Re: sdQH & fp with the 40mm Art f/1.4 - Kitchen Table Comparison
xpatUSA wrote:
Scottelly wrote:
xpatUSA wrote:
Scottelly wrote:
xpatUSA wrote:
Is there even one credible reference which backs up "I know enough to know that an image circle doesn't suddenly get blurry half a [millimeter] off the sensor" statement? And why "suddenly" ??
Suddenly, as in over a small distance from the sensor (as in suddenly as in it was not blurry, and then, as the lens moves ever so slightly to the side it gets suddenly blurry). <>
Image blur does not work like that, Scott.
If you can not agree, please provide a credible reference that upholds your claim.
[edit]
I think you are confusing "shift" with Cicala's tests which are to do with differences in distance from the lens flange to the sensor.
Ted, in this thread I quoted: I can't agree with this statement: "Misalignment of 10 microns from side-to-side was enough to cause blur on the sides of the image."
See where it says, ". . . from side-to-side . . ." Ted?
https://www.dpreview.com/forums/post/66947476
I do agree that a shift of lens position caused by an adapter will make no difference provided that all four faces are parallel.
Thank you for saying that, and I'm glad. That shows to me that you don't disagree with what seemed obvious to me by the many examples I have seen in the past from photos shot with tilt-shift adapters.
However, I am assuming that Cicala's test setup ensures that the target is parallel with the sensor. Which leaves tilt (adapter faces not parallel) as a possible cause of varying focus across an image - as indeed shown in his test results.
That could indeed happen Ted, but a tilt of a few microns further away or closer to the sensor at one side of a mount that is like forty or fifty milimeters in diameter works out to an incredibly insignificant tilt. With a tilt-shift set-up, such as a bellows camera (4x5 large format, for instance) the maximum tilt is often as much as 45 degrees. I believe five degrees is enough to significantly change the focal plane, so the perfectly focused plane would be changed enough to cause significant blur, when using wide apertures on close subjects, even with a wide-angle lens. A few microns over 45mm is not five degrees though. In fact, it's not even one degree, and one degree is almost imperceptible, unless you're shooting macro shots of subjects less than one foot from the lens, and using a wide aperture lens (i.e. f1.4 or f2.8) wide open, or very close to wide open.
Imagine tilting the camera by one degree. That'd be pretty difficult to measure, huh? How many times have you considered/wondered if your plane of focus matched a wall you were focusing on? I have many times. I never imagined I would get my camera's sensor within one degree of being parallel to the wall. I have done the same with paintings and old photo prints several times. I doubt my estimates were accurate within one degree, but that isn't generally necessary, because I would just focus on one corner, shoot a photo, and check the focus on the far corner. Then I'd make an adjustment if necessary. I don't know why Roger Cicala can't or won't do the same, when testing his lens and adapter combinations.
No need to mention tilt lenses in support of your claim, I am not discussing their usage in this context.
[/edit]
... I bet that Iain is just loving this exchange ...
what you got is not what you saw ...
