Depends on what you’re shooting
drunkenjitsu wrote:
I have an R6 Mark ii with the 100mm 2.8 macro and was considering the Canon mr-14ex ii macro ring lite second hand which I could pick up for around $250 with a 6mo warranty.
I was wondering if any of you more seasoned shooters here use these, and if you think it's a worthwhile investment. Thanks!
I find ring lights to be fine for certain limited uses. The lighting is very uniform, which is good for cataloging coins, stamps, or small figurines.
For most subjects, I find ring light to be monotonous, flat, and boring.
The Canon can "split" the ring and give you some control of the lighting, but it's not that much. Even if you mask off parts of the ring with tape, you're still limited to a small family of frontal angles.
I like to use small, independent flashes so I'm able to move the lights around on goosenecks or swing arms. That way I can use any portraiture lighting technique, including things like rim lighting or top lighting.
My weapon of choice these days are a pile of tiny Godox/Flashpoint MF-12 flashes. I have four flashes (purchased as two sets of two) and for quick work I can put anywhere from one to four on a lens mounting ring, but for more creative work I've rigged a bunch of goosenecks to put them almost anywhere.
A set of 2 flashes and a ring retails for $250, and I've seen them on sale as low as $150. It will take you a while to outgrow that. You'll also need a controller, which tacks on $30-60. I use the more expensive version because I like larger displays and dedicated controls. One controller can run 6 flashes on the ring or an unlimited number on goosenecks (you have to group some of the flashes, because you're only allowed 5 groups).
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
