Neutral vs. Standard
Started 1 week ago | Discussions
Peter Slovakia
Peter Slovakia Contributing Member • Posts: 716
Ted, Don .. I'll put 3 photos from the DP3 Merrill in a new thread:
1. neutral mode
2. standard mode
3. standard mode corrected in HSL - green-blue (cyan) + 100 to blue
that is what i mean.
Ted, it's just a small thing, maybe it doesn't need to be paid too much attention to..it's just that I noticed it the most with DP Merrill..
neutral
standard
standard + HSL
corrected in HSL in Lightroom
Please look at the sky in all the photos, the blue is not the same in neutral and standard mode.
Do you have a similar experience? Peter
 Peter Slovakia's gear list:Peter Slovakia's gear list
Sigma DP3 Merrill Sigma SD1 Merrill Sigma sd Quattro +3 more
Sigma DP3 Merrill
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: Neutral vs. Standard
1. neutral mode
2. standard mode
so that you understand what I mean.
Ted, it's just a small thing, maybe it doesn't need to be paid too much attention to..it's just that I noticed it the most with DP Merrill..>
Ted, please look at the sky in all the photos, the blue is not in the neutral mode and the standard is the same.
OK, Peter, I looked with my screen color-picker ...
Hue, Saturation, Brightness
Neutral: 213 deg, 51%, 68%
Standard: 209 deg, 51%, 67%
HSL Edit: 211 deg, 50%, 50%
With my poor color vision, barely any difference between Neutral and Standard, sorry. Your color vision must be excellent!
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Scottelly
Scottelly Forum Pro • Posts: 18,026
1. neutral mode
2. standard mode
neutral
standard
standard + HSL
I'm trying to understand what this thread is about. Are you saying that the blue color of the sky looks to be  the wrong color?
Have you experimented with adjusting the white balance setting?
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Peter Slovakia
OP Peter Slovakia Contributing Member • Posts: 716
Peter Slovakia
Ted, thank you for the color measurement.
Peter
D Cox Forum Pro • Posts: 32,979
1. neutral mode
2. standard mode
I see a difference when the two images are both on the screen together. But it isn't a big difference.
Don
Sigma fp
rick decker
MOD rick decker Forum Pro • Posts: 19,097
Poor color-perception photographers of the world unite!!!   Down with color and up with black and white....
It is a tough job living in Hawaii but somebody has to do it.
http://www.lightreflection.com
http://www.rickswavepics.com
larryj Forum Pro • Posts: 13,086
Here, here Rick, I'll drink to that!
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
Peter Slovakia
As you can see, the color of the sky in neutral and standard mode is not the same, in standard mode it is more green-blue than in neutral mode (it is not a fundamental problem, but it is a difference). The difference is most visible in the images processed from DP Merrill.
I was surprised by this discovery of mine a few years ago. Of course, the difference can always be corrected in at least two ways in HSL.
With this, I wanted to point out that even if the standard mode is considered to be color "balanced", it may not be true. It depends on which color of the sky is closer to someone - the color in neutral mode is closer to me. Color modes may not match our color perception. I will give two more pictures so that you can see the difference..
neutral
standard
No need to expand this thread further. It's just my observation that I wanted to share with those who notice the difference..
Thanks for paying attention. Peter
OOPS.. so I don't leave anyone out
BW
This is certainly something to watch out for when processing images.
I think in almost all cases, the exact colour of the sky is not important for the success of a picture, but there will certainly be some landscapes where it matters.
Back in 2015 -- 2016 I did a lot of shots of clouds, and processed them in Foveon Blue mode. The aim was to get a good contrast rather than accurate colour. I wasn't aiming for meteorological exactitude.
Swift:
Don
Sigma fp
josepmg Regular Member • Posts: 157
DPREVIEW_sdQH_SDIM0046.X3F
SPP_Daylight_The whole center
Neutral
Standard
For the revealed I stay with "standard" "neutral"
Peter Slovakia
Thanks for your response, josepmg.
xpatUSA
Well done, José!
Now the differences can be measured ...
Peter Slovakia
In the Neutral mode, I add the orange color and in the Standard mode, I reduce the contrast and fine-tune the blue color of the sky. Both mods can be tuned very well and the result is excellent. But in Neutral mode I like the blue and green colors more, they seem more realistic - in Standard mode there is a lot of orange/red (photos attached) mixed into the green and the trees are reddish. Shadows and highlights are better rendered in Neutral mode, the contrast is not as aggressive as in Standard mode.
neutral
standard
Peter
Iain G Foulds
Iain G Foulds Veteran Member • Posts: 5,647
… Peter: You have an excellent eye for subtle colour. Thanks for sharing your insights.
... “Beginner photographers handhold, more experienced use tripods, but serious photographers use serious tripods.”
 Iain G Foulds's gear list:Iain G Foulds's gear list
Sigma DP1s Sigma DP2s Panasonic Lumix DMC-LX5
JL Salvignol
JL Salvignol Senior Member • Posts: 1,858
Peter this thread is subtle and very useful to former Merrill users. 👏
JLS
 JL Salvignol's gear list:JL Salvignol's gear list
Sigma DP2 Merrill Nikon Coolpix A Nikon 1 V1 Nikon 1 J1 Pentax K-01 +26 more
Peter Slovakia
Thank you Iain. I am very glad if it is at least worth noting. I like "pure colors", it's my personal vision of colors, maybe someone else doesn't see it the way I do.. I like your colors in photos, I always like to look at them.
Peter
PS: I apologize for the first photos, the photos are dark. These last two are already OK.
Peter Slovakia
Thank you for your response JL S. Yes, this applies primarily to the Merrills.
Peter
