Lens for handheld focus stacking for indoor orchid exhibition
Started 1 week ago | Discussions
JoeSchmoe007 Contributing Member • Posts: 502
I am looking for a lens recommendation for handheld focus stacking (stacking will be done in Canon DPP, don't care about in-camera stacking) for indoor orchid exhibition.
I did try focus stacking in the past with RF 24-205 STM but I was using tripod.
I will use R5 and have following lenses available:
RF 50 f/1.8 STM
RF 24-105mm f/4-7.1 is stm
RF 70-200 f/2.8 L IS
RF 15-30 STM IS
Which one would produce the best results? I am thinking RF 50 f/1.8 because it is lightweight and has wide aperture.
Also looking for camera setting recommendation for focus stacking for this scenario.
Brian D3300 Senior Member • Posts: 2,428
Re: Lens for handheld focus stacking for indoor orchid exhibition
Try them all at home first to see what you like. My gut says the RF 70-200 f/2.8 will give you the best image quality.    Full electronic  at 20fps would is my guess on the best results as well due to camera shake but you could try the different modes.
 Brian D3300's gear list:Brian D3300's gear list
Canon EOS R5 Canon RF 50mm F1.2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM +3 more
drsnoopy Senior Member • Posts: 1,216
Focus bracketing always uses full electronic shutter at the fastest available frame rate. If you have a slow shutter speed it won’t run faster than the shutter speed allows.
I would suggest trying it with the 50/1.8 and the 70-200, both are listed as compatible, the choice depending on subject and what distance you are working at. Both will give very good results. You don’t need the widest aperture, better to stop down a bit for improved IQ. Bear in mind you can’t use flash, you need continuous lighting, such as natural light or LED.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
koenkooi Contributing Member • Posts: 920
I’d pick something with IS that is sharp wide-open. The RF50 STM fails both those requirements.
Depending on how you want to frame the shots, I’d pick the 15-30 or 70-200.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Ah cool. I did not know that was the only option since that is all I tried.
Good point. I have used a reflector outside as well as a little rectangular continuous light at times. I can't find my original file but it worked pretty well on this Dahlia:
https://www.instagram.com/p/CTJCwLEHZb7/
RogerZoul
RogerZoul Veteran Member • Posts: 3,243
And speaking of lighting, I was playing around with R7 and RF 35mm f1.8 the other day with a Funko thingie (a Green Lantern figurine). After playing around, I found that the stacking worked great at aperture 3.5, for my distance and subject.  I was just using the poor default lighting in my room, and set the iso to 100 (why not?) and let the camera handle the shutter. It set the aperture between 0.5s and 1.3s (I did 3 or 4 stacks) and the camera gave me several nicely stacked results. I shot from a tripod. I can't wait to try this outside as I often do macro against a bridge, so I'll use that to stabilize the camera rather than using a tripod.  Then I'll just need a bug that isn't moving.
 RogerZoul's gear list:RogerZoul's gear list
Canon EOS R5 Canon EF 500mm f/4.0L IS II USM Canon RF 35mm F1.8 IS STM Macro Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 800mm F11 IS STM +31 more
The OP is using an R5, so lens IS is not necessary. There is no need to use a lens wide open for focus bracketing, in fact it’s best not to use wide open in order to have smoother focus transition between frames. The RF 50/1.8 is beautifully sharp across the frame at f2.8 or f4.
So you could equally well conclude that the RF 50/1.8 succeeds on both counts.
The colors are muddier on the 50 1.8 though compared to the 70-200mm, that's part of my preference to recommend the  70-200.
OP JoeSchmoe007 Contributing Member • Posts: 502
I don't disagree about colors but wouldn't 70-200 be significantly more difficult to handheld stable enough for the stacking?
I think the IS paired with the R5 is pretty darn good but I guess that would be something to experiment with.
KevinRA Senior Member • Posts: 1,457
RF 50 f/1.8 STM
RF 15-30 STM IS
50mm lens  at f2.8.
You probably already expert in this - orchids can be quite challenging in photostacking due to the detail of the flowers - e.g. parts of flowers / plants in front of other parts so when out of focus in the foreground, this blooms across the background when focussed there.  Helicon Soft I find better than DPP but usually in complex shots end up with some re-touching in helicon then on pixel peeping, using photoshop too.
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
robgendreau Forum Pro • Posts: 10,917
A tough but very practical question.
I'd test at home, gradually lowering the illumination.
There are several variables at work that all interact: the exposure, MFD, and IBIS. Not to mention maybe relying on some cropping. Still helps to be able to stop down a bit, and you can probably push ISO a ways. And finally, you'd get different looks with different focal lengths too, especially if you need some subject isolation via that choice.
I am also not sure which of those lenses, if any, suffer from focus breathing. Although very skillful movement of the body with fixed focus and some burst shooting vs using camera assisted focus bracketing can work for that. Tough without a support though.
I'm sure we'd love for someone to do a complete series of experiments with examples and let us know
Good luck,
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
So I ran some tests at home and no focus stacking for me this time.
And my preference at this time is RF 50 f 1.8 at 1.8-2.8 with a on camera flash in HS manual mode. NO FOCUS STACKING! Shutter speed as fast as needed to obliterate ambient light (1/4000 sec in my test), ISO 100 (like shooting indoor portrait with strobes).
This way background is dark and out of focus (if there is enough space between the flower and the background).
charlyw64 Contributing Member • Posts: 717
You do know that orchids, especially the large tropical epiphytes have so large cells in their flowers that you will get reflections from cell walls if you use a flash which will be obliterating the color. It will also make stacking a complete mess (which already is exceedingly hard given that the flowers are complex and have large elements overlapping elements further back which will destroy any chances of getting a decent stacking result, especially because the harsh shadows due to the direct flash will vary shot to shot...
No, I didn't know any of that. Thanks for sharing. I also gave up on stacking idea.
So what do you recommend?
That depends on what you want to take in terms of photos - full flower spikes don't need any stacking, just a middle of the road aperture. You can often vary the angle at which you photograph to get a decent background. If you are aiming for single flower shots, then concentrate on where the viewer should be looking - use the DOF to guide the viewers eye towards what you find interesting about the flower.
