OP
furtle
Re: sdQH & fp with the 40mm Art f/1.4 - Kitchen Table Comparison
TN Args wrote:
furtle wrote:
I would just like to add, my intention of this comparison (and the previous 135mm comparison) is to compare the finished photos which I have created rather than it being a camera vs camera comparison. This is why I included the f/2 comparison to see the quality of the separation and out of focus areas.
How does that make it not a camera vs camera comparison? If you want to compare photos, just use one camera.
What's the point on comparing two identical photos from the same camera, same lens and same processing? Anyhow, it's a comparison of the finished images from two different cameras with the same lens. The final image for each camera is a melange of the sensor, the camera software, the lens, the Raw program, maybe LightRoom and of course the screen to view the image or the print.
It's not just a test comparing the sensors, which I assume could be done with some scientific instruments.
What is apparent is the two final images I produced are remarkably similar with the sdQH edging the sharpness.
For the record, I'm way more interested in the visual interest a photo delivers rather than technical excellence when displayed at some enormous magnification. Sigma cameras do seem to deliver interesting outputs and I do wonder if it is a lot to do with first processing the raw images in SPP.
Sure but let’s be honest, what a photo delivers is up to you, not the camera, unless there is something technically challenging about the photo that makes some cameras less suited than others. With modern cameras they generally can all can deliver the photo you want, except for these edge use cases, when one camera will beat another at what you call “technical excellence when displayed at some enormous magnification”. It might be extra high resolution, or extra good detail retention in shadows, or extra high burst speed, or extra high AF accuracy and speed and tracking.
If you are “way less interested in that”, then honestly, pick any camera and get on with making your middle use case images of vases and back walls, or supreme photographic art, it’s all the same. They are all highly capable at such.
IMO people make a beginner’s mistake in overemphasising the differences in the straight-out-of-camera (SOOC) images, viewed unmagnified on normal sized screens, because then all you are really looking at are differences in colours and contrast and brightness, maybe sharpening, which, to be honest, are all fully adjustable in software…because it is nothing more than software settings anyway. The only justification I can see for putting strong emphasis on SOOC images is for people who are never going to tweak the look in software, but just leave untouched what is, after all and in effect, the camera’s JPEG file. For those people, fair enough, obsess over the look of the software settings between cameras. For the rest of us… it’s pointless, gear-obsessed fun.
Lenses, that’s different…although I could make the same argument in some areas of lens differentiation. People still overplay the ‘lens rendering’ card too, for middle use case photography not viewed at enormous magnifications. But at least there are inherent differentiators like focus transitions that are apparent at normal viewing size.
In my other 135mm comparison, I was skooled and found out that X3F files can be processed in Affinity
Yes.
and this is what DpReview do for their camera tests.
No. It’s what I did for my tests. Before Sigma released firmware that enabled Quattro cameras to output DNG files, DPR used X3F files processed in SPP, which caused many difficulties comparing cameras and knowing what differences are due to the camera and what is due to the different software. Since the sdQH review DPR have used the DNG files in Adobe Camera Raw, hence simplifying the comparison of cameras. Unfortunately the sdQH DNG files are not quite as good as its X3F files, but DPR argued that this has little effect in practice and most users will benefit hugely from using their own standard workflow, so they went with DNG. They also provided X3F files of the test chart photo for those interested, but it doesn’t come up in the DPR comparator tool.
You've confused me. Earlier I asked if Affinity can develop X3F files and you said yes. Now you say the DPR did initially use SPP to process the X3F files but that caused "difficulties". If Affinity can process X3F files, why didn't the DPR testers use Affinity instead of SPP?
Anyway, it seems the DPR testers were given a lifeline with the DNG outputs from the Quattro and these are processed in Affinity and your example images of their tests show the sdHQ is visibly better (at 200%) than the images from the fp; and that's using the Quattro's DNG output which is "not as quite good" as the X3F output.
If DPR had processed the Quattro's X3F files in SPP, the difference between the Quattro shots and the fp shots should have been even more obvious in favour of the Quattro. But in my two examples, that is simple not the case. It is a close run thing between the two images. It should be a home run for the Quattro but it's not. I could do a third test with another Art lens but I'm not sure I'll end up with a different result.
I do wonder if Sigma have boxed themselves into a corner with the fp because the upcoming FFF's image quality will need to be "night and day " better than the Quattro and by reasoning, also that from the fp / fpL. Right now, in my real life comparisons, that's not the case.
I don't have Affinity but I would like to compare the outputs of processing X3F files in SPP and Affinity. Maybe there is no difference.
There is quite a difference. It has led me to conclude that SPP is just as much, or more, responsible for the ‘Foveon look’ as the sensor, in terms of colour and contrast tuning. In all likelihood it has always been the case.
The 'Foveon look'. Umm. Since my fp's final image outputs look very close to my Quattro final images, I'm inclined to think it's the 'SPP look'. Sigma undoubtably have some secret sauce in their SPP programme and it appears to work it's magic on X3F files and the fp's DNG files.
