nnowak
Re: EOS m underwater/ water proof solutions
Psxpetey wrote:
I’m looking at getting into it starting at no more than 4m maybe 5 max. Anyway I’m aware of the light I believe I stated the m50 first and then asked about the m100 I did not state this was specifically for the m100 I’m curious about options and systems.
You never mentioned the M50, only M100
There are some housings available to fit the M50, but you will also need the corresponding port to match your lens.
the frog one used to have cases for 250$ which would be awesome but when they released stuff for newer systems now it’s 500-780 which is pretty mental
Those cheaper housings are typically only for compact cameras with fixed lenses. As soon as you go to interchangeable lens cameras, you generally need a housing with interchangeable ports in order to match the lens you are using.
These are low volume items, and you generally get what you pay for. The last thing you want to do is try to save $100 on a housing only to have it leak and destroy your $3900 R5 with a $2400 15-35mm f/2.8 attached.
I’ll probably start with a bag with a lens holder for say 2-3m
This would be a good short term solution. The 22mm would probably be the best lens to use starting out. The Sigma 16mm f/1.4 would be another good option.
Alternatively, an Olympus "Tough" camera or Sony RX100 series in a dedicated housing would be good starting points too. With so many people dropping DSLRs and upgrading to mirrorless, you might be able to find some deals on a used housing and corresponding DSLR kit.
this would be for choral photography in shore branching into other things later
apparently this is not common so I doubt I’ll see any options or reviews
If this will be a long term endeavor, I would suggest that the M system might not be the best starting point. The biggest problem is the lack of wide and bright lenses. Think if something along the lines of a 15-35mm f/2.8 on full frame. The other problem is general support for the system. For example, B&H lists 15 different housings for the R5, but only one for the M50. With Canon phasing out the M system the relatively small number of options that are available for the M system will get even smaller.
You might get some more comprehensive answers over in the underwater photography forum - https://www.dpreview.com/forums/1063
