EOS R3 "Custom high-speed continuous shooting" menu item grayed out
Started 1 week ago | Questions
Dave Chaplain New Member • Posts: 9
Fairly new here - camera set to Manual 1/1000 f2.8 Auto ISO with RF 70-200mm 2.8 lens and Flicker OFF.  Current drive mode is H+.  The HC drive mode is grayed out / unavailable.  Never used HC mode before.  No mention in the updated online manual of what might prevent HC from being available in the menu.  Anyone else seen this problem or a reference to it?
 Dave Chaplain's gear list:Dave Chaplain's gear list
Canon EOS R3
koenkooi Contributing Member • Posts: 920
Re: EOS R3 "Custom high-speed continuous shooting" menu item grayed out
Is the battery fully charged?
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
OP Dave Chaplain New Member • Posts: 9
I found the answer in a DPReview article on the firmware version 1.2.0 that delivered the new HC drive mode -
"The new Custom High speed Continuous is disabled by default, so you must enable the 'Custom high-speed continuous’ drive mode in orange 'Custom Functions' Menu, Tab 3 'Restrict Drive Modes.' Once you've enabled 'HC,' it can then be selected in your drive settings."
Thank you DPReview!
Canon EOS R3
Yes, and thanks for the response.  See my latest response for the fix I found ...
Canon EOS R3
expro Senior Member • Posts: 2,273
This is surprisingly true for many factory settings including drive modes and even custom modes….
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
RLight Senior Member • Posts: 4,418
I’ve never tried it on mine, but I believe it’s limited to TV mode.
Also, you have to use electronic shutter for the highest drive modes. Are using mechanical, EFCS, or electronic? I highly recommend electronic for most use cases.
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
