Wide vs. Ultra Wide for landscape?
Started 2 weeks ago | Discussions
Jeffry7 Contributing Member • Posts: 898
Hi folks,
I have been thinking of getting a wide angle zoom for landscape use. Maybe a 14-24.
I generally do landscape with the 24-105 at the wide end, or a 20 prime.
It seems like there must be tradeoff in going wider, but I am not sure. For instance, wider will take in more of the scene and require fewer shots for a pano, but wouldn't also 'condense' your detail? After the sensor isn't changing.
Are there other problems with ultra wide?
Other advantages?
For what it is worth I would be doing the shots with a sigma sdqh.
furtle
furtle Senior Member • Posts: 1,572
Re: Wide vs. Ultra Wide for landscape?
Jeffry7 wrote:
Hi folks,
Other advantages?
The dp0 Quattro is an excellent landscape camera. Exceptional 14mm lens (21mm eq). I often use it in portrait mode for stitched panoramic photos. The advantage is you get plenty of sky in which I really like when the clouds are good.
I know you are asking about a lens but this could be a viable alternative.  It’s lighter than the wide Art lenses
Best, Steve
 furtle's gear list:furtle's gear list
Ricoh GR Digital III Sigma DP2 Merrill Sigma dp3 Quattro Sigma dp0 Quattro Sigma sd Quattro H +2 more
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Jeffry7 wrote:
Hi folks,
It seems like there must be tradeoff in going wider, but I am not sure. For instance, wider will take in more of the scene and require fewer shots for a pano, but wouldn't it also 'condense' your detail? After all, the sensor isn't changing.
One problem for me with the Sigma 8-16mm at 8mm was determining where the focus was in the scene - might  be easier on the Quattro with it's focusing aids.
Another was the huge depth-of-field relative to the scene ... a longer lens allows more obvious separation of a subject from it's background.
If you get an 8-16mm you will often forget to remove the hood at 8mm which can give you unwanted vignetting.
Other advantages?
More perspective distortion for trick shots.
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
dpreviewblog
dpreviewblog Contributing Member • Posts: 544
Jeffry7 wrote:
Hi folks,
Other advantages?
There's not much to choose from, especially considering that it will be the SD Quattro H
I'm using now for Sigma SDQ H - Sigma 14-24/2.8 Art. IMHO - the optimal and the best choice, But there is may be an "issue" with quite expensive filters. Now I have - Benro FM150M2S5 Filter KIT + additional filters - ND/CPL150x150mm / GND150x170mm
Before buying 14-24, I used for wide-angle shots the Sigma Dp0 Quattro.
Also I have 18-35/1.8 Art - no vignetting without lens hood, but I don't like the resulting images with excessive micro-contrast. Now the lens is for sale.
 dpreviewblog's gear list:dpreviewblog's gear list
Pentax smc FA 31mm F1.8 AL Limited Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp2 Quattro +13 more
OP Jeffry7 Contributing Member • Posts: 898
dpreviewblog wrote:
Jeffry7 wrote:
Hi folks,
Other advantages?
I have a Canon fit sdq as well. Another forum member had it modified from the SA mount and I purchased it from them. There is a Canon L mount 17-40 that is relatively inexpensive but well regarded. Possibly because it is F4 and there are a lot of them out there.
Either way, I could use the lens on my Panasonic S1. But this is a Sigma forum, not L-Mount.
xpatUSA
Jeffry7 wrote:
dpreviewblog wrote:
Jeffry7 wrote:
Hi folks,
Other advantages?
I didn't know that Canon makes L-mount lenses. This 17-40mm f/4 is EF mount:
https://www.imaging-resource.com/lenses/canon/ef-17-40mm-f4l-usm/specifications/
dpreviewblog
Jeffry7 wrote:
dpreviewblog wrote:
Jeffry7 wrote:
Hi folks,
Other advantages?
I purchased 14-24/2.8 SA on Amazon in November for $849
IMHO... The main nuance is that the optics must be the Hi-Res and adapted to a very high-quality and detailed images from SDQ H sensor. And this applies primarily to the line of Art optics from Sigma. The 14-24 is optically great even around the edges and is designed for high resolution sensors (as opposed to the 17-40).
https://www.sigma-global.com/en/lenses/a018_14_24_28/ - "Designed to team up with 50-megapixel-plus cameras and offer top-level optical performance throughout the zoom range ..."
In addition, fast optics (2.8) will not be "superfluous" for the Foveon sensor, which perfoms only at low ISO's
xpatUSA wrote:
Jeffry7 wrote:
dpreviewblog wrote:
Jeffry7 wrote:
Hi folks,
Other advantages?
Your are of course correct. What I meant was the Canon L series. L being how they denote their more professional lenses.
Karl Huber Contributing Member • Posts: 817
Jeffry7 wrote:
Hi folks,
Other advantages?
I very rarely use wide angle lenses for landscapes. You wind up with a heap of foreground and very little detailed background.
 Karl Huber's gear list:Karl Huber's gear list
Sony RX100 Nikon 1 V1 Olympus PEN E-P5 Nikon D850 Nikon Z7 +25 more
xpatUSA
Jeffry7 wrote:
xpatUSA wrote:
Jeffry7 wrote:
dpreviewblog wrote:
Jeffry7 wrote:
Hi folks,
Other advantages?
A pity that, Jeffry, because I suspect that you now know that the EF-mount is the same distance from the sensor as the SA-mount meaning that an adapter is unlikely to exist.
xpatUSA wrote:
Jeffry7 wrote:
xpatUSA wrote:
Jeffry7 wrote:
dpreviewblog wrote:
Jeffry7 wrote:
Hi folks,
Other advantages?
Hi Ted,
The Sigma sdq I bought had the SA mount metal bezel removed and replaced with a Canon mount bezel.
No adapter is required. The Canon EF mount lens attaches directly to the modified Sigma sdq. I have already tried this and it works.
Abbazz
Abbazz Senior Member • Posts: 1,339
The Sigma 8-16 lens can be used on the SD Quattro H without vignetting from around 10-11mm until 16mm. By shaving the built-in lens shade, it is even possible to shoot from 8mm. This lens offers a surprisingly good image quality considering its price.
8-16mm on SD Quattro H at 8mm
Cheers!
Abbazz
xpatUSA
Jeffry7 wrote:
xpatUSA wrote:
Jeffry7 wrote:
xpatUSA wrote:
Jeffry7 wrote:
dpreviewblog wrote:
Jeffry7 wrote:
Hi folks,
Other advantages?
Hi Ted,
Sorry, I missed that - thought it was a different Quattro than your H ...
atom14
atom14 Veteran Member • Posts: 3,301
Umm..., there is one...
...so far unmentioned [what I sometimes find to be a] disadvantage...
Jeffry7 wrote:
Hi folks,
Other advantages?
I have the Sigma 8-16, and most markedly at the widest FL setting it introduces a distortion due to the attempt to render such a wide rectilinear projection, viz:
The subject elongates progressively from the centre of the image.
This is not always noticeable in landscape scenes, and is more of a problem where people are included, making them appear much wider than they are, but it is still there in any scene. In terms of the potential stitching you mention, I reckon it would pose a problem there as well.
Apart from that, I like the lens for its u-wide-a capability.
atom14.
Abbazz
Re: Umm..., there is one...
Jeffry7 wrote:
Hi folks,
Other advantages?
atom14.
That's why I always use a square aspect ratio when shooting with a rectilinear ultrawide.
If I want to shoot in 2:3 aspect ratio, I much prefer using a fisheye and run the image through Fisheye-Hemi to get a defished image without the edge elongation associated with rectilinear ultrawides.
Here is a nice write-up about "defishing": https://www.lonelyspeck.com/defish/
Cheers!
Abbazz
atom14
Thanks, Abbazz...
Abbazz wrote:
Jeffry7 wrote:
Hi folks,
Other advantages?
atom14.
Cheers!
Abbazz
In that video, it's the Photoshop "Warp" method that I use to fix my really noticeable shots. It's a bit finicky, but it's worth it for a good shot.
atom14.
danski0224 Senior Member • Posts: 1,465
Jeffry7 wrote:
Hi Ted,
Do tell more. Auto focus? Aperture?
Moments in Time, a work in progress.... https://www.flickr.com/gp/142423236@N08/965cs3
danski0224 wrote:
Jeffry7 wrote:
Hi Ted,
Yes to both. I have it from a friend that Sigma adopted the Canon lens protocol for their cameras. I guess this would mean that Sigma SA mount lenses from Sigma and Canon EF lens mount lenses from Sigma only differ by the mechanical connection and are therefore cheaper. (Logistically. Fewer seperate components for each model of lens.)
I got the already modified camera specifically to keep my options open to the wealth of Canon EF lenses.
Scottelly
Scottelly Forum Pro • Posts: 18,026
Jeffry7 wrote:
Hi folks,
Other advantages?
A cheap, light, and small alternative to the 14-24 Art is the 10-20mm f3.5 EX. You can put filters on it, and it will give you a wider view than the 14-24. I have the slightly wider 8-16, which is heavier, and I hate the lens cap (and the fact that I can't use filters). Still, the 8-16 works quite well from 9mm to 16mm on the SD Quattro H. The view is crazy wide! You'll like it for some subjects, but it can be addicting, and believe it or not, you will sometimes wish you could get an even wider view.
You can see more (and larger versions) in my galleries on my website.
Here's a thread with a bunch of photos from the 8-16 on the SD Quattro H (including buildings, interior shots, and natural/landscape scenes):
https://www.dpreview.com/forums/post/62591835
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Interesting.
Any info on the electronic connection? As in, is the layout the same (probably, easier for Sigma).
Person that did the mods? Still possible?
More in line with your original question, I prefer to stitch together a couple or few shots taken in portrait orientation. The wide/ultra wide look does not always work.
With a little effort and auto focus disabled, stitching usually works fine after some practice. I wouldn't use the technique without practice. Don't always need a tripod, either.
