Are Fuji JPGs deterministic?
Started 3 weeks ago | Discussions
kdarwin-photo New Member • Posts: 11
Take multiple frames of the same scene with the same lens, same settings.  Are the resulting .jpg images the same?  Or do they vary in color/contrast/whatever?
While doing some testing shortly after getting my X-T3 I seem to recall that I got variation between jpg frames but the raw files when processed with the same setting in CaptureOne were consistent.
I have not tried to repeat the experiment but may if I get a chance some day.  Just wondering what you have seen.
Fujifilm X-T3
Erik Baumgartner Senior Member • Posts: 6,894
Re: Are Fuji JPGs deterministic?
Unless you were shooting with some sort of bracketing mode or Auto-DR mode, if the RAWs look consistent, the jpegs should be consistent too (but not identical).
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
orlovsn Regular Member • Posts: 201
8
Every time you release shutter button - your exposure and white balance metering are lost, every time you start pressing that button - you have new expo and wb so - no, they are not perfectly identical most of the time
sometimes you move your lens just a bit between shots with af point moving from bright object to dark one - if your ae is sticked to af point (by default) your pictures start to looks different
this is normal for every camera, to keep files identical you need external spot metering and manual white balance
michaeladawson Forum Pro • Posts: 18,315
Even spot metering is not going to give you the same look in all the files.
The only way to absolutely guarantee that the photos are identical is to be shooting a static lab test scene where the camera is on a tripod (locked in position), the lights are controlled, and the camera is in completely manual mode for all settings.
Of course, no one is shooting that.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D7200 Nikon D5 Fujifilm X-T2 Nikon D850 Fujifilm X-E3 +39 more
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
What do you mean by the same?  If you mean if you loaded two such jpegs into a computer and subtracted one from the other the results would be zero - no. First there are too many variables.  While the lighting might be close it will not be the same.  The exposure and WB - unless set manually are recalculated on each shot.  Then there is noise that is independent from shot to shot. Not even two raw images are exactly pixel to pixel the same.   Jpeg is a compressed format and slight differences will result in slight differences in the compression.
If you mean that the output images will appear for all practical purposes to a viewer at a normal viewing distance they should look the same.
When you load the raws and process in Capture One, LR, etc. using common settings for all shots, WB, exposure adjustments, etc., a few variables are removed and jpegs exported might be closer but I don't expect anyone would notice it.
"The winds of heaven is that which blows between a horse's ears," Bedouin Proverb
__
Truman
www.tprevattimages.com
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Chris Dubea
Chris Dubea Senior Member • Posts: 2,199
https://www.merriam-webster.com/dictionary/deterministic
'jus sayin'
Chris
 Chris Dubea's gear list:Chris Dubea's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
emirco
emirco Junior Member • Posts: 44
'jus sayin'
wrong link. Should point here:
 emirco's gear list:emirco's gear list
Fujifilm X100F Olympus PEN E-P1 Sony Alpha NEX-5N Fujifilm X-E3 Fujifilm X-T4 +15 more
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
5
'jus sayin'
That’s not exactly the definition used in this context - this might be better - we’re not discussing philosophy
https://en.wikipedia.org/wiki/Deterministic_algorithm
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
'jus sayin'
I suppose the grammar lessons might be marginally useful to some folks here, but I really think the OP was pretty clear on what information he was looking for.
Might I gently suggest that we keep the discussion focused on the question posed in the first part of his post rather than turning this thread into a Grammar 101 lesson, please?
Thanks in advance.
Jerry-Astro
Fuji Forum co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
5
Greybeard2017 wrote:
'jus sayin'
Based on that definition I'd say that the output from Fuji (and every other camera manufacturer) is deterministic.  Given the exact same input you will get the same output.
The problem?  You will never get the exact same input so you really can't prove it one way or the other.
Mike Dawson
Truman Prevatt
'jus sayin'
In reality a camera sensor does not capture the same values at for multiple shots of the same scene because there is randomness involved in the data - photon shot noise and electrical noise. Clearly the exact same numbers on the post ADC side will be processed the same. One the other hand the same light energy profile illuminating the detectors will not result in identical numbers on the post ADC side.
__
Truman
Truman Prevatt
'jus sayin'
While that is well and good and it is nice that some can use a dictionary, the concept of determinism in physics was a mistake. It started to become well established starting with Einstein’s explanation of the photoelectric effect, that determinism was not a property of the real world.
https://link.springer.com/article/10.1140/epjh/s13129-021-00012-x
__
Truman
'jus sayin'
That's all well and good, but I don't think the OP was probably looking for that level of nuance. His RAWs were consistent enough with the same processing, but his SOOC jpegs were not. Auto-WB, Auto DR, or a bracketing mode could affect the SOOC jpegs significantly, but not necessarily the RAWs with identical development settings.
Pocket Lint Senior Member • Posts: 2,540
'jus sayin'
How can light be both a wave and a particle in what seems to be both at the same time. Still boggles my mind every time I think about it.
The universe is full of mysterious paradoxes waiting to be discovered, revealed, solved, questioned, only to reveal more questions…
 Pocket Lint's gear list:Pocket Lint's gear list
Canon EOS 5D Mark IV Fujifilm X-Pro3 Canon EF 50mm f/1.2L USM Canon EF 100-400mm F4.5-5.6L IS II Fujifilm XF 23mm F2 R WR +5 more
Richard Butler
Richard Butler dpreview Admin • Posts: 2,911
9
<waves />
Richard - DPReview.com
Truman Prevatt
'jus sayin'
I’m not really sure we know what he is asking since the question was - same scene, same lens, same settings (which means auto WB, DR, sharping, etc) are the jpegs identical. If everything is identical- the only difference is result to the fact the lighting was not exactly the same or randomness.
Clearly is one image in camera was generated with Auto DR and the next with auto DR off then the out of camera would likely be different but the raw could be processed to produce comparable jpeg exports. However, that is not the same settings.
__
Truman
OP kdarwin-photo New Member • Posts: 11
OK, OP back here - I noticed it while testing some lenses.  I'm pretty sure I was set to AWB and shooting aperture priority mode.  What I remember seeing is that the raw files on several shots all looked the same but there was noticeable variability between the jpgs.  Enough that it could make me think the lens had color shift at different apertures.  Yet those raws when given the same processing recipe all looked the same.
My 1/2 baked conclusion is that AWB may vary a bit and if I want to really compare one lens to another I had better be looking only at the raw files.
I have not tired to duplicate the results.
If you use the "as shot" WB values, you should see any AWB differences with the RAWs as well.
Truman Prevatt
'jus sayin'
The discovery around black body radiation - bid goodbye to the concept of "pure waves." The discovery explanation verified many times which won Einstein his Nobel - was the beginning of quantum mechanics. The world is not comprised of two dichotomies - one being particles ( a big set of marbles in a bag ) and waves. For example the electron which has mass - also acts like a wave.
Even the discovery of electromagnetic radiation started the process of ripping the bandage of the of a deterministic physical universe. How can something be a wave - when there is nothing to "wave in."
The problem is really more having to do with people trying to related concepts to things that are common to them. On the other hand Richard Feynman was I think correct. "Their "paradox" is only a conflict between reality and your feeling of what reality "ought to be." Or maybe Neils Bohr is the right reference, "Everything we call real is made up of things that cannot be regarded as real."
What quantum mechanics tells us is "nothing exist until it is measured!"
https://theconversation.com/explainer-what-is-wave-particle-duality-7414
__
Truman
Truman Prevatt
Thanks for the clarification.  Minor changes in light can change how AWB modifies the scene and could in fact change the in camera jpeg a little.  For example if the sun goes behind a cloud the scene is not lite by more skylight (blue) than white light. AWB would compensate for that.
On the other hand if you shoot AWB Capture one will open the Raw and apply the settings you had in the camera.  You can change them and the Raw is not modified in camera because of this but when they are opened, the camera settings will be used as default including film simulation.
Your conclusions are correct, if you want to compare lenses, look only at the Raws but also applying the same settings in Capture One.
__
Truman
