Re: sdQH & fp with the 40mm Art f/1.4 - Kitchen Table Comparison
xpatUSA wrote:
Scottelly wrote:
xpatUSA wrote:
Scottelly wrote:
... According to Args and Ted, the adapter causes image quality degradation ...<>
Ted made no such simple statement, instead agreeing more with Cicala than Scottelly.
Cicala said:
... Although it doesn’t always work. Lloyd Chambers first reported years ago that with high-quality, wide-angle lenses you could detect very small misalignments in the camera-lens mount. Misalignment of 10 microns from side-to-side was enough to cause blur on the sides of the image.
What?!? BALDERDASH!
I can't agree with this statement: "Misalignment of 10 microns from side-to-side was enough to cause blur on the sides of the image."
What was that in reference to? A microscope?
Here Cicala tested a good few adapters:
https://www.lensrentals.com/blog/2013/09/there-is-no-free-lunch-episode-763-lens-adapters/
I won’t bore you with another 20 graphs that look pretty much like these. We tried Leica to NEX and Leica to Micro 4/3 adapters, Canon to NEX, etc. We tried different lenses on one adapter. It didn’t really matter. None of them would be acceptable for testing. Not one.
I’ll point out that we carry only name-brand, fairly expensive adapters, not eBay $29 adapters. All of them are tested frequently and used frequently and none of the ones I tested today had any problems. Still, not one of them would be acceptable for testing, so I guess I’m going to have to order those expensive lens mounts after all.
Maybe you should read the whole article.
There's no way . . . I repeat . . . NO WAY . . . that one tenth of a [millimeter] will make any noticeable difference to the image quality on an APS-C camera, let alone a full-frame camera. That statement seems totally absurd to me.
The resolution is so high on the Nikon D3x that the tiniest misalignment between lens mount and sensor and lens results in edge or corner blur. We’re talking 5-10 microns, an almost impossible manufacturing challenge. Why short focal lengths? Because the percentage error for any fixed alignment error is much larger.
https://diglloyd.com/blog/2009/20090802_1-UltraWideAlignment.html
Do you actually believe [Cicala's] statement Ted?
Yep, and no emotive response without credible references, such as yours, will change my mind.
Ted, neither of them seem to be taking into account that when tilting a lens all that happens is the angle of the focal plane changes slightly, something simple to adjust for by slightly changing the angle of the camera, and when shifting a lens even that doesn't happen. One milimeter of shift is like nothing. Most tilt shift adapters will shift up to ten milimeters! Then there would be a noticeabke difference, but shifting the center point of the image the lens projects across the sensor by just one tenth of a milimeter ir even by a whole milimeter is not going to have any significant affect on the image quality. If you can't see how that woukd be the case, then I don't know how else to help you understand, other than to get a tilt-shift adapter for a Sony E mount camera, and show you the resukts of shifting my Nikon 14-24mm f2.8 G over by 1 mm, and then shooting a comparison test shot. In fact, I've been planning to get just such an adapter, and I'll do this experiment for you, posting my resukts in the Adapted Lens Forum, so you can see for yourself. I'll even make shots with the lens shifter over 2 mm, so you can see the affect of a shift of twenty times what Roger Cicala claims is enough to make a lens "untestable."
Cicala knows his stuff and has all the test equipment and enough gear samples to prove/disprove anything he wants to.
Yeah, he surely does, which is why I can't understand why he would actually publish what he wrote.
Your lack of test equipment, test software, decent monitor, sample quantity and, dare I say, technical knowledge pales by comparison.
I guess I haven't earned your respect regarding my knowledge yet, and of course you're correct about my lack of test equipment. Still, I know enough to know that an image circle doesn't suddenly get blurry half a milimeter off the sensor. If it did, then the corners of my SD Quattro H photos that I shot at 10 mm with my 8-16mm lens woukd all be quite blurry, wouldn't they?
