon, but I've used the Cotten Carrier and now use the Cotten Carrier Skout with the R5 and 100-500.  I often have the 1.4 on the combo.  I fasten the camera to socket, not the tripod foot (I don't even have the tripod foot attached to the lens).  No problems and I've hiked many miles.
 Sharpshooter007's gear list:Sharpshooter007's gear list
Canon EOS R5
OP tclardy Forum Member • Posts: 84
Thanks of the reply.    I was looking at the vest but being in Texas the heat will list the use of that full best.  Do you find the scout is okay for this weight?
CameraCarl Veteran Member • Posts: 9,193
The 100 - 500 is not that heavy a lens when you consider other lenses that could be hung from the camera. If you look at sports shooters or if you look at press conferences and government meetings, you'll see professional photographers with the old  full metal bodied 70 - 200 mm f2.8 lenses or 300 or 400mm telephoto fast aperture lenses hung from the camera straps over their shoulders all the time.
I'm in Louisiana, so I understand about the heat concerns.  That's the main reason I bought the Skout, and I love it!  As light as the R5 and 100-500 combo weight in, it does a fantastic job of distributing the weight evenly!  My one and only complaint is more about the inability to retract the lens with the 1.4 extender, but that's due to Canon, not Cotten Carrier.  I'm 72 and use the Skout all the time, unless I'm needing two cameras, then I go with the full version Cotton carrier.
Canon EOS R5
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
The big whites all have their indepndent strap attachments starting with the big 200 and 300mm lenses!
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
Leigh A. Wax Senior Member • Posts: 1,621
I have used Manfrotto CR2 quick disconnect system/s for many years, with release Heads on my Tripod Gimbal, & Monopod head.
With the CR2 Plate attached to the Lens foot, and a Trigger Snap Release attached to my $15.00 MOVO sling strap, I can quickly remove the strap, or just leave it attached, when mounted either on the Tripod, or Monopod.
Works quite well for me.
Tazz93
Tazz93 Veteran Member • Posts: 3,473
Any lens with a tripod mount on it
I think Canon sees it as, if the lens has a tripod mount, the lens is too heavy to consistently be supported by the body mount.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
3 lbs are absolutely fine.
When I carry my 70-200/2.8 II I have the sling strap attached to the plate at the bottom of the camera and if needed I attach the lens to the tripid using the plate on a tripod collar on lens.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Re: Any lens with a tripod mount on it
Quite true, and as to hand-holding it's expected that one would grip the camera, with one hand, with the other hand on the lens.
It's also a matter of balance on a Tripod. or Monopod; a 6-pound lens attached to a tripod at the Camera mount would challenge the sturdiest Ball-head from sagging down.
Karl_Guttag Senior Member • Posts: 1,883
The O.P. was talking about a Cotton Carrier where the lens would be hanging down similar to a camera strap (https://www.cottoncarrier.com/products/grey-skout-camera). In this configuration, the lens would be hanging down as it would with a shoulder strap.
Almost everyone would change the RF70-200f2.8 and RF100-500 off a shoulder strap. The feet for both lenses are easily removable.
It is a different issue when the lens is at a right angle to the body as it is on a tripod. It is also more a matter of balance on the tripod, monopod, or gimbal, so the center of gravity is not so far forward. The RF70-200f2.8 seems light enough that I wouldn't worry about bending the mounting flange and would only use the foot with a tripod or the like.
I use the Peak Design Anchor tabs (https://www.peakdesign.com/products/anchor-links), and I will use one on the tripod foot with the RF100-500, but that is because it makes long lenses hang better with the lens-down.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
Quite true but you still see press photographers and sports photographers carrying them by the camera lugs.
