My PC can't see my pics on one of my SD cards
Started 3 weeks ago | Discussions
jonikon Veteran Member • Posts: 7,433
I recently bought two SanDisk 128GB 177MB/s Extreme Pro SD cards and one of them can not be read by my PC.  It can't even find it when I put it in the slot, However, I can see the images in my X-T2. Is there a fix or should I just toss that card?
I've been using SanDisk cards for years without a problem, which makes me wonder if this is a one-off bad copy, or a new QC problem with SanDisk memory cards?
Fujifilm X-T2
Morris0
Morris0 Forum Pro • Posts: 32,181
Re: My PC can't see my pics on one of my SD cards
The first thing I would try is formatting that card in your camera.   This is the first thing that should be done with any new card.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
OP jonikon Veteran Member • Posts: 7,433
Morris
Thanks, but I did that first thing. . I'm not sure it's relevant but one  thing I noticed was that the troublesome card was made in Maylasia, while all my previous SanDisk were made in China.  Probably best to just bin the troublesome card and hope my other cards stay good.
jnat Senior Member • Posts: 1,508
Might be a longshot, but carefully clean the contacts. I'm sure they look bright, shiny, and new, but a very slight speck of dust can have an affect. Couldn't hurt. Good luck.
 jnat's gear list:jnat's gear list
Panasonic Lumix DMC-GX8 Fujifilm X-E2S Panasonic Lumix DMC-GX85 Canon Pixma Pro-100 Nik Silver Efex Pro +2 more
KennyXYZ
KennyXYZ Contributing Member • Posts: 567
Try a different card reader.
 KennyXYZ's gear list:KennyXYZ's gear list
Fujifilm X-T4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR +2 more
baobob
baobob Forum Pro • Posts: 18,248
Only a problem of initialization of the Sd card Put the card in the computer then in parameters of the PC ask for Disk management In the window you now will see the card.
In Action, all, choose format then choose the type of format as exFAT instead of probably the one that was use (frequently NTFS)
The card is now ex Fat and can be read normally
Sorry my system is in french so may be my english translation is not enterely correct for the system That should do it
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
baobob
Have a look to
https://www.dropbox.com/s/faqcn1i9adhlyvz/How%20to%20initialize%20a%20Sd%20card%20that%20is%20not%20visible%20on%20the%20computer%20PC%20Win%2010.pdf?dl=0
21William Contributing Member • Posts: 866
That’s what I’d do.
In the past I’ve managed to open media on a Mac that wouldn’t open on a PC so it would be interesting to see if anyone you know with a Mac can see the contents of the card? I don’t suppose it helps you much except perhaps something on you PC needs updating?
 21William's gear list:21William's gear list
Pentax K-5 Fujifilm X-H1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS
biza43 Forum Pro • Posts: 15,074
If you can see the images in the card in the camera, then the card seems to be ok. I suggest you connect the camera to the PC and transfer the images from the card.
Then reformat the card in the camera and see if it works.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Morris0
Morris
I'd exchange the bad card with SanDisk.  It may take some time.
Morris
Thanks. I'll give that a try. Strange that I've only had trouble with this one card.
