R5 + 28-70 F2.0 child's party
Started 1 week ago | Discussions
thunder storm Forum Pro • Posts: 10,139
Re: R5 + 28-70 F2.0 child's party
Ephemeris wrote:
thunder storm wrote:
RLight wrote:
I understand. In sure I will come away with some one eye in focus and one eye outside the DOF.
No, f/2 is fine for one person, just not 2 or more.
My maximum is 2 with 40mm & f/1.4. With a little bit of practice you can always get 2 points in the plain of focus by moving yourself. With 3 points you're out of control
Just so I understand. Your moving to adjust the angle such that 2 points seperated (say a point on one person's eye and another person's eye) stay in focus?
Yes.  The eye of person A is tracked by the AF, and the eye of person B is kept in focus by adjusting the angle. It's not easy, but it isn't completely undoable either.
With 2 persons you can capture eye contact expressions. Worth it!
That's a nifty idea.
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
Although not the best example may be this helps. By swinging the sensor plane you can adjust the focused plane to accommodate both sets of eyes within the DoF.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Ephemeris
OP Ephemeris Senior Member • Posts: 1,186
Makes sense and something I will practice. I can imagine the benefits so thank you for the idea.
If it all goes wrong I know how to contact you 🙈
Ephemeris
Great example these children are not to dissimilar age. Nice outfits.
Ephemeris
Joe Reynolds wrote:
>>>Will FV honor min shutter speed?
Absolutely. It’s all I shoot. Used that setup last night in fact.<<<
FV mode will not honor min shutter speed set in Red/2/ISO Speed Settings in menu. Works only in P and AV mode as noted in the Info text
Thus the only option is Orange/2/Set shutter speed range
However this presents other issues for some. Fair amount of discussion of this in the past .
I like the use of the front dial in FV mode for exposure compensation. However, I see no way to to use the front dial for ec in AV mode
So with it set how does one 'unset' it quickly if needed?
I can see it could work well for me at said child's party.
If I was in Av rather than Pv what may be the best option?
Joe Reynolds
Joe Reynolds Regular Member • Posts: 326
Fastest way to change might be two custom settings.
Or just set the shutter to a specific speed in FV mode, depending on lighting and subject movement,  rather than leave on auto.
Ephemeris
Hi Joe.
I think the Fv route and take out of Auto is likely to give me what I need and be flexible.
Well, the party is tomorrow so let's hope I don't forget to take the lens cap off 😀
I've put the lens hood on.
Hi Joe.
Great capture, and focus is close enough to perfect for sure!
The girl on the left has the right eye in focus, while I would prefer the left eye to be in focus, but that's nit picking.
You're welcome!
Ephemeris
Hi Joe.
It's okay I've turned long exposure noise reduction on 🙈
Canon_Guy
Me too . But imagine that situation - two 4 years old besties at the children Haloween party... Stopping them from romping around for even a 1 second was a hilarious act. So it was one chance shot. Catch the eye of one of them, adjust the focal plane to so so fit the other and fire. Shutter blades did not even return fully and ladies were gone again .
Sittatunga Veteran Member • Posts: 5,406
that's going to slow your frame rate down. It works by taking a second dark exposure work the shutter closed for the same exposure time and subtracting it from the light one. Normally it's used for >1s exposures.
Ephemeris
If you take a read up this is linked to leaving the lens cap on.
It's a joke. 😀
cpharm86 Senior Member • Posts: 2,742
Hi Joe.
Hope you can post some results.
Ephemeris
cpharm86 wrote:
Hi Joe.
I will, as long as the only laughing is within the image.
The result is VERY acceptable.
My youngest is 7 now, and the AF systems are tortured a little bit less than 3 years ago. The other one is 10 and asks if I can take a picture and starts posing spontaneously. So I'm asking myself if it's a wise thing to invest a whole lot more money in fast AF-ing lenses and bodies, as it might not be a very long term investment....
Panta rhei....
R2D2 Forum Pro • Posts: 26,541
Ephemeris wrote:
Hi Folk
Lens finally arrived but haven't had chance to use it myself as I've been travelling.
Loons quitea big tool.
I will be at a 3 year old child's birthday party on Saturday where I will be camera man.
I would appreciate any tips on settings to help me grab photos of this child and her friends party.
For example tracking settings and any advice on the shallow effects of the F2 aperture.
Thanks folks in advance
Hope I'm not too late for the party!
Move a lot!
Show the kids their images on the LCD. They'll love it.
Don't wear a neck strap (camera should be up and at the ready 100% of the time).
Shoot wide open whenever you can.
Stop down when needed (photos will still have nice character).
Shoot (silent shutter) bursts.
Turn off Exposure Simulation in low light.
Use Eye AF with "Focal Point" Initial (not Auto Initial).
AF Case 2.
Lock focus if needed, then use the "lean" technique to place your focal plane.
Avoid using flash if you can (it annoys your subjects).
Set up better ambient lighting instead.
Shine a big LED lamp up into a corner.
Shoot RAW and process with DxO PL6.
Enjoy!
R2
Ephemeris
R2D2 wrote:
Ephemeris wrote:
Hi Folk
Nope hasn't started yet. I'm still at the cleaning stage🤣 why do we clean before a kids party? Madness.
Move a lot!
Got that
Got that
Got that
Got that
Understood
I'm ECFS shooting?
Okay - I've read many things but for the sake of dragging up old dead wood why do you do this? (If I ask you you can't be wrong 🤣)
Got that
AF Case 2
Got that
This sounds a great idea.
No flash today
Have some LED work lamps for upligjtibg
Got that
Adobe and Topaz are what we have. Usually shoot RAW + JPEG
Enjoy!
This is the most demanding request you have made so far 🤣
R2
Hope the travels were okay and thanks for the hints and tips.
Oh - freshly formatted cars.
Ephemeris
Just recovering from Chicken Pox
