Jan_K
New Member
Re: R7 with RF 70-200 f2.8 for Wildlife (paired with R5/RF 100-500/1.4x)
Captive18 wrote:
Has anyone paired the R7 with the RF 70-200 f2.8 for wildlife purposes?
I have my R5 paired to the RF 100-500 L w/ the 1.4x Extender attached to get an AOV of 480mm - 800mm. Being as I can’t put the extender on the 70-200 f2.8, I was thinking of putting this on the R7 to obtain an AOV of 112mm - 320mm.
This set up seems like it would cover a wide range of wildlife situations without having to worry about taking on/off extenders.
Thoughts? Personal experience?
I do not have much experience to share, but since owning an R5 and R7 I have went through the thought experiment myself. Partially with another lens combination.
Most of my photography is rugby, where I mostly use my Sigma 120-300 f2.8 and 70-200 f2.8. I used the 120-300 on a R5 and the 70-200 on a R6, while the lesser MP's of the R6 would better be used for more close by action.
I recently added a R7 to my kit and for now I try to shoot the 120-300 on the R7 'acting' like a 192-480mm and the 70-200 on R5. That gives me 70-480 range to use.
I also have the 100-500 and there I would add the 100-500 to the R7 (acting like 160-800mm in FF equivalent) and the 70-200 on the R5, covering 70-800 range. I think that would be a more usefull range than the 112-320 and 420-700 you would get with the RF100-500 + 1.4x on the R5 (note: you stated 480-800 in your post, but 1.4x on that lens for FF would be 420-700, given the lens should be zoomed to at least 300mm to add the extender.
The only reason I see to do it differently is when the light is poor and your want the dimmer aperture of the RF100-500 + 1.4 on the FF camera, so you could should lower f-stop on the crop body R7. Whether the ISO performance of the R5 and 1.4x versus the R7 with the bare lens would be significant for your use cases I can't tell. (And I don't have use cases from my own experience in this respect).
